查看: 1790|回复: 4
[文章]:已知一段弧的起点和终点以及其凸度,求其圆心
发表于 2003-7-29 15:56:53 | 显示全部楼层 |阅读模式
int getCenter(ads_point startPoint,ads_point endPoint,double bulge,ads_point& center)
  if (bulge==0.0)
    ads_point_set(startPoint,center);
    return 0;
  ads_point startPt,endPt;
  if (bulge<0.0)
    ads_point_set(endPoint,startPt);
    ads_point_set(startPoint,endPt);
    bulge=bulge*(-1.0);
  else
    ads_point_set(startPoint,startPt);
    ads_point_set(endPoint,endPt);
  double distStartToEnd,distX,distY,radius;
  distStartToEnd=ads_distance(startPt,endPt);
  distX=distStartToEnd/2.0;
  distY=bulge*distX;
  radius=((distX*distX)+(distY*distY))/(2.0*distY);
  double tmpAng;
  ads_point tmpPt;
  tmpAng=ads_angle(startPt,endPt);
  ads_polar(startPt,tmpAng,distX,tmpPt);
  ads_polar(tmpPt,(tmpAng+(_PI/2.0)),(radius-distY),center);
  return 1;
已领礼包: 145个
发表于 2003-7-29 19:29:51 | 显示全部楼层
Re: [文章]:已知一段弧的起点和终点以及其凸度,求其圆心
最初由 godking311 发布
[B]已知一段弧的起点和终点以及其凸度,求其圆心
  if (bulge==0.0)
... [/B]
典型的ADS写代码的方法,其实利用AcGe Helper 类的AcGeCircArc2d类,可以非常方便的得到,以后大家在求对象的几何性质的时候,不放多利用下AcGe Helper类
  1. [font=courier]
  2. AcGeCircArc2d(
  3. const AcGePoint2d& startPoint,
  4. const AcGePoint2d& endPoint,
  5. double bulge,
  6. Adesk::Boolean bulgeFlag = Adesk::kTrue);
  7. startPoint Input start point of arc
  8. endPoint Input endpoint of arc
  9. bulge Input bulge distance
  10. bulgeFlag Input how to interpret bulge distance for arc calculation
  11. Constructs an arc with the specified start and endpoints. If a line is drawn
  12. between startPoint and endPoint, then the distance between this line
  13. and the midpoint of the constructed arc is equal to the bulge distance.
  14. The direction of the constructed arc is always counterclockwise.
  15. startPoint must be different than endPoint. This constructor always
  16. constructs a bounded arc and cannot be used to construct a full circle. If
  17. bulgeFlag is Adesk::kTrue, then bulge is interpreted to be the maximum
  18. distance between the arc and the chord between the two input points. If
  19. bulgeFlag is Adesk::kFalse, then bulge is interpreted to be the tangent of
  20. 1/4 the included angle (tan(ang/4)), where ang is the angle of the arc
  21. segment between the two input points.
  22. [/font]
复制代码
所以你上面的代码可以简单的写成:
  1. [font=courier]
  2. AcGeCircArc2d mArc(startPt,endPt,bulge); //利用构造函数得到几何圆弧数学模型
  3. AcGePoint2d cenPt=mArc.center(); //得到圆心。
  4. [/font]
复制代码
 楼主| 发表于 2003-7-30 11:33:35 | 显示全部楼层
向你敬礼!请多指教
发表于 2003-8-2 23:17:44 | 显示全部楼层
//多义线的圆弧插补数据输出
void arxtestccarc(AcDbPolyline *pPline,int num)
        double cbulge;
        ads_real len,rad,bu,angle1,L_angle,steplen,symbolK,symbolU,symbolV,deltaX,deltaY,distXY;
        ads_point cpt1,cpt2,centerpt,intpt1,intpt2;//centerpt为圆心坐标,rad为半径,intpt为插补点
        AcGePoint2d basept1,basept2;//点的类型转换
        char cptbuffer[50];
        pPline->getBulgeAt(0,cbulge);
//        acutPrintf ("\nBulge.%f",bulge);
        pPline->getPointAt(num,basept1);
        pPline->getPointAt((num+1),basept2);
//        pPline->close();
        cpt1[X]=basept1.x;
        cpt1[Y]=basept1.y;
        cpt2[X]=basept2.x;
        cpt2[Y]=basept2.y;
        cpt1[Z]=cpt2[Z]=0;
        len=acutDistance(cpt1,cpt2);
        //acutPrintf ("\nlen.%f",len);
        bu=fabs(cbulge);
        //acutPrintf ("\nbu.%f",bu);
