查看: 650|回复: 1
[编程申请]:删除多个层上的所有图元
发表于 2003-12-9 20:09:06 | 显示全部楼层 |阅读模式
可以此删除多个层上的所有图元,对精简你的DWG文件大有用处。
;;; DELLAYER.LSP
;;;   Copyright (C) 1990 by Autodesk, Inc.
;;;   Permission to use, copy, modify, and distribute this software and its
;;;   documentation for any purpose and without fee is hereby granted.
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY.
;;;   ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF
;;;   MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;; DESCRIPTION
;;;   This program deletes all entities on specified layers.  Wildcards
;;;   can be specified.
(defun dellerr (s)                    ; If an error (such as CTRL-C) occurs
                                      ; while this command is active...
  (if (/= s "Function cancelled")
    (princ (strcat "\nError: " s))
  (setq S nil)                        ; Free selection-set if any
  (setvar "CMDECHO" ocmd)             ; Restore saved mode
  (setq *error* olderr)               ; Restore old *error* handler
  (princ)
;;; ------------------------- Main Program -----------------------------------;
(defun C:DELLAYER (/ olderr ocmd L S)
  (setq olderr *error*
        *error* dellerr)
  (setq ocmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (setq L (strcase (getstring "\nLayer(s) to delete: ")))
  ;; Get all entities on layer(s)
  (setq S (ssget "X" (list (cons 8 L))))
  (if S
    (command "ERASE" S "")            ; Delete 'em!
    (princ "Layer empty or not a valid layer name.")
  (princ)
发表于 2003-12-10 03:40:38 | 显示全部楼层
1.不是[编程申请] 应为 [转贴]
2. 这个程序以前好像贴出
GMT+8, 2026-11-7 01:47 , Processed in 0.443647 second(s), 34 queries , Gzip On.
