查看: 618|回复: 1
[LISP函数]:将多条多仪线宽度一起更改!
发表于 2003-12-31 19:27:09 | 显示全部楼层 |阅读模式
,r14中bonus的超强性质更改,可以一次修改很多线宽,
可是很不方面,我的问题是:
有谁有lsp程序,类似的matchprop那个命令那样,进行格式刷,那多方便!
发表于 2003-12-31 21:27:20 | 显示全部楼层
用这个程序,vba的
Sub jcx()
Dim a
On Error Resume Next
Dim i As Integer
Dim allobj As AcadEntity
Dim spnt As Variant
Dim epnt As Variant
Dim plineobj As AcadLWPolyline
Dim ver(0 To 3) As Double
For i = 0 To ThisDrawing.SelectionSets.Count - 1
ThisDrawing.SelectionSets.Item(i).Clear
ThisDrawing.SelectionSets.Item(i).Delete
Next
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("lineset")
sset.SelectOnScreen
If sset.Count = 0 Then Exit Sub
Dim w As String
w = ThisDrawing.Utility.GetString(1, vbCrLf & "请输入宽度:")
For Each allobj In sset
If allobj.ObjectName <> "AcDbLine" Then
allobj.ConstantWidth = w
End If
If allobj.ObjectName = "AcDbLine" Then
spnt = allobj.StartPoint
epnt = allobj.EndPoint
ver(0) = spnt(0): ver(1) = spnt(1)
ver(2) = epnt(0): ver(3) = epnt(1)
Set plineobj = ThisDrawing.ModelSpace.AddLightWeightPolyline(ver)
plineobj.ConstantWidth = w
allobj.Delete
End If
Next
Exit Sub
End Sub
GMT+8, 2026-11-5 02:29 , Processed in 0.444868 second(s), 34 queries , Gzip On.
