查看: 1082|回复: 4
[编程申请]:(连续梁、刚架、桁架、排架、组合结构)计算程序. _FOR
发表于 2003-11-3 15:43:40 | 显示全部楼层 |阅读模式
C        ***************************************
C        *   STATIC ANALYSIS FOR PLANE FRAME   *
C        *    (METHOD OF FORMER TREATMENT)     *
C   Main program reads the control parameters, organizes
C   the whole calculation by calling subroutines and
C   prints calculation results.
        PROGRAM PFF2
        DIMENSION X(50),Y(50),IJ(50,2),MT(30),AI(10,2),
     &  JS(20,4),SE(30,2),PJ(50,3),PF(50,4),JN(50,3),
     &  KD(150),TK(1000),P(150),F(6)
        CHARACTER*12 INDAT,OUTDAT
        WRITE(*,*) 'Please input primary data file name!'
        READ(*,'(A12)') INDAT
        WRITE(*,*) 'Please input calculation result file name!'
        READ(*,'(A12)') OUTDAT
        OPEN(1,FILE=INDAT,STATUS='OLD')
        OPEN(2,FILE=OUTDAT,STATUS='NEW')
        READ(1,*) NE,NJ,NS,NAI,NK,NL,E
        WRITE(2,10) NE,NJ,NS,NAI,NK,NL,E
10      FORMAT(5X,'PLANE FRAME STRUCTURE ANALYSIS'
     &  /5X,'******************************'
     &  //2X,'CONTROL PARAMETERS OF STRUCTURE'
     &  /5X,'NE=',I2,8X,'NJ=',I2,8X,'NS=',I2,8X,'NAI=',
     &  I2,/5X,'NK=',I2,8X,'NL=',I2,8X,'E=',E12.4)
        CALL INPUT(NE,NJ,NS,NAI,NK,X,Y,IJ,MT,AI,JS,SE)
        CALL DJN(NJ,NS,JS,JN,N)
        CALL ADE(NE,NJ,N,IJ,JN,KD,NN)
        CALL TSM(NE,NJ,NAI,E,N,NN,X,Y,IJ,MT,AI,JN,KD,TK)
        CALL UTDU3(TK,NN,KD,N)
        DO 20 LC=1,NL
        READ(1,*) NP,NF
        WRITE(2,30) LC,NP,NF
30      FORMAT(/2X,'LOAD DATA'/10X,'LOAD CASE=',I3/10X,
     &  'NP=',I3,8X,'NF=',I3)
        CALL JLP(NE,NJ,NAI,E,N,NP,NF,X,Y,IJ,JN,PJ,PF,MT,AI,P)
        CALL BACK3(TK,NN,P,N,KD,JN,NJ)
        WRITE(2,40)
40      FORMAT(//4X,'MEMBER-END FORCES OF ELEMENTS'/4X,
     &  'ELEMENT',13X,'N',17X,'V',17X,'M')
        DO 60 M=1,NE
        CALL MVN(M,NE,NJ,NAI,N,NF,E,X,Y,IJ,MT,AI,JN,PF,P,F)
        WRITE(2,50) M,(F(I),I=1,6)
50      FORMAT(/1X,I10,3X,'N1=',F12.4,3X,'V1=',F12.4,3X,'M1=',
     &  F12.4/14X,'N2=',F12.4,3X,'V2=',F12.4,3X,'M2=',F12.4)
60      CONTINUE
        IF(NK.GT.0) THEN
        CALL NVMK(NE,NJ,NAI,NK,E,N,NF,X,Y,IJ,JN,MT,AI,PF,P,SE)
        END IF
20      CONTINUE
        CLOSE(1)
        CLOSE(2)
        END
C   Read and print structural data.
