查看: 1116|回复: 6
[其他]:[參考]圖庫管理
发表于 2003-8-25 19:38:04 | 显示全部楼层 |阅读模式
下面這個程序我發了10天的時間寫的(存在很多錯誤),最近公司比較忙,等有空在來理它.
基本功能應該有了.呵呵.
 楼主| 发表于 2003-8-25 19:39:08 | 显示全部楼层
jpg
jpg
 楼主| 发表于 2003-8-25 19:45:26 | 显示全部楼层
代碼
;;;功能:圖庫管理
;;;BY Spring
;;;08/20-03
;;;_______________________________________________________
(defun ICON_NA (/ count iconname_list)
  (setq count 0)
  (while (/= count 16)
    (setq iconname_list (nth count icon_list))
    (princ "\n")
    (princ iconname_list)
    (setq count (1+ count))
(defun PREV_LOUN ()
  (if (>= n? 16)
    (mode_tile "prev" 0)
    (mode_tile "prev" 1)
  (if (>= n? 32)
    (mode_tile "next" 1)
    (mode_tile "next" 0)
  (if (/= n? 0)
    (setq page$%@# (strcat "第 " (itoa (+ (/ n? 16) 1)) " 頁"))
    (setq page$%@# (strcat "第 1 頁"))
  (set_tile "t1" page$%@#)
(defun SHOW (/ n? n?# n??)
  (setq n? 0)
  (while (/= n? 16)
    (setq n?# (nth n? icon_list))
    (setq n? (1+ n?))
    (if        (/= n?# nil)
      (progn
        (setq n?? (itoa n?))
        (start_image n??)
        (FILL_IMAGE 0 0 (DIMX_TILE n??) (DIMY_TILE n??) -2)
        (END_IMAGE)
        (START_IMAGE n??)
        (SLIDE_IMAGE 0 0 (DIMX_TILE n??) (DIMY_TILE n??) n?#)
        (END_IMAGE)
      (progn
        (start_image n??)
        (END_IMAGE)
        (START_IMAGE n??)
        (SLIDE_IMAGE 0 0 (DIMX_TILE n??) (DIMY_TILE n??) "")
        (END_IMAGE)
(defun SHOW_$# (/ icon_li icon_list@# n?$ icon_n? count)
  (setq icon_list@ (reverse icon_list))
  (setq icon_list@# icon_list)
  (setq icon_list nil)
  (setq n?$ n?)
  (while (< n?$ (+ n? 16))
    (setq icon_n?$ (nth n?$ icon_list@#))
    (setq n?$ (+ n?$ 1))
    (if        (= icon_n?$ nil)
      (progn
        (setq icon_n?$ (strcat "icon" (itoa n?$)))
        (setq icon_list@ (cons icon_n?$ icon_list@))
    (setq icon_list (cons icon_n?$ icon_list))
  (setq icon_list (reverse icon_list))
  (if (/= icon_list@ nil)
    (progn
      (setq fi "cc")
      (if (findfile (strcat fi ".ini"))
        (progn
          (setq fil (findfile (strcat fi ".ini")))
          (setq count 0)
          (setq pe (open fil "W"))
          (while (< count (length icon_list@))
            (setq ddf (nth count (reverse icon_list@)))
            (if        (/= ddf nil)
              (write-line ddf pe)
  (close pe)
(defun LS ()
  (start_list "ls" 3)
  (mapcar (quote add_list) lib_list)
  (end_list)
(defun ICON_LS (/ fi fil fel pe en1 en2 hcount@# nn$# count$%)
  (setq fi "library")
    (progn
      (setq fel nil)
      (setq pe (open fil "r"))
      (setq en1 (READ-LINE pe))
      (close pe)
      (setq fil (findfile (strcat en1 ".ini")))
      ;;(setq fil (findfile (strcat (nth (atoi value$) lib_list) ".ini")))
      (setq en2 T)
      (while (/= en2 nil)
        (setq en2 (READ-LINE pe))
        (setq fel (cons en2 fel))
      (close pe)
      (setq icon_list (reverse (cdr fel)))
(defun LIB_LS (/ fi fil fel pe en)
  (setq fi "library")
    (progn
      (setq fel nil)
      (setq en T)
      (while (/= en nil)
        (setq en (read-line pe))
        (setq fel (cons en fel))
      (close pe)
      (setq lib_list (reverse (cdr fel)))
(defun LIB_WBLOCK (/              ss         sp?            s?l
                   library_path                 p1            wblockname?#
                   spcircle_dd                 ss1            pt1
                   pt2
  (setq ss (ssget))
  (if ss
    (progn
      (command "_.UNDO" "Group")
      (command "_.ERASE" "ALL" "R" ss "")
      (command "_.ZOOM" "E")
      (command "_.ZOOM" "0.9X")
      (command "_.REGEN")
      (setq sp? (findfile "library.ini"))
      (setq s?l (strlen sp?))
