查看: 1535|回复: 0
[每日一码] (XDGE几何库应用)三点获取圆弧信息
发表于 2025-1-22 16:44:48 | 显示全部楼层 |阅读模式
XDRX API 有个函数 xdrx-geom-3p2arc ,根据三点,获取圆弧信息
如果3点组成逆时针弧
(xdrx-geom-3p2arc p2 pin p1)
(T (3637.41 842.633 0.0) 836.058 0.334996 2.67516)
如果3点组成顺时针弧
(xdrx-geom-3p2arc p1 pin p2)
(nil (3637.41 842.633 0.0) 836.058 0.334996 2.67516)
获取的圆弧信息数据是按逆时针弧返回的,第一个T或者NIL反映时针方向
下面用XDGE几何库,来模拟实现上面函数xdrx-geom-3p2arc
  1. (defun xd::geom:3p2arc (pstart pmid pend / garc sang eang #center #radius #isclockwise)
  2.   (if (setq garc (xdge::constructor "kCircArc2d" pstart pmid pend))
  3.     (progn
  4.       (xdrx-getpropertyvalue
  5.         garc  "center" "radius"  "isclockwise")
  6.       (setq sang (xdrx-vector-angleonplane
  7.                    (xdrx-vector-normalize
  8.                      (mapcar '-
  9.                              pstart
  10.                              (list (car #center) (cadr #center) 0.0)
  11.                      )
  12.                    )
  13.                    '(0 0 1.0)
  14.                  )
  15.             eang (xdrx-vector-angleonplane
  16.                    (xdrx-vector-normalize
  17.                      (mapcar '-
  18.                              pend
  19.                              (list (car #center) (cadr #center) 0.0)
  20.                      )
  21.                    )
  22.                    '(0 0 1.0)
  23.                  )
  24.       )
  25.       (if #isclockwise
  26.         (list nil #center #radius eang sang)
  27.         (list t        #center        #radius        sang eang)
  28.       )
  29.     )
  30.   )
  31. )
  1. Command: (XD::GEOM:3P2ARC p1 pin p2)
  2. (nil (3637.41 842.633) 836.058 0.334996 2.67516)
  3. Command: (XD::GEOM:3P2ARC p2 pin p1)
  4. (T (3637.41 842.633) 836.058 0.334996 2.67516)
GMT+8, 2026-10-11 08:24 , Processed in 0.508067 second(s), 29 queries , Gzip On.
