查看: 1426|回复: 2
[研讨] SPLINE求最近点
发表于 2023-11-29 02:56:17 | 显示全部楼层 |阅读模式
As shown in the figure, I got the AcGeCurve3d object corresponding to SPLINE,
But no matter whether I use DB method or AcGe method,
AcGeCurve::GetclosestPointTo
AcGeCurve::ClosestPointTo
The nearest points obtained are equal to the control point P1,
If used
AcGeCurve3d::GetNormalPoint
Get the point on the normal line passing through P1, the result is false,
For others such as: kCircArc3d, kLineSeg3d....the results are normal.
That is, the correct result cannot be obtained for SPLINE (AcGeNurbCurve3d(2d)).
How can I get the closest point P2?
发表于 2023-12-4 08:06:36 | 显示全部楼层
谢谢分享!!!!!
发表于 2023-12-6 08:39:30 | 显示全部楼层
谢谢分享!!!!!!
GMT+8, 2026-11-22 08:54 , Processed in 0.260458 second(s), 13 queries , Gzip On, File On.
