查看: 660|回复: 0
[下载]:Autodesk® Express Viewer 4 Beta
发表于 2003-8-6 20:54:51 | 显示全部楼层 |阅读模式
登录/注册后可看大图
What's New[/SIZE]
This release of Autodesk Express Viewer includes the following new features:
[B]Navigation window[/B] – The new Navigation window enables you to view thumbnail images of the sheets contained in the current drawing, navigate to a different sheet by clicking the thumbnail, and view and navigate to bookmarks in the drawing.
Note: Bookmarks are only published by Revit 5.1 at this time.
[B]Properties window[/B] – The new Properties window enables you to view properties for the current sheet or for selected objects that contain extended properties.
Note: The Object tab on the Properties window is not functioning for this Beta release.
[B]Markups[/B] – You can view and hide markups in your DWF file using the right-click menu item Show>Markups.
[B]Hyperlinks[/B] – When you show hyperlinks in the DWF file, the objects containing hyperlinks display in blue, all other geometry changes to grayscale. Using the Options dialog box, you can choose a different color for the hyperlinks and you can set an option to use a single-click to navigate to hyperlinks.
Note: The new Show/Hide Hyperlinks functionality is not supported for this Beta release.
[B]Autodesk Express Viewer API[/B] – The Autodesk Express Viewer control now fires events out to the hosting client application. This means that you can develop more powerful applications that integrate seamlessly with the Autodesk Express Viewer control. Using the Autodesk Express Viewer API you can develop applications that *stay informed* and more easily override or prevent the viewer's default behaviors.
[B]Note: See The Autodesk Express Viewer API for important information about changes to the API. [/B]
http://chinease.533.net/cad/ExpressViewerSetup4beta.exe
http://chinease.533.net/cad/ExpressViewerAPI.chm
8月1日的 beta 版 :D
GMT+8, 2026-11-3 20:19 , Processed in 0.609801 second(s), 32 queries , Gzip On.
