查看: 1486|回复: 8
[求助]:如何画零件的局部放大图?
发表于 2003-12-3 18:27:48 | 显示全部楼层 |阅读模式
如何画零件的局部放大图?还如何标注零件的表面粗糙度?谢谢!
已领礼包: 3657个
发表于 2003-12-3 19:34:55 | 显示全部楼层
你周围应该有样图的啊,在想要画局部放大图的地方用一个圆标示,将零件包起来,在旁边注示标记,如A,然后画一大比例的图,图注:A点大样图
表面粗糙度最近两天刚说过,查找一下吧
 楼主| 发表于 2003-12-3 20:13:47 | 显示全部楼层
要重新再画一个放大图哦.我以为有什么直接放大命令.
发表于 2003-12-3 20:20:47 | 显示全部楼层
有!使用清华天河2002!里面有很多辅助工具!可以按比例局部放大。
发表于 2003-12-4 04:56:01 | 显示全部楼层
局部放大图请参考:
(defun c:detail ( / pl ss ex p1 p2 pts pg)
  (vl-load-com)
  (setvar "osmode" 0)
  (setq ent (entsel "\nSelect Boundary:")
         p1 (cadr ent)
        ent (car ent))
  (vl-cmdf "divide" ent 60)
  (setq pg (ssget "x" '((0 . "POINT"))))
  (setq n 0)
  (while (< n (sslength pg))
    (setq en (entget (ssname pg n)))
    (setq pl (append pl (list (cdr (assoc 10 en)))))
    (setq n (1+ n))
  (vl-cmdf "erase" pg "")
  (setq ss (ssget "cp" pl))
  (vl-cmdf "copy" ss "" p1 p1)
  (setq p2 (getpoint p1 "\nPut Detail at:"))
  (if (null (getreal "\nInput Radio:<2>"))(setq s 2.0))
  (vl-cmdf "move" ss ent "" p1 p2)
  (setq n 0)
  (while (< n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss n)))
    (setq p3 (vlax-curve-getstartpoint obj))
    (setq p4 (vlax-curve-getendpoint obj))
    (if (ptinters obj (vlax-ename->vla-object ent) 2)
      (progn
        (setq pp (car (ptinters obj (vlax-ename->vla-object ent) 2)))
        (if (> (distance p2 p3)(distance p2 p4))(setq p4 p3))
        (vl-cmdf "_trim" ent "" p4 "")
    (setq n (1+ n))
  (vl-cmdf "_scale" ss ent "" p2 s)
  (vl-cmdf "text" (getpoint "\nInput Detail point:")(* (getvar "dimscale") 0.18) 0 "DETAIL A" "")
  (vl-cmdf "erase" ent "")
  (setvar "osmode" 37)
  (princ)
表面粗糙度请参考:
http://www.xdcad.net/forum/showt ... amp;threadid=119742
发表于 2003-12-4 12:00:24 | 显示全部楼层
你是说比例缩放吧?把想要画的局部图复制一下按比例放大后,剪掉不要的不就行了吗?
发表于 2018-1-18 11:48:21 | 显示全部楼层
可以按比例局部放大
发表于 2018-3-24 19:28:16 | 显示全部楼层
如果是实体模型的话,用 viewbase 命令生成基本视图,再右击选择截面/局部视图
已领礼包: 2826个
财富等级: 家财万贯
发表于 2018-11-11 00:05:39 | 显示全部楼层
看一看,学习学习。
GMT+8, 2026-11-3 20:15 , Processed in 0.514195 second(s), 48 queries , Gzip On.
