查看: 2595|回复: 0
[分享] 计算几何的一些函数模板
发表于 2013-6-15 02:12:44 | 显示全部楼层 |阅读模式
struct point
double x,y;
double max(double x,double y)
return (x>y)?x:y;
double min(double x,double y)
return (x<y)?x:y;
//浮点精度处理,三出口函数
int dblcmp(double d)
if (fabs(d)<precision) return 0;
return (d>0)?1:-1;
//叉积
double det(double x1,double y1,double x2,double y2)
return x1*y2-x2*y1;
double cross(struct point a,struct point b,struct point c)
return det(b.x-a.x,b.y-a.y,c.x-a.x,c.y-a.y);
//叉积
//点积(使用较少)
double dotdet(double x1,double y1,double x2,double y2)
return x1*x2+y1*y2;
double dot(struct point a,struct point b,struct point c)
return dotdet(b.x-a.x,b.y-a.y,c.x-a.x,c.y-a.y);
点积的三点共线判定
int betweencmp(struct point a,struct point b,struct point c)
return dblcmp(dot(a,b,c));
//点积(使用较少)
//判断a在不在bc范围内
int xycmp(double p,double mini,double maxi)
return dblcmp(p-mini)*dblcmp(p-maxi);
if (fabs(b.x-c.x)>fabs(b.y-c.y))
   return xycmp(a.x,min(b.x,c.x),max(b.x,c.x));
else return xycmp(a.y,min(b.y,c.y),max(b.y,c.y));
//判断a在不在bc范围内
GMT+8, 2026-11-22 07:57 , Processed in 0.290928 second(s), 11 queries , Gzip On, File On.
