查看: 1875|回复: 1
[每日一码] Merge two color blocks (HATCH)
发表于 2025-1-9 18:26:12 | 显示全部楼层 |阅读模式
论坛中写的代码主要是为了演示将要介绍的主要函数的使用方法,可能有更好或更直接的实现方式。
以下代码主要介绍AcGe几何库函数,并使用MPOLYGON对象对HATCH实体进行UNION。
  1. (efun c:XDTB-HatchUnion (/ e1 e2)
  2.   ;| Use the AcGe geometry library to determine whether it intersects|;
  3.   (defun _hasInterPnts (e1 e2 / g1 g2 intv ret)
  4.     (setq ret
  5.            (and (setq g1 (xdrx-getpropertyvalue e1 "rootloopat" 0))
  6.                 (setq g2 (xdrx-getpropertyvalue e2 "rootloopat" 0))
  7.                 (setq intv (xdge::getpropertyvalue g1 "getinterval" g2))
  8.            )
  9.     )
  10.     (xdrx-object-release g1 g2 intv)
  11.     ret
  12.   )
  13.   (if (and
  14.         (setq e1 (car (xdrx-entsel "\nSelect main color block<Exit>:" '((0 . "HATCH")))))
  15.         (xdrx-pickset-redraw e1 3)
  16.         (setq e2 (car (xdrx-entsel "\nSelect the color blocks to be merged<Exit>:" '((0 . "HATCH")))))
  17.         (not (eq e1 e2))
  18.       )
  19.     (progn
  20.       (xdrx-begin)
  21.       (if (_hasInterPnts e1 e2)
  22.         (progn
  23.           (xdrx-hatch->mpolygon e1 t)
  24.           (xdrx-hatch->mpolygon e2 t)
  25.           (xdrx-mpolygon-union e1 e2)
  26.           (xdrx-mpolygon->hatch e1)
  27.           (xdrx-prompt "\nTwo color blocks were successfully merged.")
  28.         )
  29.       )
  30.       (xdrx-end)
  31.     )
  32.   )
  33.   (princ)
  34. )
发表于 2025-1-15 09:00:38 | 显示全部楼层
N版,猛男   !!
GMT+8, 2026-11-22 07:41 , Processed in 0.649270 second(s), 12 queries , Gzip On, File On.
