查看: 2183|回复: 1
[求助] 请求帮助选择顺走向的线
已领礼包: 1337个
发表于 2021-11-10 12:44:46 | 显示全部楼层 |阅读模式
悬赏20D豆未解决
  1. ;;====================
  2. (defun c:tt (/ ang ang:  ang0 app i mid n na na1  obj p1 p2 pa pa: pb pb:
  3.        ss)
  4.   ;;可以270度
  5.           ;
  6.   (setq jl 0.1)        ;
  7.   (setq app nil)      ;(setq na (car (entsel "pp")))    ;
  8.   (setq s (ssget))
  9.   (setq na (ssname s 0))
  10.   (color na 3)
  11.   (setq pa (vlax-curve-getstartpoint na))
  12.   (setq pb (vlax-curve-getendpoint na))  ;
  13.           ;
  14.   (setq ang (angle pa pb))
  15.   (if (> ang 6)        ;处理转弯处,6.28->0
  16.     (setq ang (abs (- ang 6)))
  17.   )
  18.   (setq n 1)
  19.   (while (= n 1)
  20.     ;;=================================================
  21.     (setq pt-list (9pt pb jl))
  22.     (setq ss (ssget "cp" pt-list))
  23.     ;;==================================================
  24.           ;
  25.     (repeat (setq i (sslength ss))
  26.       (setq na1 (ssname ss (setq i (1- i))))
  27.       ;;==============
  28.       (setq pa: (vlax-curve-getstartpoint na1))
  29.       (setq pb: (vlax-curve-getendpoint na1))
  30.       ;;---
  31.       (if (equal pb pa: 0.1)
  32.   (progn (setq p1 pa:) (setq p2 pb:))
  33.   (progn (setq p1 pb:) (setq p2 pa:))
  34.       )
  35.       ;;======================
  36.       (setq ang: (angle p1 p2))
  37.       (setq obj (vlax-ename->vla-object na1))
  38.       (setq ang0 (vla-get-angle obj))
  39.       ;;=====================
  40.       (if (> ang: 6)      ;处理转弯处,6.28->0
  41.           ;
  42.   (setq ang: 0)
  43.       )
  44.       ;;==================
  45.       ;;==================
  46.       (if (or (equal ang ang: 0.4)  ;
  47.         (> (abs (- ang: ang)) 5.5) ;
  48.           ;
  49.     )
  50.   (progn (color na1 6)
  51.          (setq n 1)
  52.          (setq ang ang:)
  53.          (setq pb p2)
  54.   )
  55.   (progn (setq n 0)    ;
  56.   )
  57.       )
  58.     )          ;
  59.     ;;==============
  60.   )          ;while
  61.           ;          ;
  62.           ;           ;repeat
  63. )
  64. (defun 9pt (pt dis / ang app ii pt1)
  65.   (setq app ())
  66.   (setq ii 0)
  67.   (setq ang 0)
  68.   (repeat 9
  69.     (setq pt1 (polar pt ang dis))
  70.     (setq app (cons pt1 app))
  71.     (setq ang (+ ang (* 0.25 pi)))
  72.     (setq ii (1+ ii))
  73.   )          ;repeat
  74.   app
  75. )
  76. (defun color (na i /)
  77.   (vla-put-color (vlax-ename->vla-object na) i)
  78. )
  79.           ;
  80.           ;
请修改下,按线走向选择此线,边上有其他线在此线交点处相交,外边杂线不变色
cad线走向.rar
1.02 MB, 下载次数: 2, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 1337个
 楼主| 发表于 2021-11-10 12:51:15 | 显示全部楼层
原线其他软件转过来的,下面连接后炸开,效果好些,干扰没处理好,请大师指导.
GMT+8, 2026-11-3 01:36 , Processed in 0.277304 second(s), 33 queries , Gzip On.
