查看: 1071|回复: 2
[VBA程序]:怎么办?
发表于 2002-8-28 14:01:36 | 显示全部楼层 |阅读模式
有如下程序,原意图对一组尺寸进行处理,当尺寸值为100(〉99,<101)
时,将其删除
在程序执行时,遇到自动化错误
经查,缘由尺寸创建时非ALIGNED
而是水平,或垂直标注
单VBA没有提供对这样的尺寸的对象,我该怎么办
程序代码如下:
Public Sub test()
  Dim ss1 As AcadSelectionSet
  Dim mydim As AcadDimAligned
  Dim filtertype(0) As Integer
  Dim filterdata(0) As Variant
  filtertype(0) = 0
  filterdata(0) = "DIMENSION"
  Call Module10.bulidselction(ss1, 1) '创建选择集
  Dim i As Integer
    Call ss1.SelectOnScreen(filtertype, filterdata)
  For i = 0 To ss1.Count - 1
    Set mydim = ss1(i)
        If mydim.Measurement > 99 And mydim.Measurement < 101 Then
            mydim.Delete
        Else
        End If
Next i
End Sub
发表于 2002-9-1 17:04:03 | 显示全部楼层
仔细阅读,找出差别
  1. Public Sub test()
  2.     Dim ss1 As AcadSelectionSet
  3.     Dim mydim As AcadEntity
  4.     Dim filtertype(0) As Integer
  5.     Dim filterdata(0) As Variant
  6.     filtertype(0) = 0
  7.     filterdata(0) = "DIMENSION"
  8.     Call Module10.bulidselction(ss1, 1)    '创建选择集
  9.     Dim i As Integer
  10.     Call ss1.SelectOnScreen(filtertype, filterdata)
  11.     For i = 0 To ss1.Count - 1
  12.         Set mydim = ss1(i)
  13.         If mydim.ObjectName = "AcDbAlignedDimension" Or mydim.ObjectName = "AcDbRotatedDimension" Then
  14.             If mydim.Measurement > 99 And mydim.Measurement < 101 Then
  15.                 mydim.Delete
  16.             Else
  17.             End If
  18.         End If
  19.     Next i
  20. End Sub
 楼主| 发表于 2002-9-1 20:04:21 | 显示全部楼层
谢斑竹,后来我查阅了acad的帮助信息,
发现了AcDbRotatedDimension对象
我的解决方法如下:
Public Sub test()
  Dim mydim2 As AcadDimRotated
  filtertype(0) = 0
  Dim i As Integer
    If ss1(i).ObjectName = "AcDbAlignedDimension" Then
        Set mydim = ss1(i)
                mydim.Delete
            Else
            End If
    Else
        Set mydim2 = ss1(i)
        If mydim2.Measurement > 99 And mydim2.Measurement < 101 Then
                mydim2.Delete
            Else
            End If
    End If
Next i
End Sub
GMT+8, 2026-11-22 09:55 , Processed in 0.256615 second(s), 14 queries , Gzip On, File On.
