查看: 1541|回复: 3
[求助]:如何编写一个提取并修改有多个属性的块的值lisp程序!
发表于 2003-11-20 12:35:27 | 显示全部楼层 |阅读模式
发表于 2003-11-20 18:56:20 | 显示全部楼层
Vlisp/Lisp 论坛 aeo 斑竹帖过这个功能函数
发表于 2003-11-21 03:45:58 | 显示全部楼层
REFER TO THIS:
  1. (defun changeAttributes (lst / sset item atts ename i)
  2.   (setq i 0)
  3.   (setq sset (ssget "X" (list '(0 . "INSERT") (cons 2 (car lst)))))
  4.   (if sset
  5.     (repeat (sslength sset)
  6.       (setq ename (ssname sset i))
  7.       (setq i (+ 1 i))
  8.       (if (safearray-value
  9.             (setq atts
  10.                    (vlax-variant-value
  11.                      (vla-getattributes (vlax-ename->vla-object ename))
  12.                    )
  13.             )
  14.           )
  15.         (progn
  16.           (foreach item (cdr lst)
  17.             (mapcar
  18.               '(lambda (x)
  19.                  (if
  20.                    (= (strcase (car item))
  21.                       (strcase (vla-get-tagstring x))
  22.                    )
  23.                     (vla-put-textstring x (cdr item))
  24.                  )
  25.                )
  26.               (vlax-safearray->list atts)
  27.             )
  28.           )
  29.           (vla-update (vlax-ename->vla-object ename))
  30.         )
  31.       )
  32.     )
  33.   )
  34. )
提示:请用[代码]方法粘贴Lisp部分,我都改累累:)  eachy
发表于 2019-12-25 08:05:26 | 显示全部楼层
学习学习
GMT+8, 2026-11-22 09:11 , Processed in 0.378966 second(s), 16 queries , Gzip On, File On.
