查看: 1030|回复: 1
[VBA函数]:才能用vba对外部引用中的图层进行操作
发表于 2002-7-27 20:56:39 | 显示全部楼层 |阅读模式
假定一图形有三个外部引用图形分别为xref1,xref2,xrf3,
如何才能用vba对xref1,xref2,xref3,中的图层进行关闭,锁定
等操作呢?
发表于 2002-7-27 22:55:00 | 显示全部楼层
  1. Dim objBlock As AcadBlock
  2. Dim objLayer As AcadLayer
  3. Dim OldName As String
  4. Dim LayName As String
  5. OldName = "MyLayer"
  6. For Each objBlock In ThisDrawing.Blocks
  7.     If objBlock.IsXRef = True Then
  8.         LayName = objBlock.Name & "|" & OldName
  9.         Set objLayer = ThisDrawing.Layers(LayName)
  10.         objLayer.LayerOn = False
  11.     End If
  12. Next
GMT+8, 2026-11-22 10:16 , Processed in 0.325821 second(s), 13 queries , Gzip On, File On.