        SUBROUTINE INPUT(NE,NJ,NS,NAI,NK,X,Y,IJ,MT,AI,JS,SE)
        DIMENSION X(NJ),Y(NJ),IJ(NE,2),MT(NE),AI(NAI,2),
     &  JS(NS,4),SE(NK,2)
        READ(1,*) (X(I),Y(I),I=1,NJ)
        READ(1,*) (IJ(I,1),IJ(I,2),MT(I),I=1,NE)
        READ(1,*) ((AI(I,J),J=1,2),I=1,NAI)
        READ(1,*) ((JS(I,J),J=1,4),I=1,NS)
        IF(NK.GT.0) READ(1,*) ((SE(I,J),J=1,2),I=1,NK)
        WRITE(2,10) (I,X(I),Y(I),I=1,NJ)
        WRITE(2,20) (I,IJ(I,1),IJ(I,2),MT(I),I=1,NE)
        WRITE(2,30) (I,(AI(I,J),J=1,2),I=1,NAI)
        WRITE(2,40) ((JS(I,J),J=1,4),I=1,NS)
        IF(NK.GT.0) WRITE(2,50) ((SE(I,J),J=1,2),I=1,NK)
10      FORMAT(//2X,'COORDINATES OF JOINTS'/6X,'JOINT',11X,'X',
     &  11X,'Y'/(6X,I4,5X,2F12.4))
20      FORMAT(//2X,'INFORMATION OF ELEMENTS'/6X,'ELEMENT',
     &  4X,'JOINT-I',4X,'JOINT-J',5X,'TYPE'/(2X,4I10))
30      FORMAT(/7X,'TYPE',10X,'A',12X,'I'/(8X,I2,5X,2F12.6))
40      FORMAT(//2X,'INFORMATION OF SPECIAL JOINTS'/6X,
     &  'JOINT',4X,'u',4x,'v',4x,'ceta'/(6X,4I5))
50      FORMAT(//2X,'ASSIGNMENT SECTION'/7X,'ELEMENT',4X,
     &  'SECTION PLACE'/(3X,F10.0,F12.2))
        END
C   Determine number of joint displacements.
        SUBROUTINE DJN(NJ,NS,JS,JN,N)
        DIMENSION JS(NS,4),JN(NJ,3)
        DO 10 I=1,NJ
        DO 10 J=1,3
10      JN(I,J)=0
        DO 20 I=1,NS
        L=JS(I,1)
        DO 20 J=1,3
20      JN(L,J)=JS(I,J+1)
        N=0
        ID=0
        DO 30 I=1,NJ
        DO 30 J=1,3
        IF(JN(I,J)-1) 40,50,60
40      N=N+1
        JN(I,J)=N
        GO TO 30
50      JN(I,J)=0
        GO TO 30
60      ID=1
30      CONTINUE
        IF(ID.EQ.0) GO TO 80
        DO 70 I=1,NS
        L=JS(I,1)
        DO 70 J=1,3
        K=JS(I,J+1)
        IF(K.LE.1) GO TO 70
        JN(L,J)=JN(K,J)
70      CONTINUE
80      RETURN
        END
C   Determine address of diagonal elements of
C   total stiffness matrix.
        SUBROUTINE ADE(NE,NJ,N,IJ,JN,KD,NN)
        DIMENSION IJ(NE,2),JN(NJ,3),KD(N),LV(6)
        DO 10 I=1,N
10      KD(I)=0
        DO 20 M=1,NE
        CALL ELV(M,NE,NJ,IJ,JN,LV)
        MIN=N
        DO 30 I=1,6
        J=LV(I)
        IF(J.EQ.0) GO TO 30
        IF(J.LT.MIN) MIN=J
30      CONTINUE
        DO 20 I=1,6
        J=LV(I)
        IF(J.EQ.0) GO TO 20
        NW=J-MIN+1
        IF(NW.GT.KD(J)) KD(J)=NW
20      CONTINUE
        NN=1
        DO 40 J=2,N
        NN=NN+KD(J)
        KD(J)=NN
40      CONTINUE
        END
C   Assemble total stiffness matrix stored as a vector.
        SUBROUTINE TSM(NE,NJ,NAI,E,N,NN,X,Y,IJ,MT,AI,
     &  JN,KD,TK)
        DIMENSION X(NJ),Y(NJ),IJ(NE,2),JN(NJ,3),MT(NE),
     &  AI(NAI,2),KD(N),TK(NN),EK(6,6),LV(6)
        DO 10 I=1,NN
10      TK(I)=0.0
        DO 20 M=1,NE
        CALL LSC(M,NE,NJ,X,Y,IJ,BL,SI,CO)
        CALL ESM(M,NE,NAI,E,MT,AI,BL,SI,CO,EK)
        DO 30 L=1,6
        I=LV(L)
        IF(I.EQ.0) GO TO 30
        DO 40 K=1,6
        J=LV(K)
        IF(J.LT.I) GO TO 40
        JI=KD(J)-J+I
        TK(JI)=TK(JI)+EK(L,K)
40      CONTINUE
30      CONTINUE
20      CONTINUE
        END
C   Decompose total stiffness matrix using
C   Crout method.
