查看: 1693|回复: 15
[推荐]:ACAD序号小工具
发表于 2003-9-25 13:58:48 | 显示全部楼层 |阅读模式
ACAD序号小工具
发表于 2003-9-25 15:01:14 | 显示全部楼层
什么意思?怎么用?
发表于 2003-9-26 08:31:23 | 显示全部楼层
能不能介绍一下?
发表于 2003-9-26 08:39:58 | 显示全部楼层
;;;  BALLOON generates a circled text descriptor with leader.
;;;  If the current balloon style has no height, a height is prompted for.
;;;  The user picks the leader end, then visually drags the balloon
;;;  center to it's most appropriate spot.
;;;  Options:
;;;  At the "<Center of Balloon>" prompt, the user may:
;;;  press [F9] to toggle the snap mode of the balloon center;
;;;  press [R] to change the ratio of the balloon radius to text height;
;;;  press [T] to change the balloon text generation style;
;;;  press [L] to change the balloon generation layer; or
;;;  press [F] to toggle the fit text mode.
;;;    The fit text mode will vertically fit any oversized text.
;;;    By default, text will be MIDDLE justified at the circle's
;;;    center.  When fit text mode is on, any text extending beyond
;;;    the edge of the circle will be changed to FIT justified and
;;;    forced within the circle boundary.
;;;  When the current balloon text style has no height defined,
;;;  the user may change the current balloon text height by pressing
;;;  [T] at the "<Center of Balloon>" prompt followed by a return.
;;;  Any action, other than pressing an R,T,L,F,F8,F9 or picking a
;;;  point at the "<Center of Balloon>" prompt, will be ignored.
一个给注释画圈的东东
发表于 2003-9-26 13:11:32 | 显示全部楼层
重文介绍一下行吗?
发表于 2003-9-26 13:25:39 | 显示全部楼层
可以不可以用中文介绍啊!
专业英语不好使啊!
发表于 2003-9-26 23:22:41 | 显示全部楼层
用不起来--2004,why
发表于 2003-10-1 11:32:19 | 显示全部楼层
在r14中能用。
发表于 2003-10-1 15:54:33 | 显示全部楼层
是不是做批注用的?
发表于 2003-10-1 16:01:54 | 显示全部楼层
i有什么用,有说明吗
发表于 2003-10-11 23:50:21 | 显示全部楼层
下载后,扩展名是什么????
发表于 2003-10-12 18:44:43 | 显示全部楼层
这个东西是做什么用的啊,我看了那么长时间都没搞懂
发表于 2003-10-12 19:55:56 | 显示全部楼层
把介绍也一并说说最好。
发表于 2003-10-12 21:20:10 | 显示全部楼层
介绍一下嘛!楼主,英文理解的不是很透彻!
发表于 2003-10-13 12:03:20 | 显示全部楼层
版主,为什么我下不了?每次要保存的都是attachment这个文件?
GMT+8, 2026-11-4 17:44 , Processed in 0.689728 second(s), 61 queries , Gzip On.
