查看: 1815|回复: 14
[LISP程序]:图层控制程序
发表于 2003-8-13 16:34:30 | 显示全部楼层 |阅读模式
不过是别人的,还有些功能我不会用,不过开关图层很好,如按“1”就会打开第一层
发表于 2005-5-21 13:21:45 | 显示全部楼层
我用下试试看
已领礼包: 1261个
发表于 2005-5-21 17:31:09 | 显示全部楼层
是哪位高手开发的?
发表于 2005-5-22 12:41:06 | 显示全部楼层
最初由 gufengyin 发布
[B]是哪位高手开发的? [/B]
  晕ing...看来这位高手开发来完全是给自己用的。强烈建议大家如果自己不会开发的话就不要试用了。这鞋恐怕不合你的脚。
[php]
(DEFUN C:-0  () (setvar "DIMDEC" 1)(princ))
(DEFUN C:-00 () (setvar "DIMDEC" 2)(princ))
(DEFUN C:-000 () (setvar "DIMDEC" 3)(princ))
(defun C:CCD()  (COMMAND "CHAMFER" "D" PAUSE "" "CHAMFER")(PRINC))
(defun C:FR()  (COMMAND "FILLET" "R" PAUSE "FILLET")(PRINC))
(defun C:MCO() (if (not c:MCOPY) (lifeload "a71")) (c:mcopy))
(DEFUN C:UO () (COMMAND "UCS" "O")(princ))
(DEFUN C:UW () (COMMAND "UCS" "W")(princ))
(DEFUN C:UZ () (COMMAND "UCS" "Z")(princ))
(DEFUN C:C0 () (COMMAND "CHAMFER" "D" "0.0" "" "CHAMFER")(princ))
(DEFUN C:C05() (COMMAND "CHAMFER" "D" "0.5" "" "CHAMFER")(princ))
(DEFUN C:C1 () (COMMAND "CHAMFER" "D" "1.0" "" "CHAMFER")(princ))
(DEFUN C:C15() (COMMAND "CHAMFER" "D" "1.5" "" "CHAMFER")(princ))
(DEFUN C:C2 () (COMMAND "CHAMFER" "D" "2.0" "" "CHAMFER")(princ))
(DEFUN C:C25() (COMMAND "CHAMFER" "D" "2.5" "" "CHAMFER")(princ))
(DEFUN C:C3 () (COMMAND "CHAMFER" "D" "3.0" "" "CHAMFER")(princ))
(DEFUN C:C4 () (COMMAND "CHAMFER" "D" "4.0" "" "CHAMFER")(princ))
(DEFUN C:C5 () (COMMAND "CHAMFER" "D" "5.0" "" "CHAMFER")(princ))
(defun C:Cr()  (COMMAND "CHAMFER" "D" "" PAUSE "CHAMFER")(PRINC))
(DEFUN C:Ff () (COMMAND "FILLET" "R" "0.0"  "FILLET")(princ))
(DEFUN C:F05() (COMMAND "FILLET" "R" "0.5"  "FILLET")(princ))
(DEFUN C:F1 () (COMMAND "FILLET" "R" "1.0"  "FILLET")(princ))
(DEFUN C:F15() (COMMAND "FILLET" "R" "1.5"  "FILLET")(princ))
(DEFUN C:F2 () (COMMAND "FILLET" "R" "2.0"  "FILLET")(princ))
(DEFUN C:F25() (COMMAND "FILLET" "R" "2.5"  "FILLET")(princ))
(DEFUN C:F3 () (COMMAND "FILLET" "R" "3.0"  "FILLET")(princ))
(DEFUN C:F4 () (COMMAND "FILLET" "R" "4.0"  "FILLET")(princ)),
(DEFUN C:F5 () (COMMAND "FILLET" "R" "5.0"  "FILLET")(princ))
(defun c:br1() (command "break" pause "f" pause "@")(princ))
(DEFUN C:B2 () (COMMAND "INSERT" "B2.DWG" pause "" "" "")(princ))
(DEFUN C:dm10 () (COMMAND "INSERT" "dm10.DWG" pause "" "" "")(princ))
(DEFUN C:um10 () (COMMAND "INSERT" "um10.DWG" pause "" "" "")(princ))
(DEFUN C:EC15 () (COMMAND "INSERT" "ENDCUT015.DWG" pause "" "" "")(princ))
(DEFUN C:EC17 () (COMMAND "INSERT" "ENDCUT017.DWG" pause "" "" "")(princ))
(DEFUN C:EC20 () (COMMAND "INSERT" "ENDCUT020.DWG" pause "" "" "")(princ))
(DEFUN C:EC25 () (COMMAND "INSERT" "ENDCUT025.DWG" pause "" "" "")(princ))
(DEFUN C:K () (COMMAND ".LAYER" "t" "*" "u" "*" "ON" "*" "")(princ))
(DEFUN C:Ks () (COMMAND ".LAYER" "ON" PAUSE "")(princ))
(DEFUN C:K1 () (COMMAND ".LAYER" "ON" "1" "")(princ))
(DEFUN C:K2 () (COMMAND ".LAYER" "ON" "2" "")(princ))
(DEFUN C:K3 () (COMMAND ".LAYER" "ON" "3" "")(princ))
(DEFUN C:K4 () (COMMAND ".LAYER" "ON" "4" "")(princ))
(DEFUN C:K5 () (COMMAND ".LAYER" "ON" "5" "")(princ))
(DEFUN C:K6 () (COMMAND ".LAYER" "ON" "6" "")(princ))
(DEFUN C:K7 () (COMMAND ".LAYER" "ON" "7" "")(princ))
(DEFUN C:K8 () (COMMAND ".LAYER" "ON" "8" "")(princ))
(DEFUN C:K9 () (COMMAND ".LAYER" "ON" "9" "")(princ))
(DEFUN C:K0 () (COMMAND ".LAYER" "ON" "10" "")(princ))
(DEFUN C:K11() (COMMAND ".LAYER" "ON" "11" "")(princ))
(DEFUN C:K12 () (COMMAND ".LAYER" "ON" "12" "")(princ))
(DEFUN C:K13 () (COMMAND ".LAYER" "ON" "13" "")(princ))
(DEFUN C:K14 () (COMMAND ".LAYER" "ON" "14" "")(princ))