        SUBROUTINE UTDU3(A,NN,ID,N)
        DIMENSION A(NN),ID(N)
        DO 30 J=2,N
        JJ=ID(J)
        J1=J-1
        MJ=J-JJ+ID(J1)+1
        IF(MJ.GT.J1) GO TO 30
        DO 20 I=MJ,J
        II=ID(I)
        I1=I-1
        MIJ=MJ
        IF(I.EQ.J) GO TO 5
        MI=I-II+ID(I1)+1
        IF(MIJ.LT.MI) MIJ=MI
5       S=0.0
        IF(MIJ.GT.I1) GO TO 15
        DO 10 K=MIJ,I1
        KI=II-I+K
        KK=ID(K)
        KJ=JJ-J+K
10      S=S+A(KI)*A(KK)*A(KJ)
15      IF(I.EQ.J) THEN
        A(JJ)=A(JJ)-S
        ELSE
        JI=JJ-J+I
        A(JI)=(A(JI)-S)/A(II)
        END IF
20      CONTINUE
30      CONTINUE
        END
C   Form total joint load vector.
        SUBROUTINE JLP(NE,NJ,NAI,E,N,NP,NF,X,Y,IJ,JN,
     &  PJ,PF,MT,AI,P)
        DIMENSION X(NJ),Y(NJ),IJ(NE,2),JN(NJ,3),PJ(NP,3),
     &  PF(NF,4),MT(NE),AI(NAI,2),P(N),FO(6),PE(6),LV(6)
        DO 10 I=1,N
        P(I)=0.0
10      CONTINUE
        IF(NP.GT.0) THEN
        READ(1,*) ((PJ(I,J),J=1,3),I=1,NP)
        WRITE(2,20) ((PJ(I,J),J=1,3),I=1,NP)
20      FORMAT(/2X,'JOINT LOAD'/6X,'JOINT',8X,'XYM',12X,
     &  'LOAD'/(6X,F5.0,6X,F5.0,6X,F12.4))
        DO 30 I=1,NP
        J=INT(PJ(I,1))
        K=INT(PJ(I,2))
        L=JN(J,K)
        IF(L.NE.0) P(L)=PJ(I,3)
30      CONTINUE
        END IF
        IF(NF.GT.0) THEN
        READ(1,*) ((PF(I,J),J=1,4),I=1,NF)
        WRITE(2,40) ((PF(I,J),J=1,4),I=1,NF)
40      FORMAT(/2X,'NON-JOINT LOAD'/6X,'ELEMENT',8X,'TYPE',
     &  8X,'LOAD',12X,'C'/(6X,F6.0,6X,F6.0,4X,2F12.4))
        DO 50 I=1,NF
        M=INT(PF(I,1))
        CALL EFF(I,M,NE,NAI,E,NF,PF,MT,AI,BL,FO)
        PE(1)=-FO(1)*CO+FO(2)*SI
        PE(2)=-FO(1)*SI-FO(2)*CO
        PE(3)=-FO(3)
        PE(4)=-FO(4)*CO+FO(5)*SI
        PE(5)=-FO(4)*SI-FO(5)*CO
        PE(6)=-FO(6)
        DO 60 J=1,6
        L=LV(J)
        IF(L.NE.0) P(L)=P(L)+PE(J)
60      CONTINUE
50      CONTINUE
        END IF
        END
C   Solve equations and print joint displacements.
