查看: 1148|回复: 5
[求助] 计算坐标
已领礼包: 15个
发表于 2022-7-11 20:38:49 | 显示全部楼层 |阅读模式
(defun ayGetAllEntInBLK
       (BlkEntName / xBlkName xBlkDef entName1 entType entNameList)
  (setq xBlkName (cdr (assoc 2 (entget BlkEntName))))
  (setq xBlkDef (tblobjname "Block" xBlkName))
  (setq xlist '() ylist '())
  (while (setq entName1 (entnext xBlkDef))
    (setq entType (cdr (assoc 0 (entget entName1))))
    (if  (= entType "INSERT")
      (setq entNameList
       (append (ayGetAllEntInBLK entName1) entNameList)
      (and (or (= entType "LINE") (= entType "LWPOLYLINE") (= entType "CIRCLE") (= entType "ARC"))
      (progn
(setq o (vlax-ename->vla-object entName1))
(vlax-method-applicable-p o 'getboundingbox)
(vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))
(setq p1 (vlax-safearray->list a))
(setq p9 (vlax-safearray->list b))
(setq p1x (Car p1))
(setq p9x (Car p9))
(setq p1y (Cadr p1))
(setq p9y (Cadr p9))
(setq xlist (cons p1x xlist))
(setq xlist (cons p9x xlist))
(setq ylist (cons p1y ylist))
(setq ylist (cons p9y ylist))
    (setq xBlkDef entName1)
  (list (List (apply 'min xlist) (apply 'min ylist)) (List (apply 'max xlist) (apply 'max ylist)))
;这是论坛大佬的代码,我在上面改了一下想计算块内坐标,结果出来结果不对,应该是要转换一下计算才,我不会,望大神出手
已领礼包: 55个
发表于 2022-7-17 12:21:23 | 显示全部楼层
如果是计算左下角和右上角坐标程序应该没问题吧.
会不会是没有调用 (VL-LOAD-COM)?
不是计算不了,是计算的结果,不是图形上,,以0点计算了  详情 回复 发表于 2022-7-17 16:46
已领礼包: 15个
 楼主| 发表于 2022-7-17 16:46:31 | 显示全部楼层
已领礼包: 55个
发表于 2022-7-17 17:26:59 | 显示全部楼层
明白了,加个嵌套吧.
(defun ayGetAllEntInBLK2 (BlkEntName / a b entname1 entnamelist enttype o p1 p1x p1y p9 p9x p9y xblkdef xblkname xlist ylist)
  (setq xlist '()
        ylist '()
      (setq entNameList (append
                          entNameList
      (and
        (or
          (= entType "LINE")
          (= entType "ARC")
        (progn
          (setq p1x (Car p1))
          (setq p9x (Car p9))
  (list (List (apply
                'min
                xlist
              ) (apply
                  'min
                  ylist
        ) (List (apply
                  'max
                  xlist
                ) (apply
                    'max
                    ylist
(DEFUN ayGetAllEntInBLK (BLKENTNAME / LB P0 P1)
  (SETVAR "CMDECHO" 0)
  (SETQ P0 '(0 0))
  (COMMAND "COPY" BLKENTNAME "" P0 P0)
  (PRINT)
  (COMMAND "EXPLODE" "L")
  (PRINT)
  (COMMAND "COPYBASE" P0 "P" "")
  (PRINT)
  (COMMAND "ERASE" "P" "")
  (COMMAND "_pasteblock" '(0 0))
  (SETQ LB (SSNAME (SSGET "l") 0))
  (SETQ P1 (ayGetAllEntInBLK2 LB))
  (COMMAND "erase" "l" "")
  (SETVAR "CMDECHO" 1)
  P1
(setq aa (ayGetAllEntInBLK (car (entsel)))) 提示错误,函数被取消 另外,能不用COPY 与 炸散吗,直接坐标转换计算  详情 回复 发表于 2022-7-17 22:28
已领礼包: 15个
 楼主| 发表于 2022-7-17 22:28:03 | 显示全部楼层
hhhaaa1121 发表于 2022-7-17 17:26
明白了,加个嵌套吧.
(defun ayGetAllEntInBLK2 (BlkEntName / a b entname1 entnamelist enttype o p1 p1x ...
提示错误,函数被取消
已领礼包: 55个
发表于 2022-7-18 13:04:39 | 显示全部楼层
出错可能是捕捉模式的问题,这个程序是对块原始数据计算对角,如果块只是平移缩放还行,块旋转的话坐标转换解决不了,原程序要动手术。
加个关闭捕捉再试下吧,行不行都是它了。
(DEFUN ayGetAllEntInBLK (BLKENTNAME / LB P0 P1 OS)
  (SETQ OS (GETVAR "osmode"))
  (SETVAR "OSMODE" 0)
  (SETQ P0 '(0 0))
  (COMMAND "_pasteblock" p0)
  (SETVAR "OSMODE" OS)
  P1
GMT+8, 2026-11-3 08:31 , Processed in 0.462625 second(s), 44 queries , Gzip On.
