查看: 2668|回复: 3
[求助]:createFromCurves是不是有内存泄漏?!
发表于 2003-8-1 12:42:41 | 显示全部楼层 |阅读模式
我发现在用explode函数炸开后,删除对象时,若这样删除:
for (i = 0; i < lines.length(); i++)
delete  lines;
就会有内存泄漏,但这样删除:
delete (AcRxObject*)lines;
就不会有泄漏,
但我发现只要是调用createFromCurves形成AcDbRegion,再用上面的形式删除生成的区域,还是有内存泄漏,是不是createFromCurves有问题呢?
我用的R14.arx202.用它的例子POLYSAMP,我将其polyedit函数改造了一下,在thickenPoly函数内,
循环1000,对3d实体的操作都取消,用炸开的曲线生成region,再将炸开的曲线和region都删除。这时就会有内存泄漏。我用2000的内存监视器看一般要耗2-3M内存。但将createFromCurves函数去掉。即不生成AcDbRegion,就不会有内存泄漏。所以,我不知是createFromCurves的问题还是delete region时的问题。
哪位高手遇到过这种问题吗?很急啊。
发表于 2003-8-1 13:04:54 | 显示全部楼层
Re: [求助]:createFromCurves是不是有内存泄漏?!
最初由 catwang_G 发布
[B]我发现在用explode函数炸开后,删除对象时,若这样删除:
delete  lines;
就会有内存泄漏,但这样删除:
delete (AcRxObject... [/B]
createFromCurves是涉及到了内存的分配,你需要小心的使用.
以前有讨论的,看看下面的帖子
http://www.xdcad.net/forum/showt ... d=289139#post289139
 楼主| 发表于 2003-8-1 13:27:47 | 显示全部楼层
将DLLIMPEXP void  polyeditCommand()中一段改为
                else if (strcmp(option, "Thicken") == 0) {
            if (!ent->isKindOf(AsdkPoly::desc())) {
                ads_printf("\nNot Applicable");
                continue;
            eMode = PolyEdit::kThicken;
            AOK(thickenPoly(poly));
         //   solid = AcDb3dSolid::cast(ent);
         //   assert(solid != NULL);
         //   poly = NULL;
         //   solid->draw();
将
static Acad::ErrorStatus
thickenPoly(AsdkPoly* poly)
    Acad::ErrorStatus es = Acad::eOk;
        for(int i=0;i<1000;i++)//
                int i;
                AcDbVoidPtrArray lines;
                AcDbVoidPtrArray regions;
                // Explode to a set of lines
                if ((es = poly->explode(lines)) != Acad::eOk) {
                        for (i = 0; i < lines.length(); i++) {
                        for (i = 0; i < regions.length(); i++) {
                                delete (AcRxObject*)regions;
                        return es;
                //AcDbRegion*
                // Create a region from the set of lines.
                if ((es = AcDbRegion::createFromCurves(lines, regions)) != Acad::eOk) {
                        return es;
                assert(regions.length() == 1);
                AcDbRegion* region = AcDbRegion::cast((AcRxObject*)regions[0]);
                assert(region != NULL);
                // Extrude the region to create a solid.
/*                double height;
                if ((es = poly->getDistAtParam(6.28318530717958647692, height))
                        != Acad::eOk)
                                delete lines;//(AcRxObject*)
                        return es;
                height *= 0.25;
/*                AcDb3dSolid* solid = new AcDb3dSolid;
                if ((es = solid->extrude(region, height, 0.0)) != Acad::eOk) {
                        delete solid;
                        return es;
                // Save up the data to flatten the solid.
                savedCenter     = poly->center();
                savedStartPoint = poly->startPoint();
                savedNumSides   = poly->numSides();
                savedNormal     = poly->normal();
                // Copy the poly name
                strcpy(savedName, poly->name());
                // Now we have a solid. Change the entity to be this solid
                if ((es = solid->setPropertiesFrom(poly)) != Acad::eOk) {
                        delete solid;
                        return es;
                ent = poly;
                if ((es = ent->upgradeOpen()) != Acad::eOk) {
                        delete solid;
                        return es;
                es = replaceEntity(ent, solid);
                if ((es != Acad::eOk) && (es != Acad::eObjectToBeDeleted)) {
                        ent->downgradeOpen();
                        delete solid;
                        return es;
                es = ent->downgradeOpen();
                        delete (AcRxObject*)lines;//
    return es;
这样有内存泄漏,应该不存在上个贴子说的问题。
修改的代码是arx202里的polysmap例子,大家也试试。
真的有内存泄漏啊,我该怎么办?
在arx2002中,我也用了这个方法试了一下,一点问题都没有。
有没有arx202的补丁什么的?
发表于 2014-12-20 00:44:31 | 显示全部楼层
我也遇到这问题
GMT+8, 2026-11-3 07:39 , Processed in 0.521738 second(s), 38 queries , Gzip On.
