查看: 1667|回复: 12
[分享]:是否有人需要以下的软件?
发表于 2002-6-17 02:13:33 | 显示全部楼层 |阅读模式
有人需要就上传(附license)
烦请提供较快速的ftp,上传到台湾的ftp对大家来说太慢了
Bentley_Enterprise_Navigator_v4.02.01.10
Bentley_Dynamic_Animator_v4.02.01.10
(安装需求: Bentley_Enterprise_Navigator_v4.02.01.10)
(Bentley_Schedule_Simulator_v4.02.01.10
发表于 2002-6-17 02:58:57 | 显示全部楼层
huang兄,我用PM给你发过去了一个Ftp, 试试如何? 呵呵,只是这三个软件我不知道是作啥的呀,能介绍一下吗?
 楼主| 发表于 2002-6-17 03:23:18 | 显示全部楼层
风过花零兄
请见pm
这3个软件我不懂,好象和碰撞检查有关,也请你研究研究,做个教学说明
或者方言帮得上忙
Description for Bentley Schedule Simulator
Bentley Schedule Simulator enables users to "virtually" build a facility according to a construction schedule. Modifications to the schedule can be easily reflected in the simulation, and users can also choose to play multiple scenarios-- such as early vs. late start or actual vs. planned progress--for consideration.
Description for Bentley Enterprise Navigator
Bentley Enterprise Navigator can increase the value of your engineering and enterprise data by making it visible to all project participants. It is an ideal tool for real-time, interactive, intelligent 3D model review for the Plant and Building industries. It provides features for visualizing and querying both graphical and non-graphical information from many industry-standard applications.
NEW! Bentley Enterprise Navigator now allows you to control the behaviour of the product from an MS-DOS Command Prompt. See the readme delivered with the product for complete details.
Description for Bentley Dynamic Animator
Bentley Dynamic Animator takes static models generated in the design phase of a project, and applies accurate motion to the 3D objects. Animations can easily be recorded, replayed, and modified as required, and can be output to video file for presentation or training purposes. Automated clash detection highlights proposed movement conflicts, enabling early problem resolution.
NEW! Bentley Dynamic Animator now enables you to link 3D models to schedules, thus enabling you to "virtually" build a facility according to a construction schedule. Modifications to the schedule can be easily reflected in the simulation. By further combining your schedule simulation with animations, only now can you create a true representation of what is happening on your project site.
发表于 2002-6-17 03:43:57 | 显示全部楼层
huang兄请看短消息, 这几个软件可能先放些时候再研究喽, 呵呵
 楼主| 发表于 2002-6-17 03:57:11 | 显示全部楼层
风过花零兄
请见pm, ^_^
