查看: 831|回复: 2
[求助]:那位高手有结构专业方面的英语词汇呀???能否上传,以供小弟及大家共同享用
发表于 2003-11-14 21:07:03 | 显示全部楼层 |阅读模式
*-*i
发表于 2003-11-14 21:24:24 | 显示全部楼层
附件解压后可导入金山词霸2003用户辞典内,双向翻译。
是本人从台湾网站上收集并转成国标码的。如果觉得有用的话,拿去好了。
-      FLASH,盖板/遮雨板
1F      First Floor,一楼
2F      Second Floor,二楼
A/G      At Grade,平面段
AB      Anchor Bolt,锚栓
AC      Asphalt Concrete,沥青混凝土
ACOUS      Acoustical,隔音
ACP      Asbestos Concrete Pipe,石棉管
AG      Above Ground,地面上
ALT      Alternative,交错 / 排列 / 替代
ALUM      Aluminum,铝
AZ      Azimuth,方位角
B      Bench,台阶 / 户外长形座椅
B1      First Basement,地下一层
B2      Second Basement,地下二层
BC      Beginning of simple Circular Curve,单曲线起点
BL      Boundary Line,边界线
BM      Bench Mark,水准标准点/水准点
BOF      Bottom Of Footing,基础底面
BOT      Bottom,底(层)
BOX      Box Culvert,箱涵
BRG      Bearing,支承
BRK      Brick,砖
BSMT      Basement,地下室
BT      Bent,弯
BVC      Beginning of Vertical Curve,竖曲线起点
C.I.P      Cast Iron Pipe,铸铁管
CAB      Cabinet,室/厨/箱
CB      Catch Basin,阴井
CC      Point of Curve to Curve,曲线连结点
CCM      Cut and Cover Method,明控覆盖工法
CE      Civil Engineering,土木工程
CF      Point of Contra-flexure,挠曲点
CGR      Concrete Grouted Rock,混凝土砌卵石
CGS      Center of Gravity of Prestressing Tendons,预力钢键坐标(重心)
CH      Chainage,测炼
CI      Cast Iron,铸铁
CIPC      Cast in Place Concrete,场铸混凝土
CJ      Control Joint/Construction Joint,控制缝/施工缝
CL      Center Line,中心线
CL.      Clearance,净(保护层)
CLD      Clothoid,克罗梭曲线
CLG      Ceiling,天花板
CLL      Clearance Line,净高线
CMU      Concrete Masonry Unit,混凝土砖
COL      Column,柱
CONC      Concrete,混凝土
CONST JT      Construction Joint,施工缝/收缩缝
CONST JT"      Construction Joint,施工缝/收缩缝
CONT      Continuous ,继续
CORR      Corridor,"通路 , 走廊"
CS      Point of Curve to Spiral/Cutting Slope,缓曲线起点/开挖坡面
CT      Point of Curve to Tangent/Cable Trough,切线点/电缆槽
CW      Curtain Wall,帷幕墙
D&B      Drill and Blast,钻炸法
DET      Detail,详细
DGL      Designed Ground Level,设计地面高程
DIA      Diameter,直径
DIM      Dimension,尺寸
DL      Dead Load,呆重/静重
DWL      Dowel,杆/预留钢栓
EA      Each,每…..个
EDM      Electronic Distance Measurement,电子测距
EGL      Existing Ground Level,现地高程
EJ      Expansion Joint,伸缩缝
EL      Elevation(Height),立面
ELEV      Elevation View,立视
ELVR      Elevator,电梯
EMB.PL      Embedded Plate,预埋底板
EOP      End of Platform,月台终端
EP      Earth Pressure Cell,土压计
EQ      Equal Space,等距
ESCA      Escalator,电扶梯
ETP      Existing Top of Pavement,现有铺面顶
EW      Even Way,双向
EXC      Excavation,开挖
EXH      Exhaust,排气
F.S      Full Superelevation,全超高
Fc      Allowable Compressive Strength of Concrete,混凝土容许抗压强度
Fc'      Compressive Strength of Concrete,混凝土设计抗压强度
FD      Floor Drainage,地板落水/地板排水
