查看: 1191|回复: 3
[源码] 截取多段线于精确两点
发表于 2024-7-19 15:54:34 | 显示全部楼层 |阅读模式
;截取多段线于精确两点,适用于闭合多段线和非闭合多段线
(defun c:partCopy ()
  (setq entpnt0 (entsel "\n选择要截取的多段线:"))
  (if (not entpnt0)
    (vl-exit-with-error "")
  (if (not
        (wcmatch (cdr (assoc 0 (entget (car entpnt0)))) "*POLYLINE")
;;;  (redraw (car entpnt0) 3)
  (setq p1 (getpoint "\n指定第一个打断点:"))
  (if (not p1)
  (setq p2 (getpoint "\n指定第二个打断点:"))
  (if (not p2)
  (if (equal p1 p2 0.0001)
  (if (isclosePL (car entpnt0))
    (progn
      (setq pmid (getpoint "\n指定中间点:"))
      (if (not pmid)
      (if (or (equal p1 pmid 0.0001) (equal p2 pmid 0.0001))
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (vla-copy (vlax-ename->vla-object (car entpnt0)))
  (setq ent (entlast))
  (setq entpnt (list ent (cadr entpnt0)))
  (setq vlaObj (vlax-ename->vla-object ent))
  (setq stapnt (vlax-curve-getStartPoint vlaObj))
  (setq endpnt (vlax-curve-getEndPoint vlaObj))
  (setq pt1 (vlax-curve-getclosestpointto ent p1)) ;取得最近点
  (setq para1 (vlax-curve-getParamAtPoint ent pt1)) ;取得参数
  (setq pt2 (vlax-curve-getclosestpointto ent p2)) ;取得最近点
  (setq para2 (vlax-curve-getParamAtPoint ent pt2)) ;取得参数
  (if (> para1 para2)
    (progn
      (setq tempval0719 pt1)
      (setq pt1 pt2)
      (setq pt2 tempval0719)
  (if (not (isclosePL (car entpnt0)))
    (progn
      (command "BREAK" entpnt "f" stapnt pt1)
      (command "BREAK" entpnt "f" pt2 endpnt)
    (progn
      (setq ptmid (vlax-curve-getclosestpointto ent pmid)) ;取得最近点
      (setq paramid (vlax-curve-getParamAtPoint ent ptmid)) ;取得参数
      (if (between paramid para1 para2)
        (progn
          (if (equal stapnt pt1)
            (progn
              (setq para2 (vlax-curve-getParamAtPoint vlaObj pt2))
              (setq paraEnd (vlax-curve-getEndParam vlaObj))
              (setq para2E (/ (+ para2 paraEnd) 2.0))
              (setq pt2E (vlax-curve-getPointAtParam vlaObj para2E))
              (command "BREAK" entpnt "f" pt2 pt2E)
              (command "BREAK" entpnt "f" pt2E endpnt)
            (progn
        (progn
          (command "BREAK" entpnt "f" pt1 pt2)
  (setq layerName "复线")
  (if (not (tblsearch "layer" layerName))
    (command "layer" "m" layerName "")
  (command "chprop" ent "" "LA" layerName "")
  (command "undo" "e")
  (setvar "cmdecho" 1)
  (princ)
;判断是否介于二者之间
(defun between (mynum num1 num2)
  (> 0.0 (* (- mynum num1) (- mynum num2)))
;;;判断曲线是否闭合
(defun isclosePL (ent / ed)
  (setq ed (entget ent))
  (or (= 1 (cdr (assoc 70 ed)))
      (equal (assoc 10 ed) (assoc 10 (reverse ed)))
已领礼包: 228个
发表于 2024-7-31 08:05:35 | 显示全部楼层
不错,谢谢分享!!!!!!
已领礼包: 228个
发表于 2024-7-31 08:13:23 | 显示全部楼层
不错,谢谢分享!!!!!!
GMT+8, 2026-11-3 08:04 , Processed in 0.476433 second(s), 39 queries , Gzip On.
