查看: 1334|回复: 2
[LISP函数]:有无求算面积的lisp函数
发表于 2002-8-9 11:44:13 | 显示全部楼层 |阅读模式
我需要求算面积的lisp函数,给出几个点后得出所围面积。
功能和AuoCAD命令"area"同。
有谁能帮我啊!
发表于 2002-8-9 16:04:25 | 显示全部楼层
论坛上老又这样的问题,这样吧,我写一段
;;; 借助辅助线计算面积
;;; 作者:刘长清
(defun  c:parea( / pt pt1 pt-list cmdvar)
   (setq  pt 1 pt-list nil)
   (while pt
       (setq pt (getpoint "\n输入范围点<完成>:"))
       (if pt
           (if (not pt-list)
               (setq pt-list (list pt))
               (setq pt-list (cons pt pt-list))
       (if (and pt1 pt)
         (grdraw pt1 pt 3 1)
       (setq pt1 pt)
   (if
      (> (length pt-list) 2)
      (progn
         (setq cmdvar (getvar "cmdecho" ))
         (setvar "cmdecho" 0)
         (command"pline")
         (foreach pn pt-list (command pn))
         (command"c")
         (command"area" "e" "l" "erase" "l" "")
         (princ "\n刚确定范围的面积 = ")
         (princ (getvar "area"))
         (setvar "cmdecho" cmdvar)
       (princ "\n输入的点数不够。")
   (redraw)
   (princ)
发表于 2002-9-6 13:56:16 | 显示全部楼层
用area命令计算后,计算结果保存在系统变量area中,读出变量的值即可
GMT+8, 2026-11-3 02:44 , Processed in 0.637043 second(s), 36 queries , Gzip On.