(DEFUN C:K15 () (COMMAND ".LAYER" "ON" "15" "")(princ))
(DEFUN C:KL () (COMMAND ".LAYER" "ON" "Lo" "")(princ))
(DEFUN C:G () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "0" "OFF" "*" "" "ON" "0" "") (princ))
(DEFUN C:G1 () (COMMAND ".LAYER" "Off" "1" "")(princ))
(DEFUN C:G2 () (COMMAND ".LAYER" "Off" "2" "")(princ))
(DEFUN C:G3 () (COMMAND ".LAYER" "Off" "3" "")(princ))
(DEFUN C:G4 () (COMMAND ".LAYER" "Off" "4" "")(princ))
(DEFUN C:G5 () (COMMAND ".LAYER" "Off" "5" "")(princ))
(DEFUN C:G6 () (COMMAND ".LAYER" "Off" "6" "")(princ))
(DEFUN C:G7 () (COMMAND ".LAYER" "Off" "7" "")(princ))
(DEFUN C:G8 () (COMMAND ".LAYER" "Off" "8" "")(princ))
(DEFUN C:G9 () (COMMAND ".LAYER" "Off" "9" "")(princ))
(DEFUN C:G10 () (COMMAND ".LAYER" "Off" "10" "")(princ))
(DEFUN C:G11 () (COMMAND ".LAYER" "Off" "11" "")(princ))
(DEFUN C:G12 () (COMMAND ".LAYER" "Off" "12" "")(princ))
(DEFUN C:G13 () (COMMAND ".LAYER" "Off" "13" "")(princ))
(DEFUN C:G14 () (COMMAND ".LAYER" "Off" "14" "")(princ))
(DEFUN C:G15 () (COMMAND ".LAYER" "Off" "15" "")(princ))
(DEFUN C:GL () (COMMAND ".LAYER" "Off" "Lo" "")(princ))
(dEFUN C:Kd () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "1" "OFF" "*" "" "ON" "1,2,3,9,9A,9B,9C,11,13,15,CU,sv,std,TEXT,wc" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:Ku () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "4" "OFF" "*" "" "ON" "4,5,6,7,8,10,10A,10B,10C,12,14,,sv,t_text,wt" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:KDd () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "ON" "D1,D2,D3,DIM1,DIM2,DIM3" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:lo () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "LO" "OFF" "*" "" "ON" "LO,LOB,LOS,cu" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:KLb () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "LOb" "OFF" "*" "" "ON" "LOB," "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:KLs () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "LOs" "OFF" "*" "" "ON" "LOS," "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:Kp () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "part" "OFF" "*" "" "ON" "part," "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:CU () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "CU" "OFF" "*" "" "ON" "CU" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:Kt () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "text" "OFF" "*" "" "ON" "text" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:Gt () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "0" "OFF" "text" "" "ON" "0,Defpoints" "")(princ))
(DEFUN C:Km () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "d2" "OFF" "*" "" "ON" " d1,d2,d3,dim1,dim2,dim3" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:Gm () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "0" "OFF" " d1,d2,d3,dim1,dim2,dim3" "" "ON" "0,Defpoints" "")(princ))
(DEFUN C:DY ()(COMMAND ".lengthen" "dy")(princ))
(DEFUN C:PURA () (setvar "cmdecho" 0)(repeat 3 (COMMAND ".purge" "a" "" "n"))(princ))
(DEFUN C:PURB () (setvar "cmdecho" 0)(repeat 3 (COMMAND ".purge" "B" "" "n"))(princ))
