查看: 1198|回复: 8
[求助] [求助]:谁帮我把尺寸标注的组码点解下
发表于 2003-9-3 16:14:03 | 显示全部楼层 |阅读模式
谢谢
发表于 2003-9-3 16:40:13 | 显示全部楼层
Common dimension group codes Group codes Description
100 Subclass marker (AcDbDimension)
2 Name of the block that contains the entities that make up the dimension picture
10 Definition point (in WCS)
DXF: X value; APP: 3D point
20, 30 DXF: Y and Z values of definition point (in WCS)
11 Middle point of dimension text (in OCS)
21, 31 DXF: Y and Z values of middle point of dimension text (in OCS)
70 Dimension type.
Values 0-6 are integer values that represent the dimension type. Values 32, 64, and 128 are bit values, which are added to the integer values (value 32 is always set in R13 and later releases).
0 = Rotated, horizontal, or vertical; 1 = Aligned;
2 = Angular; 3 = Diameter; 4 = Radius;
5 = Angular 3 point; 6 = Ordinate;
32 = Indicates that the block reference (group code 2) is referenced by this dimension only.
64 = Ordinate type. This is a bit value (bit 7) used only with integer value 6. If set, ordinate is X-type; if not set, ordinate is Y-type.
128 = This is a bit value (bit 8) added to the other group 70 values if the dimension text has been positioned at a user-defined location rather than at the default location.
71 Attachment point:
1 = Top left; 2 = Top center; 3 = Top right;
4 = Middle left; 5 = Middle center; 6 = Middle right;
7 = Bottom left; 8 = Bottom center; 9 = Bottom right
72 Dimension text line spacing style (optional):
1(or missing) = At least (taller characters will override)
2 = Exact (taller characters will not override)
41 Dimension text line spacing factor (optional):
Percentage of default (3-on-5) line spacing to be applied. Valid values range from 0.25 to 4.00.
42 Actual measurement (optional; read-only value)
1 Dimension text explicitly entered by the user. Optional; default is the measurement. If null or "<>", the dimension measurement is drawn as the text, if " " (one blank space), the text is suppressed. Anything else is drawn as the text.
53 The optional group code 53 is the rotation angle of the dimension text away from its default orientation (the direction of the dimension line)  (optional).
51 All dimension types have an optional 51 group code, which indicates the horizontal direction for the dimension entity. The dimension entity determines the orientation of dimension text and lines for horizontal, vertical, and rotated linear dimensions.
This group value is the negative of the angle between the OCS X axis and the UCS X axis. It is always in the XY plane of the OCS.
210 Extrusion direction (optional; default = 0, 0, 1)
DXF: X value; APP: 3D vector
220, 230 DXF: Y and Z values of extrusion direction  (optional)
3 Dimension style name
 楼主| 发表于 2003-9-4 11:13:15 | 显示全部楼层
我就是英语太差,能不能给个翻译,不好意思啊
已领礼包: 593个
发表于 2003-9-4 12:33:51 | 显示全部楼层
最初由 ago9999 发布
[B]我就是英语太差,能不能给个翻译,不好意思啊 [/B]
到明经下载DXF2002,翻译版。
发表于 2003-9-5 12:56:35 | 显示全部楼层
公用标注组码
下列组码适用于所有标注类型。除了此处描述的组码外,其余可参见“图形对象的公用组码”。对于使用本表时出现的缩写及格式的信息,请参见“本参考中的格式转换”。
公用标注组码
组码
说明
100
子类标记 (AcDbDimension)
2
包含组成标注的图元的块名称
10
标注点(用 WCS 表示)。
DXF:X 值;APP:三维点。
20, 30
DXF:标注点坐标的 Y 和 Z 值(用 WCS 表示)
11
标注文本的中点(用 OCS 表示)。
DXF:X 值;APP:三维点。
21, 31
标注文本的中点坐标的 Y 和 Z 值(用 OCS 表示)
70
标注类型: 整数值 0 - 6 表示标注类型。 位值 32、64 和 128 则添加到整数值后(在 R13 和更高版本中设置值 32)。
0 = 转角标注、水平标注或垂直标注;
1 = 对齐标注;
2 = 角度标注;
3 = 直径标注;
4 = 半径标注;
5 = 角度三点标注;
6 = 坐标标注;
32 = 表示块引用(组码 2)只被此标注引用;
64 = 坐标标注类型,此位值(位 7)只与类型 6 一起使用,如果设置,坐标类型为 X 型,否则为 Y 型;
128 = 如果标注文本位于用户指定的位置而不是缺省位置,此位值(位 8)将添加到其他的组码 70 的值中。
71
附着点:
1 = 左上;2 =中上;3 = 右上;
4 = 左中;5 = 中间;6 = 右中;
7 = 左下;8 = 中下;9 = 右下
72
标注文字行间距样式(可选):
1(或缺少) = 至少 (根据一行中最大文字的高度自动添加间距)
2 = 精确 (强制多行文字对象中的各行文字具有相同的行间距)
41
标注文字行间距因子(可选):
使用的缺省行间距(字高的5/3)的百分比。有效值在0.25 到 4.00的范围内。
42
实际尺寸 (可选; 只读值)
1
用户明确地输入了标注文字(可选,缺省值为测量结果) 如果为空或"<>",以文字方式标注测量结果; 如果为 " "(一个空格),禁止输出文字,其他情况下将作为文字绘制到图形中。
53
组码 53 可选,表示标注文字方向与其缺省方向之间的旋转角度(尺寸线的方向)。
51
所有标注类型都有可选组码 51,此组码为标注图元表示了水平方向。它为水平标注、垂直标注及转角线性标注指定了标注文本和尺寸线的方向。组码值为 OCS X 轴与 UCS X 轴间的角度的负值(始终在 OCS 的 XY 面中度量该角度)。
210
拉伸方向(可选,缺省值= 0, 0, 1)DXF:X 值;APP:3D 矢量
220, 230
DXF:拉伸方向的 Y 和 Z 值 (可选)
3
标注样式名
 楼主| 发表于 2003-9-6 16:55:23 | 显示全部楼层
我要用的210肯定是变的,你这里怎么没13/14/15呢,标注点好象也该有两个
已领礼包: 6530个
发表于 2003-9-7 20:59:22 | 显示全部楼层
你为什么不看一下联机帮助呢?明经通道有汉化的。下图是R14的,这许多,怎么给你解释呢?
发表于 2003-9-9 18:16:34 | 显示全部楼层
最初由 ll_j 发布
[B]你为什么不看一下联机帮助呢?明经通道有汉化的。下图是R14的,这许多,怎么给你解释呢? [/B]
谢谢你的提醒,本来我CAD版本里没有东西,也就忘了,经你一提醒,哈。。。那里全有!!
发表于 2003-9-9 20:55:20 | 显示全部楼层
掌握学习的方法比掌握学习本身更重要
GMT+8, 2026-11-3 20:08 , Processed in 0.763430 second(s), 49 queries , Gzip On.