        SUBROUTINE BACK3(A,NN,B,N,ID,JN,NJ)
        DIMENSION A(NN),B(N),ID(N),JN(NJ,3),D(3)
        DO 20 J=2,N
        JJ=ID(J)
        J1=J-1
        MJ=J-JJ+ID(J1)+1
        IF(MJ.GT.J1) GO TO 20
        DO 10 I=MJ,J1
        JI=JJ-J+I
10      B(J)=B(J)-A(JI)*B(I)
20      CONTINUE
        DO 30 I=1,N
        II=ID(I)
        B(I)=B(I)/A(II)
30      CONTINUE
        NW=1
        DO 35 I=2,N
        IW=ID(I)-ID(I-1)
        IF(IW.GT.NW) NW=IW
35      CONTINUE
        N1=N-1
        DO 50 I=N1,1,-1
        MIN=I+NW-1
        IF(N.LT.MIN) MIN=N
        DO 40 J=I+1,MIN
        JJ=ID(J)
        MJ=J-JJ+ID(J-1)+1
        IF(I.LT.MJ) GO TO 40
        JI=JJ-J+I
        B(I)=B(I)-A(JI)*B(J)
40      CONTINUE
50      CONTINUE
        WRITE(2,60)
60      FORMAT(//2x,'JOINT DISPLACEMENTS'/5x,'JOINT',12X,
     &  'u',14X,'v',11X,'ceta')
        DO 80 I=1,NJ
        DO 70 J=1,3
        D(J)=0.0
        L=JN(I,J)
        IF(L.NE.0) D(J)=B(L)
70      CONTINUE
        WRITE(2,75) I,D(1),D(2),D(3)
75      FORMAT(2X,I6,4X,3E15.6)
80      CONTINUE
        END
C   Calculate member-end forces of elements.
        SUBROUTINE MVN(M,NE,NJ,NAI,N,NF,E,X,Y,IJ,MT,
     &  AI,JN,PF,P,F)
        DIMENSION X(NJ),Y(NJ),IJ(NE,2),AI(NE,2),P(N),
     &  JN(NJ,3),PF(NF,4),LV(6),FO(6),D(6),FD(6),F(6),
     &  EK(6,6)
        DO 10 I=1,6
        L=LV(I)
        D(I)=0.0
        IF(L.NE.0) D(I)=P(L)
10      CONTINUE
        DO 20 I=1,6
        FD(I)=0.0
        DO 30 J=1,6
        FD(I)=FD(I)+EK(I,J)*D(J)
30      CONTINUE
20      CONTINUE
        F(1)=FD(1)*CO+FD(2)*SI
        F(2)=-FD(1)*SI+FD(2)*CO
        F(3)=FD(3)
        F(4)=FD(4)*CO+FD(5)*SI
        F(5)=-FD(4)*SI+FD(5)*CO
        F(6)=FD(6)
        IF(NF.GT.0) THEN
        DO 40 I=1,NF
        L=INT(PF(I,1))
        IF(M.EQ.L) THEN
        DO 50 J=1,6
        F(J)=F(J)+FO(J)
50      CONTINUE
        END IF
40      CONTINUE
        END IF
        END
C   Calculate assignment section forces of elements.
        SUBROUTINE NVMK(NE,NJ,NAI,NK,E,N,NF,X,Y,IJ,JN,
     &  MT,AI,PF,P,SE)
     &  AI(NAI,2),PF(NF,4),P(N),F(6),SK(3),S(3),SE(NK,2)
        WRITE (2,5)
5       FORMAT(//4X,'ASSIGNMENT SECTION FORCES OF ELEMENTS'
     &  /4X,'ELEMENT',8X,'XK',13X,'NK',13X,'VK',15X,'MK')
        DO 10 K=1,NK
        M=INT(SE(K,1))
        XK=SE(K,2)
        SK(1)=F(4)
        SK(2)=F(5)
        SK(3)=-F(5)*(BL-XK)-F(6)
        IF(NF.NE.0) THEN
        DO 20 I=1,NF
        I1=INT(PF(I,1))
        IF(I1.NE.M) GO TO 20
        IF((PF(I,1)-M).GT.0.0) GO TO 25
        C=PF(I,4)
        NO=INT(PF(I,2))
        IF(XK.LT.C.AND.NO.LT.7) THEN
        Q=PF(I,3)
        CALL CANB(NO,Q,C,XK,S)
        DO 30 J=1,3
30      SK(J)=SK(J)+S(J)
        END IF
20      CONTINUE
        END IF
25      WRITE (2,40) M,XK,SK(1),SK(2),SK(3)
40      FORMAT(5X,I5,F12.2,3F16.4)
10      CONTINUE
        END
C   Calculate length,sine and cosine of member.
        SUBROUTINE LSC(M,NE,NJ,X,Y,IJ,BL,SI,CO)
        I=IJ(M,1)
        J=IJ(M,2)
        DX=X(J)-X(I)
        DY=Y(J)-Y(I)
        BL=SQRT(DX*DX+DY*DY)
        SI=DY/BL
        CO=DX/BL
        END
C   Set up element location vector.