(DEFUN C:1 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "1" "OFF" "*" "" "ON" "1" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:2 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "2" "OFF" "*" "" "ON" "2" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:3 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "3" "OFF" "*" "" "ON" "3" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:4 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "4" "OFF" "*" "" "ON" "4" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:5 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "5" "OFF" "*" "" "ON" "5" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:6 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "6" "OFF" "*" "" "ON" "6" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:7 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "7" "OFF" "*" "" "ON" "7" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:8 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "8" "OFF" "*" "" "ON" "8" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:9 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "9" "OFF" "*" "" "ON" "9" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:0 () (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "10" "OFF" "*" "" "ON" "10" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:11() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "11" "OFF" "*" "" "ON" "11" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:12() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "12" "OFF" "*" "" "ON" "12" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:13() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "13" "OFF" "*" "" "ON" "13" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:14() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "14" "OFF" "*" "" "ON" "14" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:15() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "15" "OFF" "*" "" "ON" "15" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:tt() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "tet" "OFF" "*" "" "ON" "text" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:22() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "d1b1" "OFF" "*" "" "ON" "d1b1,d2b1,d3b1,d4b1,d5b1,d6b1,d7b1" "")(SETVAR "CMDECHO" 1)(princ))
(DEFUN C:23() (SETVAR "CMDECHO" 0)(COMMAND ".LAYER" "SET" "u1b1" "OFF" "*" "" "ON" "u1b1,u2b1,u3b1,u4b1,u5b1,u6b1,u7b1" "")(SETVAR "CMDECHO" 1)(princ))
(defun C:r90() (command ".rotate" pause "" "@" "90")(princ))
(defun c:cc()
  (setq ob(ssget))
  (setq p1(getpoint "base point:"))
  (command "copy" ob "" "m" p1))
(defun C:ZI ()  (command "zoom" "0.8x"))
(defun C:ZO ()  (command "zoom" "1.2x"))
(defun C:ZZ ()  (command "zoom" "e" "zoom" "0.8x"))
(defun C:ZZZ () (command "zoom" "e" "zoom" "0.6x"))
(defun C:ZZZZ ()(command "zoom" "e" "zoom" "0.4x"))
(defun C:ZZZZZ ()(command "zoom" "e" "zoom" "0.2x"))
(defun C:ZZZZZZ ()(command "zoom" "e" "zoom" "0.1x"))
(defun C:ZZZZZZZ ()(command "zoom" "e" "zoom" "0.05x"))
[/php]
发表于 2005-5-22 14:50:03 | 显示全部楼层
果然是高手!
发表于 2005-5-22 16:09:25 | 显示全部楼层
果然是“量身定做”。
程序的目的就是要能提高工作效率,虽然本程序不适合偶,但其做法值得学习和推荐。
每个人可以根据自己的实际需要,“定做”自己的简化程序命令,积累成多,发挥作用。
发表于 2005-5-22 21:02:47 | 显示全部楼层
敢贴敢当,真男人也,学习中。。。
发表于 2006-1-31 15:49:43 | 显示全部楼层
这哥们的电脑别人没法用,大家慎重下载
发表于 2006-2-6 09:44:59 | 显示全部楼层
厉害,大开眼界!
发表于 2006-2-15 09:11:48 | 显示全部楼层
下载不了,为什么呢?
 楼主| 发表于 2006-2-21 21:14:52 | 显示全部楼层
可以下载啊,怎么下载不了呢??!!!
发表于 2006-2-21 22:05:15 | 显示全部楼层
真是量身定做啊,恐怕多数人都没法用哦!
发表于 2006-2-22 07:56:29 | 显示全部楼层
不建议大家下载,但是可以参考其使用方法
发表于 2006-2-22 15:38:31 | 显示全部楼层
这玩意怎么用?请楼主介绍一下。
发表于 2009-6-28 17:22:53 | 显示全部楼层
可以参考一下,简化自己的命令。
GMT+8, 2026-11-7 02:32 , Processed in 0.556546 second(s), 61 queries , Gzip On.
