查看: 1078|回复: 1
修改外部DWG文件,给所有LINE加扩展数据的完整的ARX代码 by XDSoft
已领礼包: 444个
发表于 2002-1-24 18:35:52 | 显示全部楼层 |阅读模式
给ACAD增加个命令,修改外部DWG文件,给所有LINE加扩展数据的完整的ARX代码
#include <aced.h>
#include <acestext.h>      // acadErrorStatusText
#include <adslib.h>
#include <dbents.h>        // AcDbCircle
#include <dbsymtb.h>
#include <geassign.h>      // asDblArray
* Register an application for xData
* In :
*    AcDbDatabase* pDb      : Database
*  const char* pAppName  : application name
*  Adesk::Boolean exclude :
*      If exclude == Adesk::kTrue, then xData associated with
*      this AcDbRegAppTableRecord will not be saved when the
*      drawing is saved as a release 12 (R12) drawing.
*      If exclude == Adesk::kFalse, the data will be saved
*      during a saveAsR12 operation.
Acad::ErrorStatus
registerApp(AcDbDatabase* pDb, const char * pAppName,Adesk::Boolean exclude =
Adesk::kFalse)
    AcDbRegAppTable* pAppTable;
    Acad::ErrorStatus es;
    // get the RegAppTable
    if((es = pDb->getRegAppTable(pAppTable,AcDb::kForWrite)) != Acad::eOk)
     return es;
    // if RegAppTable has application already - fine
    if(pAppTable->has(pAppName))
     pAppTable->close();
     return Acad::eOk;
    AcDbRegAppTableRecord* pAppTableRecord = new AcDbRegAppTableRecord();
    pAppTableRecord->setExcludeFromSaveAsR12(exclude);
    pAppTableRecord->setName(pAppName);
    if((es = pAppTable->add(pAppTableRecord)) != Acad::eOk)
     delete pAppTableRecord;
     pAppTable->close();
     return es;
    pAppTableRecord->close();
    pAppTable->close();
    return es;
* Add to all lines in model space a point as xData
Acad::ErrorStatus
addXDataToAllLines(AcDbDatabase* pDb,const char *pAppName)
    AcDbBlockTable *pBlockTable;
    AcDbBlockTableRecord *pModelSpace;
    if((es = pDb->getBlockTable(pBlockTable,AcDb::kForRead)) != Acad::eOk)
     return es;
    if((es = pBlockTable->getAt(ACDB_MODEL_SPACE,pModelSpace,AcDb::kForRead))
Acad::eOk)
     pBlockTable->close();
     return es;
    AcDbBlockTableRecordIterator *pIter;
    if((es = pModelSpace->newIterator(pIter)) != Acad::eOk)
     pModelSpace->close();
     return es;
    AcDbEntity* pEnt;
    AcDbLine* pLine;
    for(;!pIter->done();pIter->step())
     if(pIter->getEntity(pEnt,AcDb::kForRead) != Acad::eOk)
        continue;
     pLine = AcDbLine::cast(pEnt);
     if(pLine)
        struct resbuf* xdata;
        AcGePoint3d pntToAttach = pLine->startPoint();
        xdata =
ads_buildlist(1001,pAppName,1011,asDblArray(pntToAttach),0);
        pLine->upgradeOpen();
        if((es = pLine->setXData(xdata)) != Acad::eOk)
         ads_printf("\nsetXData failed : es =
%s",acadErrorStatusText(es));
        ads_relrb(xdata);
     pEnt->close();
    delete pIter;
    return Acad::eOk;
void addXDataToExternalDb()
    char* filename = "c:\\temp\\test.dwg";
    char* appName = "AcDcApp";
    AcDbDatabase *pDb = new AcDbDatabase(Adesk::kFalse);
    if((es = pDb->readDwgFile(filename)) != Acad::eOk)
     ads_printf("\nreadDwgFile failed for %s : es =
%s",filename,acadErrorStatusText(es));
     return;
    if((es = registerApp(pDb,appName)) != Acad::eOk)
     ads_printf("\nregisterApp failed : es = %s",acadErrorStatusText(es));
    addXDataToAllLines(pDb,appName);
    pDb->saveAs("c:\\temp\\test2.dwg");
    delete pDb;
void initApp()
    acedRegCmds->addCommand("TEST",
              "addx",
              "addx",
              ACRX_CMD_MODAL,
              &addXDataToExternalDb);
void unloadApp()
    acedRegCmds->removeGroup( "TEST" );
extern "C" AcRx::AppRetCode acrxEntryPoint( AcRx::AppMsgCode msg, void* p )
    switch (msg) {
    case AcRx::kInitAppMsg:
     acrxUnlockApplication( p );
     initApp();
     break;
    case AcRx::kUnloadAppMsg:
     unloadApp();
     break;
    default:
     break;
    return AcRx::kRetOK;
已领礼包: 1261个
发表于 2005-11-26 01:41:07 | 显示全部楼层
能写个使用说明吗?刚学习,不太懂
GMT+8, 2026-11-6 00:55 , Processed in 0.512131 second(s), 34 queries , Gzip On.