        rad=(bu+1/bu)*len/4;
        //acutPrintf ("\nrad.%f",rad);
        angle1=acutAngle(cpt1,cpt2);
        //acutPrintf ("\nangle1.%f",angle1);
        //angle1=acutAngle(pt2,pt1);//试验pt1和pt2的次序影响
        //acutPrintf ("\nangle2.%f",angle1);
        L_angle=angle1+atan(1/(2*cbulge) - cbulge/2);
        //acutPrintf ("\nL_angle.%f",L_angle);
        centerpt[X]=cpt1[X]+rad*cos(L_angle);
        centerpt[Y]=cpt1[Y]+rad*sin(L_angle);
        //acutPrintf ("\ncenter:%f",centerpt[X]);
        //acutPrintf ("\ncenter:%f",centerpt[Y]);
        steplen=2*pow((2*rad*tolerance-tolerance*tolerance),0.5);
        symbolK=steplen/rad;
        symbolU=pow(symbolK,2)/2;
        symbolV=symbolK*pow((1-symbolK*symbolK/4),0.5);
        intpt1[X]=cpt1[X]-centerpt[X];//pt1x坐标平移
        intpt1[Y]=cpt1[Y]-centerpt[Y];//pt1y坐标平移
        intpt2[X]=cpt2[X]-centerpt[X];//pt2x坐标平移
        intpt2[Y]=cpt2[Y]-centerpt[Y];//pt2y坐标平移
                if(cbulge>0)//逆圆弧,在这里判断了,那么主程序中就无需判断了,只要分成是否等于零两类即可
                                //distXY=tolerance+1;//设置插补距离起始标志
                        for(distXY=steplen+1;distXY>steplen;)  ////计算下一个点的循环程序,循环条件就是终点判断
                                deltaX=symbolU*intpt1[X]+symbolV*intpt1[Y];//求增量x
                                deltaY=symbolV*intpt1[X]-symbolU*intpt1[Y];//求增量y
                                intpt1[X]=intpt1[X]-deltaX;
                                intpt1[Y]=intpt1[Y]+deltaY;
                                distXY=acutDistance(intpt2,intpt1);//判断终点的计算
                                //将x坐标平移还原化成字符串
                                //将y坐标平移还原化成字符串
                                                        _ltoa((long)((intpt1[X]+centerpt[X])*39.37),  cptbuffer,10 );//x
                                                        str=cptbuffer;
                                                        str="X"+str;
                                                        writedata(str,path);
                                                        _ltoa((long)((intpt1[Y]+centerpt[Y])*39.37),  cptbuffer,10 );//y
                                                        str=cptbuffer;
                                                        str="Y"+str+"*";
                        //写入pt2
                if(cbulge<0)//顺圆弧
                        //        distXY=tolerance+1;//设置插补距离起始标志
                                deltaX=symbolV*intpt1[Y]-symbolU*intpt1[X];//求增量x
                                deltaY=symbolV*intpt1[X]+symbolU*intpt1[Y];//求增量y
                                intpt1[X]=intpt1[X]+deltaX;
                                intpt1[Y]=intpt1[Y]-deltaY;
                                //判断终点的计算
                                //将x坐标平移还原化成字符串
                                //将y坐标平移还原化成字符串
                                                        str=cptbuffer;
                                                        str="X"+str;
                                                        str=cptbuffer;
                                                        str="Y"+str+"*";
                        //写入pt2
        // TODO: Implement the command
发表于 2003-10-24 12:43:37 | 显示全部楼层
有一个弧度,怎么计算它的bugle. 我怎么总是算错。555.
不是 tan((pArc->endAngle()-pArc->startAngle())/4)吗
GMT+8, 2026-11-5 02:37 , Processed in 0.442645 second(s), 40 queries , Gzip On.
