查看: 1102|回复: 2
[LISP程序]:Scale with different X,Y,Z factor.
发表于 2003-8-22 09:51:55 | 显示全部楼层 |阅读模式
(defun c:test ()
  (setq ent (car (entsel "\nSelect Block to reScale:")))
  (setq x (getreal "Xscale factor")
       y (getreal "Yscale factor")
       z (getreal "Zscale factor"))
  (setq obj (vlax-ename->vla-object ent))
  (vla-put-xscalefactor obj x)
  (vla-put-yscalefactor obj y)
  (vla-put-zscalefactor obj z)
发表于 2003-8-22 10:58:42 | 显示全部楼层
我觉得这几句应加个冒号,要不看着很便扭。
setq x (getreal "Xscale factor:")
y (getreal "Yscale factor:")
z (getreal "Zscale factor:"))
另外vlax-ename->vla-object  、vla-put-xscalefactor 、vla-put-yscalefactor 、vla-put-zscalefactor 几个函数是不是不适于ACAD2000,我在2000下的vlisp编辑器里,上述几个函数不被承认!
 楼主| 发表于 2003-8-22 11:19:55 | 显示全部楼层
(VL-LOAD-COM)
GMT+8, 2026-11-3 20:16 , Processed in 0.442941 second(s), 36 queries , Gzip On.
