查看: 1167|回复: 1
[研讨] 获取打印机名称
已领礼包: 511个
发表于 2022-8-24 16:07:48 | 显示全部楼层 |阅读模式
;获取已连接到USB口的打印机名称列表
(setq path     "HKEY_CURRENT_CONFIG\\System\\CurrentControlSet\\Control\\Print\\Printers"
      printers (vl-remove-if
                 '(lambda (x) (= 0 (vl-registry-read (strcat path "\\" x) "PrinterOnLine")))
                 (vl-registry-descendents path)))
;获取网络打印机名称列表
(mapcar
  'car
  (vl-remove-if-not
    '(lambda (y) (wcmatch (cadr y) "192.*"))
    (vl-remove-if
      '(lambda (z) (= (cadr z) nil))
      (mapcar
        '(lambda (x)
           (list
             x
             (vl-registry-read
               (strcat
                 "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\Print\\Printers\\"
                 x)
               "Port")))
          "HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\Devices"
;功能:获取已连接到USB口的打印机或网络打印机
;返回:可用打印机名称或nil
;USB口连接有打印机时返回USB口连接的打印机名称
;USB口未连接打印机,有网络打印机时返回网络打印机名称,无网络打印机时返回nil
(defun getCurrentprinter  (/ path printers)
                   '(lambda (x)
        printers (append
                   printers
                   (list
                     (caar
                       (vl-remove-if-not
                         (vl-remove-if
                           (mapcar
                             '(lambda (x)
                                (list
                                  x
                                  (vl-registry-read
                                    (strcat
                                      x)
                                    "Port")))
  (car printers))
已领礼包: 1194个
发表于 2026-1-2 08:00:07 | 显示全部楼层
又学到有用的知识了。感谢分享。
GMT+8, 2026-11-2 04:04 , Processed in 0.405692 second(s), 30 queries , Gzip On.