      (setq library_path (substr sp? 1 (- s?l 11)))
      (setq p1 (getpoint "\nInsert Point"))
      (if (/= n? 0)
        (setq ke$ (itoa (+ (atoi ke$) n?)))
      (setq wblockname?#&$ (strcat (nth 0 lib_list) ke$))
      (setq spcircle_dd (/ (getvar "viewsize") 15))
      (command "_.CIRCLE" p1 spcircle_dd)
      (setq ss1 (ssget "L"))
      (command "_.CHANGE" ss1 "" "P" "Color" "1" "")
      (setq pt1 (polar p1 pi (+ (/ spcircle_dd 2) (/ spcircle_dd 0.9))))
      (setq pt2 (polar p1 0 (+ (/ spcircle_dd 2) (/ spcircle_dd 0.9))))
      (command "_.LINE" pt1 pt2 "")
      (command "_.ROTATE" ss1 "" p1 "45")
      (command "_.MIRROR" ss1 "" p1 "@0,10" "")
      (command "_.MSLIDE" (strcat library_path wblockname?#&$))
      (command "_.UNDO" "End")
      (command "_.UNDO" "1")
      (command "_.WBLOCK"
               P1
               ss
      (WRITE_ICON)
      (command "_.UNDO" "3")
(defun LIB_CHS (/           ss              sp?         s?l            library_path
                p1           wblockname?#                 spcircle_dd
                ss1           pt1              pt2
  (setq ss (ssget))
  (if ss
    (progn
      (command "_.REGEN")
      (if (/= n? 0)
      (setq wblockname?# (strcat (nth 0 lib_list) ke$))
      (command "_.MSLIDE"
               (strcat library_path wblockname?#)
      (command "_.WBLOCK"
               "Y"
               P1
               ss
      (WRITE_ICON)
(defun WRITE_ICON (/              fi         icon_number
                   icon_name  new_icon_list            fil
                   pe              count         qwe            ddfr
  (setq fi "cc")
    (progn
      (if (= n? 16)
        (progn
          (setq icon_number (- (atoi ke$) 17))
        (setq icon_number (- (atoi ke$) 1))
      (if (= n? 32)
        (progn
          (setq icon_number (- (atoi ke$) 33))
      (setq icon_name (nth icon_number icon_list))
      (setq new_icon_list (subst wblockname?#&$ icon_name icon_list))
      (setq pe (open fil "w"))
      (setq count 0)
      (setq qwe (length new_icon_list))
      (while (< count qwe)
        (setq ddfr (nth count new_icon_list))
        (if (/= ddfr nil)
          (write-line ddfr pe)
  (close pe)
(defun WRITE_DEL (/            fi              ic        wblockname?#
                  new_icon_list              fil        pe          count
                  qwe            ddfr
  (setq fi "cc")
    (progn
      (setq ic (strcat "icon" ke$))
      (setq new_icon_list (subst ic wblockname?# icon_list))
      (setq count 0)
        (if (/= ddfr nil)
  (close pe)
(defun LIB_INS (/ p1 icon_number icon_name sp? s?l library_path ss)
  (while (setq p1 (getpoint "\nInsert Point"))
    (if        (/= n? 0)
    (command "_.INSERT"
             (strcat library_path icon_name)
             p1
    (setq ss (ssget "L"))
    (if        ss
      (progn
        (command "_.EXPLODE" ss)
        (command "_.PURGE" "Blocks" "" "N")
(defun LIB_DEL (/           sp?              s?l         library_path
                icon_number              icon_name         fi            ic
                new_icon_lis              fil         pe            count
                qwe           ddfr
  (if (/= n? 0)
  (setq fi "cc")
    (progn
      (setq new_icon_list (subst ic icon_name icon_list))
      (setq count 0)
        (if (/= ddfr nil)
  (close pe)
  (if (/= ke$ nil)
    (progn
      (vl-file-delete (strcat library_path icon_name ".dwg"))
      (vl-file-delete (strcat library_path icon_name ".sld"))
(defun LIB_ZOOM        (/ icon_number icon_name dli)
  (if (/= icon_list nil)
    (progn
      (if (/= n? 0)
  (setq dli (load_dialog "library.dcl"))
  (if (null (new_dialog "zoom" dli))
    (exit)
  (start_image "lib_zoom")
  (fill_image
    0
    0
    (dimx_tile "lib_zoom")
    (dimy_tile "lib_zoom")
    -2
  (end_image)
  (slide_image
    0
    0
    icon_name
  (end_image)
  (start_dialog)
  (unload_dialog dli)
(defun LIB_TYPE        (/ ke icon_number icon_name)
  (setq key ke$)
  (if (/= n? 0)
    (setq key (itoa (+ (atoi key) n?)))
