查看: 793|回复: 2
[求助]:在cad中用程序怎么实现输入两个三维点,输入半径,画一个圆柱体?
发表于 2003-11-26 21:14:00 | 显示全部楼层 |阅读模式
发表于 2003-11-27 05:43:27 | 显示全部楼层
REFER TO:
(vl-cmdf "cylinder" pt r h)
发表于 2003-11-30 22:51:54 | 显示全部楼层
我写了一段代码.
  1. (defun c:cc(/ p1 p2 h r)
  2.   (setq p1 (getpoint "请输入圆柱底面圆心:"))
  3.   (setq p2 (getpoint p1 "\n请输入圆柱顶面圆心:"))
  4.   (setq h (distance p1 p2))
  5.   (setq r (getdist p1 "\n请输入圆柱半径:"))
  6.   (setq oldos (getvar "osmode"))
  7.   (setvar "osmode" 0)
  8.   (command "ucs" "za" p1 p2)
  9.   (command "cylinder" "0,0,0" r h)
  10.   (command "ucs" "P")
  11.   (setvar "osmode" oldos)
  12.   (princ)
  13. )
GMT+8, 2026-11-3 12:45 , Processed in 0.505938 second(s), 36 queries , Gzip On.