发表于 2002-6-17 10:16:09 | 显示全部楼层
是个3D模型浏览软件,还包括一些丰富的功能。(没具体研究)
是个吊装模拟软件,可以用于设备进场安装的施工仿真模拟。
工程施工进度的可视化管理。与P3和Project可以挂接,实现项目的可视化管理。(这个我上星期花了很多时间研究,挺好玩的)
 楼主| 发表于 2002-6-17 11:15:56 | 显示全部楼层
软件正在上传中,完成后会公布link
还请你多多指导大家
发表于 2002-6-18 18:53:11 | 显示全部楼层
谢谢odinhuang了,等。
 楼主| 发表于 2002-6-19 00:34:08 | 显示全部楼层
to binliu
http://www.xdcad.net/forum/showthread.php?s=&threadid=8085
发表于 2002-6-19 16:21:32 | 显示全部楼层
信息的可视化增值
Bentley Enterprise Navigator能将你任形式的数据可视化,任何项目参予者都可以看到,以增加其价值。它是一个实时、交互察看3D模式的理想工具。它是提供了直接察看及查询来自许多业内标准的应用程序提供的图形及其非图形信息的能力。
利用现有应用程序的数据
Bentley Enterprise Navigator提供了强大的察看3D模型的数据的能力,这些3D模型的数据可以来自各多种计算机辅助设计及工厂设计软件系统。这意味着你可以与承包商,供应商,以及其它外来资源之间互相交换文件,而不需经过文件格式的转换或是担心数据传递问题。任何3D对象的格式,在Bentley Enterprise Navigator的环境中,都独立于其原始建立的应用程序。利用面向对象技术,你可以在Enterprise Navigator中,集成来自不同的应用程序的数据内容。
在实施之前发现问题
Enterprise Navigator是有效率的工程设计决策支持系统,因为它可以辅助你提前检查出设计问题。因为它可以提供各个设计阶段更明确沟通,以及畅通的途径访问当时的信息。Enterprise Navigator也可以提升你设计决策的质量。
在你的设计中自由的移动
在Enterprise Navigator的环境中,你可以轻易的操控3D对象的视图模式。移动视点在模型中的位置,并且从各个专业的角度来察看整个设计。向前,向后,向左,向右,上或下等各个方向移动,平视,聚焦于某个组件并环绕显示,也可以用特写镜头从远处察看。移动,旋转,或者在顶视或立面视图窗口中利用光标拖动视锥放大缩小视图范围。通过指定近的或远的视图范围边界,Bentley Enterprise Navigator允许你自己定义在模型中的可见范围。可以对某一部分在动态显示模式下移动视点,以察看一般被隐藏的细节。16个独立的视图窗口来都可以支持正交以及用户定义的透视图模式,这些功能使你可以更容易的,高效地交互对设计进行察看。
定义一个漫游路线
另外,Enterprise Navigator使你可以沿着预先定义的路径动态漫游(例如沿着管线的中心线)并可以观察设计的细节。这个特性允许你通过对模型向导般的漫游,展示施工现场中的一个特别区域。
显示信息
为任何组件或是对象组添加注释,提醒其它人员存在的问题或特定的详细情况。只要点选任一组件,任何相关的信息就会动态的以文本被放置。该文本独自地被显示于你窗口的角落,并且当你在设计文件中随意移动时,持续可见。而各个尺寸也可轻易的在点选起始点及终止点后自动标注。
传送信息
Bentley Enterprise Navigator的功能要远远大于单纯在屏幕上显示模型。你也可以直接打印所看到的模型视图,包括注释和尺寸标注。Bentley Enterprise Navigator可使用Windows NT/2000打印,以及支持任何兼容的打印机。
对整个工程的查询
你可以查询任何单个的对象以及它属性,或是同时在全部设计文件中查询任一属性值。也可以使用诸如:查找相同管号或指定管径范围内的全部管件等高级查询功能。可以对来自任何其他应用程序的属性进行查询。不需要任何编程知识,Enterprise Navigator 的用户可以为每个对象定义新的属性。这些对象通过一个数据查询的连结可以连接到另一个数据源,以获取相关的数据值,数据源可以是数据库,电子表格文件,文本文件或是互联网资源。你甚至可以在3D模式中使用其它应用程序,察看链接在这些应用程序中的数据,包括扫描图片以及录制影像。Bentley Enterprise Navigator也允许你在系统中交互地使用材料采购以及项目进度的相关数据库,所以你可以监控项目施工、维护的进度表,以及维护其它更多的项目控制的内容。
显示组件组
更多的显示操作选项:选择任何你想要察看专业的内容,包括管线,结构,设备,HVAC或是电器。可以在所选择的窗口中显示组件组,并自动的放大显示该组件组。
•以一个通用的数据值查询你所需的全部数据,例如管号或是等级。你可以选择在画面中只看到这些组件组,或者是以不同颜色高亮显示该组件组。
•将最后看到的组件组储存起来。为选择的组件组指定的颜色及显示模式将会覆盖群组中单个对象的属性。
一个真正可升级的解决方案
