查看: 1411|回复: 2
[ARX函数]:求助:关于flagBits()的使用
发表于 2002-7-9 15:33:50 | 显示全部楼层 |阅读模式
文本样式中有一项flagBits(),用来查询是否关于X,Y轴镜像。它的返回值是Adesk::UInt8 ,但我不知道如何使用Adesk::UInt8 。请教各位大侠,如何使用,谢谢!!
发表于 2002-7-9 15:53:53 | 显示全部楼层
我感觉和int差不多,只能到8而已
这有个例子
Adesk::UInt8 flag = pText->flagBits();
    if(flag == 0)
    else
 楼主| 发表于 2002-7-9 15:58:22 | 显示全部楼层
Adesk::UInt8
flagBits() const;
Returns the textStyle flagBits value. Only the second and third bits are used. If the second bit is set it indicates that the text is drawn backward (that is, mirrored in X). If the third bit is set it indicates that the text is drawn upside down (that is, mirrored in Y).
那我如何提取X,Y轴镜像呢?the second and third bits在其中又为何意呢?
GMT+8, 2026-11-3 02:34 , Processed in 0.410968 second(s), 36 queries , Gzip On.
