查看: 1629|回复: 2
[求助] lisp批量自身旋转,求大神修改
发表于 2021-7-17 06:12:26 | 显示全部楼层 |阅读模式
(defun C:ZR ()
(setvar "cmdecho" 0) ;指令执行过程不响应
(princ "\n自身旋转")
(setq ss (ssget))
(repeat (setq i (sslength ss))
(setq i (1- i) a (vlax-ename->vla-object (ssname ss i)))
(vla-getboundingbox a 'minpt 'maxpt)
(mapcar 'set '(minpt maxpt) (mapcar 'vlax-safearray->list (list minpt maxpt)))
(setq p (mapcar '(lambda (x y) (/ (+ x y) 2.0)) minpt maxpt))
(command "_.rotate" ss "" p 90.0)
(princ)
(目前选择一个对象可以,批量就不行)
已领礼包: 677个
发表于 2021-9-14 13:54:38 | 显示全部楼层
command里面SS改为A
GMT+8, 2026-11-3 08:31 , Processed in 0.402322 second(s), 33 queries , Gzip On.