FFL      Finished Floor Level,粉刷装修楼地板完成面高程
FGL      Finished Ground Level,粉刷装修地面完成面高程
FHC      Fire Hydrant Cabinet,消防箱
FIN      Finish/ Finished,粉刷/完成
FL      Floor,楼板(层)
Fs      Allowable Tension Stress of Steel,钢材容许应力
FWY.      Freeway ,高速公路
Fy      Minimum Yield Stress of Steel,钢材最低降伏应力强度
GA      Gauge,轨距/板厚
GALV      Galvanized,镀锌
GEB      Guided Expansion Bearing,导向伸缩支承
GIP      Galvanized Iron Pipe,镀锌铁管
GL      Ground Level,地面高程、地基高程
GPC      Granite Precast,人造花岗石
GPS      Global Positioning System,卫星定位系统
GRC      Glassfiber Reinforced Concrete,玻璃纤维化混凝土
GW      Guide way,导向运输系统
GWL      Ground Water Level,地下水位
GYP      Gypsum,石棉/石膏版
HC      Heel of Crossing,横断面交趾点
HG      Hinged,铰接
HH      Handhole ,人孔
HHWL      Highest High Water Level,最高洪水位
HIP      Horizontal Intersection Point,水手交连点
HL      Horizontal Line,水平线
HP      High Point,高点
HSB      High Strength Bolt,强力螺栓
HTS      High Tensile Strand,高拉力钢索
HTW      High Strength Wire,高拉力钢线
HW      Height of Water,水深
HWL      High Water Level,高水位
HWY      Highway,公路
HYP      Hydraulic Piezometer,水压计
I      Invert,仰拱
I.F.      Inner Face,内面
ID      Inside Diameter,内径
IE      Invert Elevation,仰拱高
INL      Inlet,进水井
IP      Intersection Point,交连点
IPI      In Place Inclinometer,倾钭计
JB      Junction Box,接线盒
JT      Joint,接缝
KO      Knock Out,预留开口(孔)
LAV      Lavatory,化妆室
LC      Lean Concrete,低强度混凝土
LCC      Length of Circular Curve,曲线长
LL      Live Load,活载重
LoC      Load Cell,荷重计
LP      Low Point,低点
LR      Local Road,县乡道
LS      Length of Spiral,缓和曲线长
LVC      Length of Vertical Curve,竖曲线长
LWL      Lower Water Level,低水位
MF      Mirror Finish,镜面粉刷
MK      Mark,记号/标记
MS      Main Station,主站
MSL      Mean Sea Level,平均海平面
MVC      Middle of Vertical Curve,竖曲线中点
MWL      Mean Water Level,平均水位
N      North ,北
NATM      New Austrian Tunnel Method,新奥工法
NF      Near Face ,近侧面
NGEB      Non-Guided Expansion Bearing,非导向伸缩支承
NWL      Normal Water Level,常水位
OC      On Center ,中心点
OD      Outside Diameter,外径
OF      Outer Face,外面
OFS      Offset ,支距
OGL      Original Ground Level,原地面线
OPNG      Opening,开孔
OPP      Opposite,反向
OW      Observation Well,观测井
PC      Prestressed Concrete,预力混凝土
PCC      Portland Cement Concrete,无筋混凝土
PCE      Plain Concrete,普通混凝土
PCO      Pile Cut Off,椿头打除
PED BRIG      Pedestrian Bridge,人行桥
PED U/P      Pedestrian Underpass,人行地下道
PERP      Perpendicular,垂直
PF      Platform,月台
PG      Profile Grade,纵坡
PI      Point of Intersection,交连点
PL      Property Line,产权线
PLAT      Platform,月台
PROJ      Projection,投影图
PS      Principal Station,主站
PSC      Prestressed Concrete,预力混凝土
PSCP      Prestressed Concrete Pipe,预力混凝土管
