查看: 728|回复: 1
[求助]:大家
发表于 2003-9-2 15:47:01 | 显示全部楼层 |阅读模式
不好意思,我是个超级菜鸟,别见笑。我为学习arx,先学vc++,为学vc++,先学c++,我编了一个小计算器程序,编译通过,运行时输入y,总是不能继续,请各位大侠给看看。
不胜感激!
(compiler:vc++6.0;op:win2000)
代码如下:
#include <iostream.h>
#include <ctype.h>
void main()
        int result;
        int ContinueWorking();
        do{
                int badOperator=0;
                cout<<"Pick an operator:+,-,*,/\n";
                char operation;
                cin>>operation;
                int firstNumber,secondNumber;
                cout<<"Enter your first number:";
                cin>>firstNumber;
                cout<<"Enter your second number:";
                cin>>secondNumber;
                switch(operation){
                case '+':result=firstNumber+secondNumber;
                        break;
                case '-':result=firstNumber-secondNumber;
                        break;
                case '*':result=firstNumber*secondNumber;
                        break;
                case '/':result=firstNumber/secondNumber;
                        break;
                default:
                        cout<<"You entered a bad operator."<<endl;
                        badOperator=1;
                        break;
                }//switch
                if(badOperator==0)
                        cout<<"The result is " <<result<<"."<<endl;
        }while(ContinueWorking());
//ContinueWorking return 1 if the user presses'y'in response
//to our prompt ,and 0 if the user presses 'n' otherwise
        //ContinueWorking
        char response;
                cout<< "Would you like to do another problem?(Y/N):";
        do{
                cin>>response;
                response=tolower(response);
                if(response!='y'&& response!='n'){
                        cout<< "Enter only 'Y'or'N':";
        }while (response!='Y'&&response!='n');
        return (response=='y') ? 1:0;
}//ContinueWorking
发表于 2003-9-2 17:41:44 | 显示全部楼层
你自己发现错误比大家帮你好!你调试跟踪看看,你会发现问题的。Gook Luck。
GMT+8, 2026-11-4 04:26 , Processed in 0.411424 second(s), 31 queries , Gzip On.
