查看: 532|回复: 4
[求助]:XP自带的分区工具好用吗?
发表于 2003-9-21 10:49:44 | 显示全部楼层 |阅读模式
谁用过XP自带的分区工具,好用吗?
发表于 2003-9-21 11:50:03 | 显示全部楼层
比专业分区工具差多了。
 楼主| 发表于 2003-9-21 12:14:22 | 显示全部楼层
在xp里如何运行啊?
发表于 2003-9-21 13:19:52 | 显示全部楼层
自己瞧瞧呀:
  1. Microsoft Windows XP [Version 5.1.2600]
  2. (C) Copyright 1985-2001 Microsoft Corp.
  3. G:\Documents and Settings\Anthony>diskpart
  4. Microsoft DiskPart version 1.0
  5. Copyright (C) 1999-2001 Microsoft Corporation.
  6. On computer: ALIM
  7. DISKPART> help
  8. Microsoft DiskPart version 1.0
  9. ADD         - Add a mirror to a simple volume.
  10. ACTIVE      - Activates the current basic partition.
  11. ASSIGN      - Assign a drive letter or mount point to the selected volume.
  12. BREAK       - Break a mirror set.
  13. CLEAN       - Clear the configuration information, or all information, off the
  14.               disk.
  15. CONVERT     - Converts between different disk formats.
  16. CREATE      - Create a volume or partition.
  17. DELETE      - Delete an object.
  18. DETAIL      - Provide details about an object.
  19. EXIT        - Exit DiskPart
  20. EXTEND      - Extend a volume.
  21. HELP        - Prints a list of commands.
  22. IMPORT      - Imports a disk group.
  23. LIST        - Prints out a list of objects.
  24. ONLINE      - Online a disk that is currently marked as offline.
  25. REM         - Does nothing. Used to comment scripts.
  26. REMOVE      - Remove a drive letter or mount point assignment.
  27. RESCAN      - Rescan the computer looking for disks and volumes.
  28. RETAIN      - Place a retainer partition under a simple volume.
  29. SELECT      - Move the focus to an object.
  30. DISKPART> list
  31. Microsoft DiskPart version 1.0
  32. DISK        - Prints out a list of disks.
  33. PARTITION   - Prints out a list of partitions on the current disk.
  34. VOLUME      - Print a list of volumes.
  35. DISKPART> list disk
  36.   Disk ###  Status      Size     Free     Dyn  Gpt
  37.   --------  ----------  -------  -------  ---  ---
  38.   Disk 0    Online        19 GB      0 B
  39.   Disk 1    Online        75 GB      0 B
  40. DISKPART> list partition
  41. There is no disk selected to list partitions.
  42. Select a disk and try again.
  43. DISKPART> list disk0
  44. Microsoft DiskPart version 1.0
  45. DISK        - Prints out a list of disks.
  46. PARTITION   - Prints out a list of partitions on the current disk.
  47. VOLUME      - Print a list of volumes.
  48. DISKPART> list disk 0
  49. The arguments you specified for this command are not valid.
  50. DISKPART> helo
  51. Microsoft DiskPart version 1.0
  52. ADD         - Add a mirror to a simple volume.
  53. ACTIVE      - Activates the current basic partition.
  54. ASSIGN      - Assign a drive letter or mount point to the selected volume.
  55. BREAK       - Break a mirror set.
  56. CLEAN       - Clear the configuration information, or all information, off the
  57.               disk.
  58. CONVERT     - Converts between different disk formats.
  59. CREATE      - Create a volume or partition.
  60. DELETE      - Delete an object.
  61. DETAIL      - Provide details about an object.
  62. EXIT        - Exit DiskPart
  63. EXTEND      - Extend a volume.
  64. HELP        - Prints a list of commands.
  65. IMPORT      - Imports a disk group.
  66. LIST        - Prints out a list of objects.
  67. ONLINE      - Online a disk that is currently marked as offline.
  68. REM         - Does nothing. Used to comment scripts.
  69. REMOVE      - Remove a drive letter or mount point assignment.
  70. RESCAN      - Rescan the computer looking for disks and volumes.
  71. RETAIN      - Place a retainer partition under a simple volume.
  72. SELECT      - Move the focus to an object.
复制代码
发表于 2003-9-24 00:44:57 | 显示全部楼层
喔喔...
原来是这样阿....
这个站真的不错耶....学到不少小技巧...
我以前只会用软体分...太差了
GMT+8, 2026-11-5 08:00 , Processed in 0.370890 second(s), 40 queries , Gzip On.
