查看: 1110|回复: 4
[求助]:怎么画局部放大最快,最方便?
发表于 2003-11-23 16:20:41 | 显示全部楼层 |阅读模式
我是CAD新手,请问怎么能最方便得画出一个零件的局部放大,包括标注,如果一个局部放大是圆形的,又怎么把它圈进块里?
我看了以前的好贴,就只说一张图画两个不同的比例,我只知道了一点可以用测量放大和不同的布局来实线。但这是局部放大,请高手指点,谢谢。
发表于 2003-11-23 18:00:05 | 显示全部楼层
http://www.xdcad.net/forum/showt ... d=476670#post476670
  2.   <tr>
  4.       <iframe name="I1" width="100%" height="100%" src="http://www.xdcad.net/forum/showthread.php?postid=476670#post476670">
  5. 浏览器不支持嵌入式框架或配置为不显示嵌入式框架
  6.       </iframe>
  7.     </td>
  8.   </tr>
  9. </table>
复制代码
 楼主| 发表于 2003-11-23 18:22:25 | 显示全部楼层
已看,谢谢。
我真笨还是有点不太清楚。等我再试试
发表于 2003-11-24 05:19:57 | 显示全部楼层
TRY THIS CODE:
(defun c:detail ()
  (vl-load-com)
  (setvar "osmode" 0)
  (setq ent (entsel "\nSelect Boundary:")
         p1 (cadr ent)
        ent (car ent))
  (vl-cmdf "divide" ent 60)
  (setq pg (ssget "x" '((0 . "POINT"))))
  (setq n 0)
  (while (< n (sslength pg))
    (setq en (entget (ssname pg n)))
    (setq pl (append pl (list (cdr (assoc 10 en)))))
    (setq n (1+ n))
  (vl-cmdf "erase" pg "")
  (setq ss (ssget "cp" pl))
  (vl-cmdf "copy" ss "" p1 p1)
  (setq p2 (getpoint p1 "\nPut Detail at:"))
  (vl-cmdf "move" ss ent "" p1 p2)
  (setq n 0)
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (setq p3 (vlax-curve-getstartpoint obj))
    (setq p4 (vlax-curve-getendpoint obj))
    (if (ptinters obj (vlax-ename->vla-object ent) 2)
      (progn
        (setq pp (car (ptinters obj (vlax-ename->vla-object ent) 2)))
        (if (> (distance p2 p3)(distance p2 p4))(setq p4 p3))
        (vl-cmdf "_trim" ent "" p4 "")
    (setq n (1+ n))
  (vl-cmdf "text" (getpoint "\nInput Detail point:")(* (getvar "dimscale") 0.18) 0 "DETAIL A" "")
  (vl-cmdf "erase" ent "")
  (setvar "osmode" 37)
  (princ)
发表于 2018-1-18 11:41:19 | 显示全部楼层
学习了
GMT+8, 2026-11-4 01:54 , Processed in 0.450299 second(s), 40 queries , Gzip On.