        SUBROUTINE ELV(M,NE,NJ,IJ,JN,LV)
        DIMENSION IJ(NE,2),JN(NJ,3),LV(6)
        I=IJ(M,1)
        J=IJ(M,2)
        DO 10 K=1,3
        LV(K)=JN(I,K)
        LV(K+3)=JN(J,K)
10      CONTINUE
        END
C   Calculate element stiffness matrix referred
C   to global coordinate system.
        SUBROUTINE ESM(M,NE,NAI,E,MT,AI,BL,SI,CO,EK)
        DIMENSION MT(NE),AI(NAI,2),EK(6,6)
        I=MT(M)
        C1=E*AI(I,1)/BL
        C2=2.0*E*AI(I,2)/BL
        C3=3.0*C2/BL
        C4=2.0*C3/BL
        S1=C1*CO*CO+C4*SI*SI
        S2=(C1-C4)*SI*CO
        S3=C3*SI
        S4=C1*SI*SI+C4*CO*CO
        S5=C3*CO
        S6=C2
        EK(1,1)=S1
        EK(1,2)=S2
        EK(1,3)=-S3
        EK(1,4)=-S1
        EK(1,5)=-S2
        EK(1,6)=-S3
        EK(2,2)=S4
        EK(2,3)=S5
        EK(2,4)=-S2
        EK(2,5)=-S4
        EK(2,6)=S5
        EK(3,3)=2.0*S6
        EK(3,4)=S3
        EK(3,5)=-S5
        EK(3,6)=S6
        EK(4,4)=S1
        EK(4,5)=S2
        EK(4,6)=S3
        EK(5,5)=S4
        EK(5,6)=-S5
        EK(6,6)=2.0*S6
        DO 10 I=1,5
        DO 10 J=I+1,6
10      EK(J,I)=EK(I,J)
        END
C   Calculate element fixed-end forces.
        SUBROUTINE EFF(I,M,NE,NAI,E,NF,PF,MT,AI,BL,FO)
        DIMENSION PF(NF,4),MT(NE),AI(NAI,2),FO(6)
        IF((PF(I,1)-M).GT.0.0) GO TO 100
        NO=INT(PF(I,2))
        Q=PF(I,3)
        C=PF(I,4)
        IF(NO.GT.6) GO TO 3
        B=BL-C
        C1=C/BL
        C2=C1*C1
        C3=C1*C2
3       DO 5 J=1,6
5       FO(J)=0.0
        GO TO (10,20,30,40,50,60,70,80,90),NO
10      FO(2)=-Q*C*(1.0-C2+C3/2.0)
        FO(3)=-Q*C*C*(0.5-2.0*C1/3.0+0.25*C2)
        FO(5)=-Q*C*C2*(1.0-0.5*C1)
        FO(6)=Q*C*C*C1*(1.0/3.0-0.25*C1)
        RETURN
20      FO(2)=-Q*B*B*(1.0+2.0*C1)/BL/BL
        FO(3)=-Q*C*B*B/BL/BL
        FO(5)=-Q*C2*(1.0+2.0*B/BL)
        FO(6)=Q*C2*B
        RETURN
30      FO(2)=6.0*Q*C1*B/BL/BL
        FO(3)=Q*B*(2.0-3.0*B/BL)/BL
        FO(5)=-6.0*Q*C1*B/BL/BL
        FO(6)=Q*C1*(2.0-3.0*C1)
        RETURN
40      FO(2)=-Q*C*(0.5-0.75*C2+0.4*C3)
        FO(3)=-Q*C*C*(1.0/3.0-0.5*C1+0.2*C2)
        FO(5)=-Q*C*C2*(0.75-0.4*C1)
        FO(6)=Q*C*C*C1*(0.25-0.2*C1)
        RETURN
50      FO(1)=-Q*C*(1.0-0.5*C1)
        FO(4)=-0.5*Q*C*C1
        RETURN
60      FO(1)=-Q*B/BL
        FO(4)=-Q*C1
        RETURN
70      L=INT(C)
        K=MT(M)
        S=E*AI(K,1)*Q/BL
        FO(L)=S
        IF(L.EQ.1) FO(4)=-S
        IF(L.EQ.4) FO(1)=-S
        RETURN
80      L=INT(C)
        K=MT(M)
        FO(L)=12.0*E*AI(K,2)*Q/BL/BL/BL
        IF(L.EQ.2) FO(5)=-FO(2)
        IF(L.EQ.5) FO(2)=-FO(5)
        FO(3)=0.5*BL*FO(2)
        FO(6)=FO(3)
        RETURN
90      L=INT(C)
        K=MT(M)
        S=2.0*E*AI(K,2)*Q/BL
        FO(L)=2.0*S
        IF(L.EQ.3) FO(6)=S
        IF(L.EQ.6) FO(3)=S
        FO(2)=3.0*S/BL
        FO(5)=-FO(2)
        RETURN
100     K=MT(M)
        H=SQRT(12.0*AI(K,2)/AI(K,1))
        FO(1)=0.5*E*AI(K,1)*PF(I,4)*(PF(I,2)+PF(I,3))
        FO(2)=0.0
        FO(3)=-E*AI(K,2)*PF(I,4)*(PF(I,2)-PF(I,3))/H
        FO(4)=-FO(1)
        FO(5)=0.0
        FO(6)=-FO(3)
        END
C   Calculate assignment section forces of cantilever beam.