  (setq icon_number? (- (atoi key) 1))
  (setq icon_name? (nth icon_number? icon_list))
  (if (= n? 0)
    (setq ic (strcat "icon" key))
  (if (= n? 16)
    (progn
      (setq key (itoa (- (atoi key) 16)))
      (setq ic (strcat "icon" (itoa (+ (atoi key) 16))))
  (if (= n? 32)
    (progn
      (setq key (itoa (- (atoi key) 32)))
      (setq ic (strcat "icon" (itoa (+ (atoi key) 32))))
  ;;(if (= n? 32)
  ;;(setq ke$ (itoa (- (atoi ke$) 32)))
  ;;(if (= n? 48)
  ;;(setq ke$ (itoa (- (atoi ke$) 48)))
  ;;(if (= n? 64)
  ;;(setq ke$ (itoa (- (atoi ke$) 64)))
  ;;(if (= n? 80)
  ;;(setq ke$ (itoa (- (atoi ke$) 80)))
  ;;(if (= n? 96)
  ;;(setq ke$ (itoa (- (atoi ke$) 96)))
  ;;(if (= n? 112)
  ;;(setq ke$ (itoa (- (atoi ke$) 112)))
  ;;(if (= n? 128)
  ;;(setq ke$ (itoa (- (atoi ke$) 128)))
  ;;(if (= n? 144)
  ;;(setq ke$ (itoa (- (atoi ke$) 144)))
  (if (= icon_name? ic)
    (action_tile key "(done_dialog 4)")
(defun NUBMER%%@ ()
  (setq n? 0)
(defun c:library (/ dcl_id what_next)
  (setvar "MODEMACRO" "***SPRING***")
  (setq cm (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq dcl_id (load_dialog "library.dcl"))
  (setq what_next 7)
  (while (> what_next 2)
    (if        (null (new_dialog "library" dcl_id))
      (exit)
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "cancel" "(done_dialog 0)")
    (if        (= value$ nil)
      (setq value$ "0")
    (NUBMER%%@)
    (LIB_LS)
    (ICON_LS)
    (LS)
    (SHOW)
    (PREV_LOUN)
    (set_tile "t2" "Email: hch-1983@163.com")
    (action_tile "ls" "(setq value$ $value)")
    (action_tile "1" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "2" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "3" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "4" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "5" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "6" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "7" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "8" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "9" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "10" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "11" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "12" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "13" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "14" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "15" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "16" "(setq ke$ $key)(LIB_TYPE)")
    (action_tile "zom" "(done_dialog 3)")
    (action_tile "ins" "(done_dialog 5)")
    (action_tile "ch" "(done_dialog 6)")
    (action_tile "del" "(done_dialog 7)")
    (action_tile
      "next"
      "(setq n? (+ n? 16))(SHOW_$#)(SHOW)(ICON_LS)(PREV_LOUN)"
    (action_tile
      "prev"
      "(setq n? (- n? 16))(SHOW_$#)(SHOW)(ICON_LS)(PREV_LOUN)"
    (NUBMER%%@)
    (setq what_next (start_dialog))
    (cond
      ((= what_next 4)
       (LIB_WBLOCK)
      ((= what_next 3)
       (LIB_ZOOM)
      ((= what_next 5)
       (LIB_INS)
      ((= what_next 6)
       (LIB_CHS)
      ((= what_next 7)
       (LIB_DEL)
      ((= what_next 0)
       (prompt "\n***EXIT***")
  (unload_dialog dcl_id)
  (setvar "cmdecho" cm)
  (princ)
(princ "\n     Type: library to run Program")
;;;上面的程序還存在很多問題,最近比較忙,等有空在把後面的.......
已领礼包: 488个
发表于 2003-8-25 21:06:27 | 显示全部楼层
可以用一下xd-api,或doslib把幻灯合成库.晓东api对幻灯处理很方便的.
发表于 2003-8-28 12:00:40 | 显示全部楼层
用LISP写的功能都差不多,还是习惯于自已写的:
 楼主| 发表于 2003-8-31 09:33:05 | 显示全部楼层
看來你的功能比我的要強大.呵呵!
发表于 2005-12-30 16:09:37 | 显示全部楼层
欢迎试试太阳图库啊!
重复回帖---netbee
GMT+8, 2026-11-6 20:44 , Processed in 0.444204 second(s), 45 queries , Gzip On.