PT      Point,点
PVCP      P.V.C. Pipe,塑料管
PVI      Point of Vertical Intersection,竖曲线交点
R              Riser/Radius,阶梯踏高/半径
RAL      Rail Level,轨道高程
RB      Rock Bolt,岩锚
RC      Reinforced Concrete,钢筋混凝土
RCB      Reinforced Concrete Box,钢筋混凝土箱涵
RCP      Reinforced Concrete Pipe,钢筋混凝土管
RCW      Reinforced Concrete Wall,钢筋混凝土墙
RD      Roof Drainage,屋顶落水(排水)
REINF      Reinforcement,强化/钢筋
RF      Roof,屋顶
RG      Reinforcing Bar Strain Gauge,钢筋应变计
RL      Reference Line,参考线
RM      Room,房间
ROW      Right Of Way,路权
RQD      Rock Quality Designation,岩石品质指导
RR      Rail Road,铁路
RW      Retaining Wall,挡土墙
RWDP      Rain Water Down-Pipe,雨水落水管
S      Slope/Scale,坡度/比例
SB      Sound Barrier,隔音墙
SC      Point of Spiral to Curve,缓和曲线交点
SCH      Schedule ,时程
SCR      Station Control Room,车站控制室
SE      Super Elevation/Structure Engineering,超高/结构工程
SEL      Selection,选择
SFL      Structural Floor Level,结构楼版完工面
SG      Surrounding Ground,外围地面
SGL      Single,单一
SHC      Shotcrete,喷凝土
SHLD      Shoulder,路肩
SL      Sea Level,海平面
SM      Settlement Marker,沈陷计
SNR      Sanitary Napkin Receptacle,卫生纸收集箱
SNV      Sanitary Napkin Vending,卫生纸贩卖机
SOP      Setting Out Point,定位点
SP      Spiral/Steel Pipe,螺筋/钢管
SPA      Spacing,间距
SPEC      Specification,规范
SQ      Square,广场
SR      Settlement Rod,沈陷椿
SRC      Steel Reinforced Concrete,钢骨钢筋混凝土
SS      Stainless Steel,不锈钢
SSP      Stainless Steel Pipe,不锈钢管
ST      Street ,街
STA      Station,测站/桩号/车站
STIR      Stirrup,箍筋
STL      Steel,钢
STOR      Storage ,贮藏
STR      Stairs,楼梯
STT      Strain Transducer,应变感应计
SUSP      Suspended,悬吊式
SYM      Symmetrical,对称
SYS      System,系统
T&B      Top and Bottom,顶层及底层
T.H.      Top Height,上半断面
T.I.      Temporary Invert,临时仰拱
T/R      Top of Rail,轨道顶
T/W      Top of Wall,墙顶
TBM      Tunnel Boring Machine,全断面隧道钻掘机
TC      Point of Tangent to Curve,切线交点
TERR      Terrazzo,磨石子
THK      Thickness,厚
TI      Tiltmeter,倾斜计
TOC      Top of Concrete,混凝土顶面
TOG      Top of Grout,灌浆顶面
TOPO      Topography,地形图
TP      Turning Point,转点
TRAN      Transverse,横向
TS      Point of Tangent to Spiral,切线缓和曲线交点
TT      Point of Tangent to Tangent,切线与切线交点
U/G      Under Ground,地下
UD      Under Drain,下水道
UP      UP,向上
US      Unapparent Section,隐藏段面
UT      Utilities,公共管线/公共设施
VE      Value Engineering,价值工程
VEH BRG      Vehicular Bridge,车行桥
VEH U/P      Vehicular Underpass,车行地下道
VENT      Ventilation,通风
VERT      Vertical,垂直
VG      Vibrating Wire Strain Gauge,振动应变计
VOL      Volume,册/容量
VR      Vibrating Rod,振动杆
W      Window/Water Supply,窗/自来水
W/      With,含…/及…
W/C      Water Cement Ratio,水灰比
W/O      Without,不含….