Bentley Enterprise Navigator可以用在,从小型的、单一用户的项目,到大型的、多用户、多重专业的项目上。Enterprise Navigator广泛适用于现有的各种软硬件平台上,这将使你并面对各种特殊项目的需求。Enterprise Navigator支持多处理器系统,可提供最大的效能以处理极端庞大的数据量。Bentley Enterprise Navigator与奔特力集成系列(Bentley® Integration Tools™)的工具兼容,也是奔特力整个设计系列(PlantSpace® Integration Series)应用程序的一部份。这些应用程序拥有先进的技术,可以集成几乎全部工厂设计的的电子信息。Intergation Series支持数据的远程传递,来自自各种数据库以及计算机辅助设计系统中的信息,无论存储在不同位置,还是不同的网络环境中时,都可以无缝的集成为一个完整的解决方案。
Bentley Dynamic Animator ―― 奔特力Schedule Simulator是业界中第一个真正实现可视化吊装模拟的商用软件,提高项目计划与项目进度控制的协调与沟通能力。这个4D系统,在3D模式中加入了时间坐标,提供了一个简单易用,基于工程进度信息的可视化的吊装模拟的环境。奔特力Schedule Simulator有集成计划进度,3D视图模式,以及按实际时间依据计划的时间数据,以可视化的方式模拟工程的能力。
奔特力Schedule Simulator将工程的详细设计阶段建立3D模型和项目控制的进度/计划结合在一起。软件与通用的计划/进度工具软件,数据库,以及3D模型的应用程序紧密结合共同使用。它提供的真实世界的项目场景使人印象深刻,在3D设计或计划进度变更时,同时更新模拟的动画。在动态的3D计算机图形环境中,你可以“播放”进度,观看呈现在你眼前的虚拟和连续的情况。现在,所有参与工程设计,施工,工厂运转,以及维护检修 - 包括成本/进度控制工程师,施工协调,以及项目管理者――都可以通过在一个计算机的项目模拟中清楚的看到计划的实际情况。
奔特力动画与进度模拟
线性平行的工作流程
项目快速进行,工程设计同时进行,这已经成为一种惯例,奔特力Schedule Simulator满足你对于贯穿整个项目生命周期中,紧密地将设计、计划和施工完成量结合并协同一致的需求。软件帮助你克服传统项目管理的挑战:计项目可视化的困难,计划进度表在使用中的种种限制,以及无法精确的比对实际进度与计划进度上的差距。对于传统的项目管理模式,详细设计与进度计划是同时但又各自独立进行的。使用奔特力 Schedule Simulator, 现在你可以将设计专业和施工计划专业结合起来,加快施工进度,缩短从概念设计到项目完成的时间。项目进度计划人可以利用高精度,最新版的3D模型――代替手绘的图纸或是等比的塑料模型――来对施工进度计划进行评估。利用设计流程中早期的详细设计数据,可让进度计划人更好地规划和控制进度实施的完整脉络。这样的效果将加快施工进度,并且项目周期,使公司的的效益大幅增长。
大量数据的集成
奔特力Schedule Simulator在Bentley® Enterprise Navigator™环境下对计划进度表以图形的方式进行模拟。这个软件所使用Primavera Project Planner® (P3®)以及Microsoft Project等软件编制的计划进度数据。你可以使用一系列的商业化的工厂设计/工程设计软件系统中模型数据,包含来自PlantSpace Design Series,Intergraph的PDS,以及其它的一些应用程序。这个PlantSpace Design Series对象的数据结构大大丰富了对其他现有应用程序数据的综合应用能力。
系统效能
•项目的范围可以扩大到从在项目可研以及概念设计阶段
•开始阶段就将施工、试车或开车的进展方法综合考虑
•使施工和试运行人员在概念设计阶段就能介入
•在订购贵重物资之前进行完整的设计、施工和试运行结果的调查
•改进设计以及采购的策略
•将重点放在预制、预装配以及实时的采购
•顺畅的材料的管理与控制
•对比选择
图形化模拟
使用Schedule Simulator,将动画与可视化模拟作为日常工具,将提高经济效益。你可以利用工厂模型中的实体,包括结构,管道,以及设备,使用施工与试运行进度控制点来生成动画。软件系统将基于进度表的时间顺序组合成一个动画系列。奔特力 Schedule Simulator使用图像来虚拟现实的施工和试运行场景,以及相关实际的状态。颜色号所表达的对象信息,与进度的过程阶段相关,或是依据其它你所定义的规则。例如,按照进度在下星期整个钢结构竖起,并且在施工现场并未完全交付完工阶段,以红色高亮显示处于该阶段的钢结构部分。
数据的连结
奔特力Schedule Simulator使用Open Database Connectivity(ODBC)技术建立模型和编制计划。JSpace®ODBC 连结模块――PlantSpace®Intergation工具中的一种,使用一个完善的ODBC驱动程序从背后的数据库中取得数据。然后经过一系列的处理以Jspace对象的格式输入数据。用户也可以选择通过动态的OLE2――Automation利用Primavera连结到P3.
 楼主| 发表于 2002-6-20 09:58:38 | 显示全部楼层
谢谢pipi的分享,消化中……..
发表于 2002-6-20 12:34:47 | 显示全部楼层
谢谢odinhuang [。
谢谢pipi。
抓下。
发表于 2003-6-14 11:09:01 | 显示全部楼层
求Primavera Project Planner下载!!
如果有的人请和我联系,谢谢QQ12124123
或者帮我Up到这
ftp://canking.dns0755.net
user:up
pass:up
GMT+8, 2026-11-3 02:12 , Processed in 0.510880 second(s), 56 queries , Gzip On.
