查看: 2226|回复: 0
[分享] 如何创建命名UCS并设置到当前的ARX代码
发表于 2013-5-5 01:05:26 | 显示全部楼层 |阅读模式
[sell=5]
[pcode=cpp,true]//This program shows how to create named ucs and set it current
//Author I. R. Nagwani
//Developer Consulting Group, Autodesk
//Date Written 8-12-99
#include "dbsymtb.h"
#include "rxregsvc.h"           // ARX linker
#include "dbapserv.h"           // Host application services
#include "acdb.h"               // acdb definitions
#include "aced.h"               // aced stuff
#include "adslib.h"             // RXADS definitions
// This command registers an ARX command.
void AddCommand(const char* cmdGroup, const char* cmdInt, const char* cmdLoc,
                                const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal = -1);
// NOTE: DO NOT edit the following lines.
//{{AFX_ARX_MSG
void InitApplication();
void UnloadApplication();
//}}AFX_ARX_MSG
//{{AFX_ARX_ADDIN_FUNCS
//}}AFX_ARX_ADDIN_FUNCS
void asdktest()
        Acad::ErrorStatus es;
        AcDbUCSTableRecord *myUCS = new AcDbUCSTableRecord;
        //define your own ucs
        AcGePoint3d  origin_point(0,0,0);
        AcGeVector3d UCSXaxis(0,1,0);
        AcGeVector3d UCSYaxis(1,0,0);
        myUCS->setOrigin(origin_point);
        myUCS->setXAxis(UCSXaxis);
        myUCS->setYAxis(UCSYaxis);
        es=myUCS->setName( "MyUCS");
        if (es != Acad::eOk)
                acutPrintf("\nFailed to set name");
                return;
        AcDbObjectId UCSId;
        AcDbSymbolTable *pUCSTable;
        if (acdbHostApplicationServices()->workingDatabase()->getUCSTable(pUCSTable,AcDb::kForWrite)==Acad::eOk)
                es=pUCSTable->add(UCSId,myUCS);
                es=pUCSTable->close();
                es= myUCS->close();
        else
                acutPrintf("\nFailed to get UCS table");
                return;
        //To set the current UCS, I accessed the active AcDbViewportTableRecord
        // and used setUCS to set the UCS I created as current.
        AcDbViewportTable *pVT;
        es = acedVports2VportTableRecords();
                acutPrintf("\nFailed to load vport info into vport table records");
                return;
        es=acdbHostApplicationServices()->workingDatabase()->getViewportTable(pVT,AcDb::kForRead);
                acutPrintf("\nFailed to get vport table");
                pVT->close();
                return;
        AcDbViewportTableIterator* pIter = NULL;
        es=pVT->newIterator(pIter);
                pVT->close();
                delete pIter;
                return;
        for (pIter->start();!pIter->done();pIter->step())
                AcDbViewportTableRecord* pRec;
                es=pIter->getRecord(pRec,AcDb::kForWrite); //it should be open for write mode
                        acutPrintf("\nFailed to get vport table record");
                        pVT->close();
                        pRec->close();
                        delete pIter;
                        return;
                char* name=NULL;
                es=pRec->getName(name);
                        acutPrintf("\nFailed to get name from vport table");
                        pVT->close();
                        pRec->close();
                        delete pIter;
                        return;
                if (stricmp(name,"*ACTIVE")==0)
                        es=pRec->setUcs(UCSId);
                es=pRec->close();
        es=acedVportTableRecords2Vports(); //force update
        es=pVT->close();
        delete pIter;
        return ;
// ObjectARX EntryPoint
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
        switch (msg) {
        case AcRx::kInitAppMsg:
                // Comment out the following line if your
                // application should be locked into memory
                acrxDynamicLinker->unlockApplication(pkt);
                acrxDynamicLinker->registerAppMDIAware(pkt);
                InitApplication();
                break;
        case AcRx::kUnloadAppMsg:
                break;
        return AcRx::kRetOK;
// Init this application. Register your
// commands, reactors...
        //{{AFX_ARX_INIT
        AddCommand("ASDK", "TEST", "TEST", ACRX_CMD_TRANSPARENT | ACRX_CMD_USEPICKSET, asdktest);
        //}}AFX_ARX_INIT
        // TODO: add your initialization functions
// Unload this application. Unregister all objects
// registered in InitApplication.
        //{{AFX_ARX_EXIT
        acedRegCmds->removeGroup("ASDK");
        //}}AFX_ARX_EXIT
        // TODO: clean up your application
// This functions registers an ARX command.
// It can be used to read the localized command name
// from a string table stored in the resources.
                                const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal)
        char cmdLocRes[65];
        // If idLocal is not -1, it's treated as an ID for
        // a string stored in the resources.
        if (idLocal != -1) {
                HMODULE hModule = GetModuleHandle("asdkucsarx.arx");
                // Load strings from the string table and register the command.
                ::LoadString(hModule, idLocal, cmdLocRes, 64);
                acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLocRes, cmdFlags, cmdProc);
        } else
                // idLocal is -1, so the 'hard coded'
                // localized function name is used.
                acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLoc, cmdFlags, cmdProc);
[/pcode]
[/sell]
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 技术引导讨论和指点奖!
查看全部评分
GMT+8, 2026-11-22 08:06 , Processed in 0.278509 second(s), 10 queries , Gzip On, File On.