WC      Water Closet,冲水马桶/厕所
WD      Wood,木料
WL      Water Level,水位/水平面
WP      Working Point,工作点
WS      Water Surface,水面
WT      Weight,重量
WWF      Weld Wire Fence,熔接钢丝网
WWL      Warning Water Level,警戒水位
板厚      GA,Gauge
半径      R,
保护层      CL.,Clearance
北      N,North
边界线      BL,Boundary Line
标记      MK,Mark
玻璃      GL,Glass
玻璃纤维化混凝土      GRC,Glassfiber Reinforced Concrete
玻璃纤维强化混凝土      GRC,Glass Reinforced Fiber Concrete
不含      W/O,Without
不锈钢      SS,Stainless Steel
不锈钢管      SSP,Stainless Steel Pipe
参考线      RL,Reference Line
册      VOL,Volume
厕所      WC,Water Closet
测炼      CH,Chainage
测站      STA,Station
层      FL,Floor
产权线      PL,Property Line
常水位,NWL      Normal Water Level
场铸混凝土      CIPC,Cast in Place Concrete
超高      SE,Super Elevation
车行地下道      VEH U/P,Vehicular Underpass
车行桥      VEH BRG,Vehicular Bridge
车站      STA,Station
车站控制室      SCR,Station Control Room
沉陷椿      SR,Settlement Rod
尺寸      DIM,Dimension
冲水马桶      WC,Water Closet
厨      CAB,Cabinet
窗      W,Window
垂直      PERP,Perpendicular
椿头打除      PCO,Pile Cut Off
单曲线起点      BC,Beginning of simple Circular Curve
单一      SGL,Single
挡土墙      RW,Retaining Wall
导向伸缩支承      GEB,Guided Expansion Bearing
导向运输系统      GW,Guide way
等距      EQ,Equal Space
低点      LP,Low Point
低强度混凝土      LC,Lean Concrete
低水位      LWL,Lower Water Level
底      BOT,Bottom
底层      BOT,Bottom
地板落水      FD,Floor Drainage
地板排水      FD,Floor Drainage
地基高程      GL,Ground Level
地面高程      GL,Ground Level
地面上      AG,Above Ground
地下      U/G,Under Ground
地下二层      B2,Second Basement
地下室      BSMT,Basement
地下水位      GWL,Ground Water Level
地下一层      B1,First Basement
地形图      TOPO,Topography
点      PT,Point
电扶梯      ESCA,Escalator
电缆槽      CT,Cable Trough
电梯      ELVR,Elevator
电子测距      EDM,Electronic Distance Measurement
顶层及底层      T&B,Top and Bottom
定位点      SOP,Setting Out Point
镀锌      GALV,Galvanized
镀锌铁管      GIP,Galvanized Iron Pipe
对称      SYM,Symmetrical
二楼      2F,Second Floor
反向      OPP,Opposite
方位角      AZ,Azimuth
房间      RM,Room
非导向伸缩支承,NGEB      Non-Guided Expansion Bearing
粉刷      FIN,Finished
粉刷装修地面完成面高程      FGL,Finished Ground Level
粉刷装修楼地板完成面高程      FFL,Finished Floor Level
盖板      -,FLASH
杆      DWL,Dowel
钢      STL,Steel
钢材容许应力      Fs,Allowable Tension Stress of Steel
钢材最低降伏应力强度      Fy,Minimum Yield Stress of Steel
钢骨钢筋混凝土      SRC,Steel Reinforced Concrete
钢骨混凝土      SRC,Steel Reinforced Concrete
钢管      SP,Steel Pipe
钢筋      REINF,Reinforcement
钢筋混凝土      RC,Reinforced Concrete
钢筋混凝土管      RCP,Reinforced Concrete Pipe
钢筋混凝土墙      RCW,Reinforced Concrete Wall
钢筋混凝土箱涵      RCB,Reinforced Concrete Box
钢筋应变计      RG,Reinforcing Bar Strain Gauge
高程      EL,Elevation
高点      HP,High Point
高拉力钢索      HTS,High Tensile Strand
高拉力钢线      HTW,High Strength Wire
高水位      HWL,High Water Level
高速公路      FWY.,Freeway
隔音      ACOUS,Acoustical
隔音墙      SB,Sound Barrier
工作点      WP,Working Point
公共管线      UT,Utilities
公共设施      UT,Utilities
公路      HWY,Highway
箍筋      STIR,Stirrup
观测井      OW,Observation Well
