查看: 1438|回复: 2
[编程申请] 高程标注
发表于 2022-9-3 13:50:19 | 显示全部楼层 |阅读模式
这是个高程标注的代码,但是不能调整字的大小,还有就是需要一遍一遍的输入命令分别标注,不能连续标注。哪位大哥能帮我修改一下呢?
(defun c:gc()
(getpoint
(setq a (getpoint "point"))
(setq b (strcat "(" (rtos (caddr a) 2 3) ")"))
(command "-text" a "" "" b "")
发表于 2022-9-7 08:47:16 | 显示全部楼层
(defun c:gc (/ loop a h11 b)
  (setq loop t)
  (while loop
    (initget "h H")
    (setq a (getpoint "\n请输入插入点或者字高H"))
    (IF        (NOT H11)
      (SETQ H11 2.5)
    (COND
      ((or (= a "h") (= a "H"))
       (SETQ H (GETINT (strcat "\n请输入字高<" (rtos h11 2 1) ">")))
       (setq a (getpoint "\n请输入插入点"))
      ((= a nil) (setq loop nil))
      ((listp a) t)
    (command "-text" a h11 "" b "")
非常感谢哈  详情 回复 发表于 2022-11-24 07:19
 楼主| 发表于 2022-11-24 07:19:23 | 显示全部楼层
  (setq loop t)
  (while loop
非常感谢哈
GMT+8, 2026-11-22 07:40 , Processed in 0.493584 second(s), 12 queries , Gzip On, File On.
