查看: 1792|回复: 2
[求助] [求助]请教高手,如何能把未定义成属性块的属性字快速批量更改?
发表于 2009-1-21 08:53:02 | 显示全部楼层 |阅读模式
因为用find命令又更改不了。如图
发表于 2009-1-21 10:35:06 | 显示全部楼层
  1. ;|
  2. ATTDEF DXF Example:
  3. (-1 . <图元名: 7ef63f88>)
  4. (0 . "ATTDEF")
  5. (330 . <图元名: 7ef63cf8>)
  6. (5 . "F1")
  7. (100 . "AcDbEntity")
  8. (67 . 0)
  9. (410 . "Model")
  10. (8 . "0")
  11. (100 . "AcDbText")
  12. (10 906.814 543.325 0.0)
  13. (40 . 2.5)
  14. (1 . "7-PS");_默认
  15. (50 . 0.0)
  16. (41 . 1.0)
  17. (51 . 0.0)
  18. (7 . "Standard")
  19. (71 . 0)
  20. (72 . 0)
  21. (11 0.0 0.0 0.0)
  22. (210 0.0 0.0 1.0)
  23. (100 . "AcDbAttributeDefinition")
  24. (3 . "图号");_提示
  25. (2 . "*PS");_标记
  26. (70 . 0)
  27. (73 . 0)
  28. (74 . 0)
  29. (-3 ("AcDbAttr" (1070 . 0) (1070 . 1)))
  30. |;
复制代码
[php]
;;修改纯属性文字 carrot1983 2009-01-21
(defun C:TT (/ ELIST I PATTERN NEW_V2 SS V1 V2 V3)
  (setq NEW_V2 "新标记") ;_新的标记值
  (setq PATTERN "*PS") ;_匹配的文字
  (if (setq SS (ssget (list (cons 0 "ATTDEF") (cons 2 PATTERN))))
    (repeat (setq I (sslength SS))
      (setq ELIST (entget (ssname SS (setq I (1- I)))))
      (setq V1 (cdr (assoc 1 ELIST)))
      (setq V2 (cdr (assoc 2 ELIST)))
      (setq V3 (cdr (assoc 3 ELIST)))
      ;; For example: Modify DXF 2
      (setq ELIST (subst (cons 2 NEW_V2)
                         (assoc 2 ELIST)
                         ELIST
      (entmod ELIST)
  (princ)
[/php]
 楼主| 发表于 2009-1-21 14:23:51 | 显示全部楼层
非常感谢carrot1983 !
GMT+8, 2026-11-22 09:06 , Processed in 0.735725 second(s), 14 queries , Gzip On, File On.