灌浆顶面      TOG,Top of Grout
广场      SQ,Square
规范      SPEC,Specification
轨道顶      T/R,Top of Rail
轨道高程      RAL,Rail Level
轨距      GA,Gauge
滚动支承      RR,Roller
海平面      SL,Sea Level
含      W/,With
荷重计      LoC,Load Cell
恒重      DL,Dead Load
横断面交趾点      HC,Heel of Crossing
横向      TRAN,Transverse
厚      THK,Thickness
户外长形座椅      B,Bench
化妆室      LAV,Lavatory
缓和曲线长      LS,Length of Spiral
缓和曲线交点      SC,Point of Spiral to Curve
缓曲线起点      CS,Point of Curve to Spiral
混凝土      CONC,Concrete
混凝土顶面      TOC,Top of Concrete
混凝土空心砖      CMU,Concrete Molded Unit
混凝土砌卵石      CGR,Concrete Grouted Rock
混凝土容许抗压强度      Fc,Allowable Compressive Strength of Concrete
混凝土设计抗压强度      Fc',Compressive Strength of Concrete
混凝土砖      CMU,Concrete Masonry Unit
活载重      LL,Live Load
基础底面      BOF,Bottom Of Footing
及      W/,With
记号      MK,Mark
继续      CONT,Continuous
价值工程      VE,Value Engineering
间距      SPA,Spacing
交错      ALT,Alternative
交连点      IP,Intersection Point
铰接      HG,Hinged
阶梯踏高      R,Riser
接缝      JT,Joint
接线盒      JB,Junction Box
街      ST,Street
结构工程      SE,Structure Engineering
结构混凝土      SRC,Structure Reinforced Concrete
结构楼版完工面      SFL,Structural Floor Level
近侧面      NF      Near Face
进水井      INL,Inlet
警戒水位      WWL,Warning Water Level
净保护层      CL.,Clearance
净高线      CLL,Clearance Line
静重      DL,Dead Load
镜面粉刷      MF,Mirror Finish
开孔      OPNG,Opening
开挖      EXC,Excavation
开挖坡面      CS,Cutting Slope
克罗梭曲线      CLD,Clothoid
控制缝      CJ,Control Joint/Construction Joint
宽度      W,Width
立面      EL,Elevation(Height)
立视      ELEV,Elevation View
沥青混凝土      AC,Asphalt Concrete
梁      BM,Beam
临时仰拱      T.I.,Temporary Invert
楼板      FL,Floor
楼梯      STR,Stairs
路肩      SHLD,Shoulder
路权      ROW,Right Of Way
铝      ALUM,Aluminum
螺筋      SP,Spiral
锚栓      AB,Anchor Bolt
每个      EA,Each
明控覆盖工法      CCM,Cut and Cover Method
磨石子      TERR,Terrazzo
木料      WD,Wood
内径      ID,Inside Diameter
内面      I.F., Inner Face
挠曲点      CF,Point of Contra-flexure
排列      ALT,Alternative
排气      EXH,Exhaust
喷凝土      SHC,Shotcrete
平均海平面      MSL,Mean Sea Level
平均水位      MWL,Mean Water Level
平面段      A/G,At Grade
坡度/比例      S,Slope/Scale
普通混凝土      PCE,Plain Concrete
起动点      WP,Warm up Point
强化      REINF,Reinforcement
强力螺栓      HSB,High Strength Bolt
墙顶      T/W,Top of Wall
墙面线      WL,Wall Line
切线点      CT,Point of Curve to Tangent
切线缓和曲线交点      TS,Point of Tangent to Spiral
切线交点      TC,Point of Tangent to Curve
切线与切线交点      TT,Point of Tangent to Tangent
倾钭计      IPI,In Place Inclinometer
倾斜计      TI,Tiltmeter
曲线长      LCC,Length of Circular Curve
曲线连结点      CC,Point of Curve to Curve
全超高      F.S,Full Superelevation
全断面隧道钻掘机      TBM,Tunnel Boring Machine
人孔      HH,Handhole
人行地下道      PED U/P,Pedestrian Underpass
人行桥      PED BRIG,Pedestrian Bridge
人造花岗石      GPC,Granite Precast
容量      VOL,Volume
熔接钢丝网      WWF,Weld Wire Fence
上半断面      T.H.,Top Height
设计地面高程      DGL,Designed Ground Level
伸缩缝      EJ,Expansion Joint
沈陷计      SM,Settlement Marker
施工缝      CJ,Control Joint/Construction Joint
