查看: 3096|回复: 1
[多段线] 你好各位大神帮我修改一下这个代码
发表于 2024-8-3 15:50:59 | 显示全部楼层 |阅读模式
你好各位大神帮我修改一下这个代码正常我在多段线上输入50多段线上就出现个50标注,现在是输入50他出现359.0197801584798麻烦各位大神帮帮忙修改输入多少数字就出现多少数字好比输入50就出现50。
(defun c:tg(/  p1 p2 p3 p4 pt dd)
    (command ".undo" "be")
  (setq p1(getpoint "\n指定点"))
  (command ".CIRCLE" "non" p1 3)
(while
  (setq p2(getpoint p1 "\n指定点")
        p3(polar p1 (angle p1 p2) 3)
        p4(polar p2 (angle p2 p1) 3)
  (command ".line" "non" p3 "non" p4 "")
  (setq dd (distance p1 p2)
        pt (polar p2 (angle p2 p1) (+ (* dd 0.55) 1.5)))
    (command ".CIRCLE" "non" p2 3)
     (command ".text" "non" pt 6 (/ (* (angle p1 p2) 180.0) pi) (rtos dd 2 2)  "")
  (setq p1 p2)
  (command ".undo" "e")
  (princ)
这是第二个代码也是这种情况麻烦也帮我修改一下谢谢:
(defun c:t2t ( /  p1 p2 p3 p4 pt dd)
(setq rad (getdist  "\n指定半径: "))
(setq p1 (getpoint "\n指定圆心: "))
(while
  (setq p2 (getpoint p1 "\n指定点") )
  (command ".line" "non" p1 "non" p2 "")
          pt (polar p2 (angle p2 p1)  (* dd 0.5)))
  (setq p3 (polar pt (atan (/ (* (angle p1 p2) 180.0) pi)) 0.6))
      (LM:CircularWipeout p1 rad)
     (command ".text" "j" "c" "non" p3 6 (/ (* (angle p1 p2) 180.0) pi) (rtos dd 2 2)  "")
  (setq p1 p2)
  (princ)
(defun LM:CircularWipeout ( cen rad / ang inc lst )
(setq acc 50 inc (/ pi acc 0.5) ang 0.0)
(repeat acc(setq lst (cons (list 14 (* 0.5 (cos ang)) (* 0.5 (sin ang))) lst)ang (+ ang inc)))
(entmakex(append(list '(000 . "WIPEOUT")'(100 . "AcDbEntity")'(100 . "AcDbWipeout")
(cons 10 (trans (mapcar '- cen (list rad rad)) 1 0))(cons 11 (trans (list (+ rad rad) 0.0) 1 0 t))
(cons 12 (trans (list 0.0 (+ rad rad)) 1 0 t))'(280 . 1)'(071 . 2))(cons (last lst) lst))))
(princ)
发表于 2024-8-22 15:08:14 | 显示全部楼层
没毛病啊,输50出来的是50啊。你是不是没关捕捉,所以捕到其他点了啊
GMT+8, 2026-11-22 07:37 , Processed in 0.172718 second(s), 10 queries , Gzip On, File On.
