楼主: liuyi7735
[求助]:求助!急!急!
发表于 2003-11-14 12:42:22 | 显示全部楼层
还是不明白,楼主说清楚些。
发表于 2003-11-15 00:14:40 | 显示全部楼层
LISP程序滿足樓主要求
  1. (defun c:test()
  2.     (setvar "cmdecho" 0)
  3.     (setvar "dimzin" 0)
  4.     (setq ss (ssget))
  5.     (setq ss (ssget "P" '((0 . "TEXT"))))
  6.     (setq num nil)
  7.     (initget 4)
  8.     (setq num (getint "\n小數位數 <3> :"))
  9.     (if (= num nil)(setq num 3))
  10.
  11.     (setq j 0)
  12.     (repeat (sslength ss)
  13.        (setq mark 0)
  14.        (setq sname (ssname ss j))
  15.        (setq endata (entget sname))
  16.        (setq ent (assoc 1 endata))
  17.        (setq oldtxt (cdr ent))
  18.        (setq txtlen (strlen oldtxt))
  19.        (setq k 1)
  20.        (repeat txtlen
  21.           (setq lenk (substr oldtxt k 1))
  22.           (setq ascnum (ascii lenk))
  23.           (if (or (and (>= ascnum 65)(<= ascnum 90))
  24.                        (and (>= ascnum 97)(<= ascnum 122)))
  25.               (setq mark 1)
  26.           )
  27.           (setq k (+ k 1))
  28.        )
  29.         (if (/= mark 1)
  30.             (progn
  31.                (setq oldtxt1 (atof oldtxt))
  32.                (setq newtxt (rtos oldtxt1 2 num))
  33.                (setq newtxt (cons 1 newtxt))
  34.                (setq endata (subst newtxt ent endata))
  35.                (entmod endata)
  36.             )
  37.         )
  38.         (setq j (+ j 1))
  39.     )
  40. (prin1)
  41. )
  42. (prin1)
GMT+8, 2026-11-3 07:20 , Processed in 0.459671 second(s), 28 queries , Gzip On.