石膏版      GYP,Gypsum
石棉      GYP,Gypsum
石棉管      ACP,Asbestos Concrete Pipe
时程      SCH,Schedule
室      CAB,Cabinet
收缩缝      CONST JT,Construction Joint
竖曲线长      LVC,Length of Vertical Curve
竖曲线交点      PVI,Point of Vertical Intersection
竖曲线起点      BVC,Beginning of Vertical Curve
竖曲线中点      MVC,Middle of Vertical Curve
双向      EW,Even Way
水灰比      W/C,Water Cement Ratio
水面      WS,Water Surface
水平面      WL,Water Level
水平线      HL,Horizontal Line
水深      HW,Height of Water
水手交连点      HIP,Horizontal Intersection Point
水位      WL,Water Level
水压计      HYP,Hydraulic Piezometer
水准标准点      BM,Bench Mark
水准点      BM,Bench Mark
塑料管      PVCP,P.V.C. Pipe
台阶      B,Bench
替代      ALT,Alternative
天花板      CLG,Ceiling
铁路      RR,Rail Road
通风      VENT,Ventilation
通路 , 走廊      CORR,Corridor
投影图      PROJ      Projection
土木工程      CE,Civil Engineering
土压计      EP,Earth Pressure Cell
外侧面      OF,Out Side Face
外径,OD      Outside Diameter
外面,OF      Outer Face
外围地面      SG,Surrounding Ground
弯      BT,Bent
完成      FIN,Finish
帷幕墙      CW,Curtain Wall
卫生纸贩卖机      SNV,Sanitary Napkin Vending
卫生纸收集箱      SNR,Sanitary Napkin Receptacle
卫星定位系统      GPS,Global Positioning System
屋顶      RF,Roof
屋顶落水      RD,Roof Drainage
屋顶排水      RD,Roof Drainage
无筋混凝土      PCC,Portland Cement Concrete
西向      W,West
系统      SYS,System
下水道      UD,Under Drain
县乡道      LR,Local Road
现地高程      EGL,Existing Ground Level
现有铺面顶      ETP,Existing Top of Pavement
箱      CAB,Cabinet
箱涵      BOX,Box Culvert
详细      DET,Detail
向上      UP,UP
消防箱      FHC,Fire Hydrant Cabinet
新奥工法,NATM      New Austrian Tunnel Method
悬吊式      SUSP,Suspended
选择      SEL,Selection
压力计      PG,Pressure Gauge
岩锚      RB,Rock Bolt
岩石品质指导      RQD,Rock Quality Designation
仰拱      I,Invert
仰拱高      IE,Invert Elevation
一楼      1F,First Floor
阴井      CB,Catch Basin
隐藏段面      US,Unapparent Section
应变感应计      STT,Strain Transducer
雨水落水管      RWDP,Rain Water Down-Pipe
预力钢键坐标      CGS,Center of Gravity of Prestressing Tendons
预力混凝土      PC,Prestressed Concrete
预力混凝土管      PSCP,Prestressed Concrete Pipe
预留钢栓      DWL,Dowel
预留开孔      KO,Knock Out
预留开口      KO,Knock Out
预埋底板      EMB.PL,Embedded Plate
原地面线      OGL,Original Ground Level
月台      PF,Platform
月台终端      EOP,End of Platform
遮雨板      -,FLASH
振动杆      VR,Vibrating Rod
振动应变计      VG,Vibrating Wire Strain Gauge
支承      BRG,Bearing
支距      OFS,Offset
直径      DIA,Diameter
直通      STR,Straight
中心点,OC      On Center
中心线      CL,Center Line
重量      WT,Weight
重心      CGS,Center of Gravity of Prestressing Tendons
主站      MS,Main Station
主站,PS      Principal Station
贮藏      STOR,Storage
柱      COL,Column
柱箍筋      CT,Column Tie-bar
铸铁      CI,Cast Iron
铸铁管      C.I.P,Cast Iron Pipe
砖      BRK,Brick
转点      TP,Turning Point
桩号      STA,Station
自来水      W,Water Supply
纵坡      PG,Profile Grade
钻炸法      D&B,Drill and Blast
最高洪水位      HHWL,Highest High Water Level
 楼主| 发表于 2003-11-15 10:03:23 | 显示全部楼层
谢谢二楼支持!!!
GMT+8, 2026-11-5 10:57 , Processed in 0.438474 second(s), 37 queries , Gzip On.