        SUBROUTINE CANB(NO,Q,C,XK,S)
        DIMENSION S(3)
        DO 5 J=1,3
5       S(J)=0.0
        GO TO (10,20,30,40,50,60),NO
10      CX=C-XK
        S(2)=Q*CX
        S(3)=-0.5*S(2)*CX
        RETURN
20      S(2)=Q
        S(3)=-Q*(C-XK)
        RETURN
30      S(3)=-Q
        RETURN
40      CX=C-XK
        XC=XK/C
        S(2)=0.5*Q*(1.0+XC)*CX
        S(3)=-Q*(2.0+XC)*CX*CX/6.0
        RETURN
50      S(1)=Q*(C-XK)
        RETURN
60      S(1)=Q
        END
发表于 2003-11-5 13:05:20 | 显示全部楼层
如何应用
发表于 2003-11-5 13:25:44 | 显示全部楼层
来自下面这本书
土木工程结构分析程序设计
著 译 者:赵更新
出 版 社:中国水利水电出版社
出版日期:2002-1-1
印刷日期:2002-7-2
书    号:ISBN 7-5084-0920-5
规    格:平装16开,371页
内容简介:
本书是为高等院校土木工程、工程力学专业的学生学习“结构分析程序设计”而编写的教材。全书共十一章,包括绪论、矩阵位移法及平面刚架静力分析程序,平面刚架静分析程序的改进及功能扩展,连续梁,桁梁及交叉梁系结构静力分析程序设计,弹性力学有限单元法的基本概念,平面问题的三结点三角形单元及程序设计,平面问题的高次单元和等参数单元,结构动力分析的有限单元法及程序设计,线性代数方程组的解法及程序,矩阵特征值及特征向量的计算,程序调试。书中有大量的例题和习题,习题附有答案。本书采用基本原理,程序设计、上机实习三者紧密结合的方式编写。取材适当,点滴结合,由浅入深,叙述细致,便于学习。本书还可以作为有关专业硕士研究生的教材,也可供有关工程技术人员参考。
目 录:
前言
第一章 绪论
第二章 矩阵位移法及平面刚架静力分析程序设计
第三章 平面刚架静力分析程序的改进及概念扩展
第四章 连续梁、桁梁及交叉梁系结构静力分析程序设计
第五章 弹性力学有限单元法的基本概念
第六章 平面问题的三结点三角形单元及程序设计
第七章 平面问题的高次单元和等参数单元
第八章 结构动力分析的有限单元法及程序设计
第九章 线性代数方程组的解法及程序
第十章 矩阵特征值及特征向量的计算程序
第十一章 程序测试
附录 部分习题答案
参考文献
发表于 2003-11-7 16:50:12 | 显示全部楼层
fortran语言,这段代码用何版编译?
发表于 2003-11-9 20:58:29 | 显示全部楼层
这个就是著名的“pff2”嘛,学结构的高等院校都要学,最初的pkpm的其中一部分就有这个程序,这些也拿出来共享??单独拿这个程序出来毫无意义。
GMT+8, 2026-11-3 07:08 , Processed in 0.442446 second(s), 41 queries , Gzip On.
