查看: 815|回复: 2
[求助]:替换尺寸标注样式
发表于 2003-11-20 19:15:48 | 显示全部楼层 |阅读模式
我用以下方法来替换尺寸标注样式,(“Dim100”是事先定义好的尺寸标注样式名)
但运行完后只有一部分正确!另外一部分标注的样式名是替换了,可全局比例因子
不知何故都是1。请各位大侠指点。
  1. (defun C:ch(/ ss id n ent)
  2.   (setq ss (ssget '((0 . "DIMENSION"))))
  3.   (setq id 0  n (sslength ss))
  4.   (repeat n
  5.     (setq ent (entget (ssname ss id)))
  6.     (setq ent (subst (cons 3 "Dim100") (assoc 3 ent) ent))
  7.     (entmod ent)
  8.     (setq id (1+ id))
  9.   )
  10. )
已领礼包: 593个
发表于 2003-11-20 20:06:21 | 显示全部楼层
entmod 后面加一句
  1. (entupd ent)
复制代码
发表于 2003-12-7 06:02:45 | 显示全部楼层
VLISP可能更简捷些:
(defun C:test ()
  (setq ss (ssget '((0 . "DIMENSION"))) n 0)
  (setq nds (getstring "\New Dimstyle: "))
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (vla-put-stylename obj nds)
    (setq n (1+ n))
GMT+8, 2026-11-7 01:47 , Processed in 0.409927 second(s), 36 queries , Gzip On.
