查看: 1066|回复: 0
[工具] 请求,哪位师傅帮忙改写下这个CAD生成数控钻程序的lisp
发表于 2022-6-29 03:17:12 | 显示全部楼层 |阅读模式
哪位师傅帮忙把我这个源码改写成输出程序是如下的
2019/7/21 19:11:42(生成时间)
P:2(板厚程序中自己给定)
L:2000(板面长度程序中自己给定)
W:1600(板面宽度程序程序中自己给定)
D12(钻头直径系统识别圆直径所得)
R350(对应上面钻头的补偿长度自己给定)
X100 Y100
X200 Y100
X300 Y100
X400 Y100
P:2(板厚程序中自己给定)
D20(钻头直径系统识别圆直径所得)
R360(对应上面钻头的补偿长度自己给定)
X500 Y100
X600 Y100
X700 Y100
M30
END
括号内是注释生成的程序里不需要写字
(defun c:nc1 (/ fp ss ii i r cirlst ss1 r1 r2 r3 j g bb biao biao1 ent)
  (setvar "CMDECHO" 0)
  (setq nm (getstring "输入CNC文件名:") fp (open (strcat nm ".drl") "w"))
  (princ "M48\nMETRIC\nVER,1\nFMAT,2\n" fp)
  (setq ss (ssget "all" '((0 . "CIRCLE"))))
   (command ".UNDO" "BE")
   (setq r2 0 i -1  biao (list) biao1 (list))
   (repeat (sslength ss)
    (setq r (cdr (assoc 40 (entget (setq en (ssname ss (setq i (1+ i))))))))
    (if (assoc r cirlst)
    (setq cirlst (subst (cons r (1+ (cdr (assoc r cirlst)))) (assoc r cirlst) cirlst))
    (setq cirlst (cons (cons r 1) cirlst))
   (setq ii 1 i -1 cirlst (reverse cirlst) )
   (setq cirlst (vl-sort cirlst (function (lambda (e1 e2) (> (car e1) (car e2))))) cirlst (reverse cirlst))
   (repeat (length cirlst)
    (setq r (car (nth (setq i (1+ i)) cirlst)))
    (command "select" ss "")
    (setq ss1 (ssget "P" (list (cons 0 "CIRCLE") (cons 40 r))))
    (setq r1 (getdist (strcat "\n请输入补偿后的钻咀直径<" (rtos  (+ r r)  2 2) "> :")))
    (setq r (if r1 (* r1 0.5) r))
    (if (= r2 0)(setq biao (list))
      (if (= r2 r1) (setq biao biao1)
    (if (/= r2 r1)
         (progn
      (setq d (read (strcat "aa" (itoa ii))) )
      (setq c2 'd c2 biao1)
      (set d biao1)
      (setq biao (list))
      (setq bb (strcat "T" (if (< ii 10) "0" "") (itoa ii) "C" (rtos r3 2 3) "F423B423S6H2000\n"))
      (princ bb fp)
          (setq ii (+ ii 1))
     (setq g (sslength ss1) j 0 )
    (repeat g
     (setq ent (entget(ssname ss1 j)))
     (setq j (1+ j))
     (setq pc (cdr(assoc 10 ent)))
     (setq biao (append biao (list (list (car pc) (cadr pc)))))
    (setq biao1 biao r2 r1 r3 r1)
  (set d biao1)
   (setq bb (strcat "T" (if (< ii 10) "0" "") (itoa ii) "C" (rtos (+ r r) 2 3) "F423B423S6H2000\n"))
   (princ bb fp)
   (setq aa "DETECT,ON\nATC,ON\n%\n")
    (princ aa fp)
    (setq i 0 )
    (repeat ii
    (setq i (1+ i))
    (princ (strcat "T" (if (< i 10) "0" "") (itoa i) "\n;请更换刀具!\n") fp)
    (setq j 0 biaoo (eval (read (strcat "aa" (itoa i)))))
  (repeat (length biaoo)
   (setq pc (nth j biaoo) j (1+ j))
   (princ (strcat "X" (rtos (car pc) 2 3) "Y" (rtos (cadr pc) 2 3) "\n") fp)
    (princ "M30\n;程式结束,欢迎使用!" fp)
    (close fp)
     (command ".UNDO" "E")
  (setvar "CMDECHO" 1)
  (progn (alert  "祝贺你,当前层数控钻孔文件成功输出,请使用!"))
  (princ)
GMT+8, 2026-11-22 10:01 , Processed in 0.402027 second(s), 8 queries , Gzip On, File On.
