查看: 587|回复: 2
[求助]:屋面梯间多塔 Ratx Raty输出异常
发表于 2004-2-7 10:37:41 | 显示全部楼层 |阅读模式
一个主体6层1个塔,结构层7层为3个屋面梯间,分为3个塔。计算结果到无大的出入,只是7层3塔的 Ratx、 Raty有点异常,如下:
Ratx =  9999.0000 是不是该塔下面无结构侧移,除零溢出;
此类工程屋面梯间是否设塔,如何设?
如不设塔应如何处理屋面梯间?
或是我的塔定义方法有误。我是这样定义的:起始层/终止层/塔数:7/7/3
谢谢!
  Floor No.   6     Tower No.   1
  Xstif=    29.7306(m)     Ystif=     5.4705(m)     Alf  =     0.0000(Degree)
  Xmass=    28.6524(m)     Ymass=     5.7006(m)     Gmass=   950.6406(t)
  Eex  =     0.0597        Eey  =     0.0124
  Ratx =     0.9679        Raty =     0.8861
  Ratx1=    17.8576        Raty1=    16.3498  薄弱层地震剪力放大系数= 1.00
  RJX  = 6.2921E+05(kN/m)  RJY  = 4.4468E+05(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   7     Tower No.   1
  Xstif=     7.2000(m)     Ystif=     3.0684(m)     Alf  =     0.0000(Degree)
  Xmass=     7.2570(m)     Ymass=     3.2516(m)     Gmass=    32.6057(t)
  Eex  =     0.0169        Eey  =     0.0496
  Ratx =     0.0700        Raty =     0.0765
  Ratx1=     1.2500        Raty1=     1.2500  薄弱层地震剪力放大系数= 1.00
  RJX  = 4.4044E+04(kN/m)  RJY  = 3.3997E+04(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   7     Tower No.   2
  Xstif=    25.2000(m)     Ystif=     3.0684(m)     Alf  =     0.0000(Degree)
  Xmass=    25.2570(m)     Ymass=     3.2516(m)     Gmass=    32.6057(t)
  Ratx =  9999.0000        Raty =  9999.0000
  RJX  = 4.7111E+04(kN/m)  RJY  = 3.6869E+04(kN/m)  RJZ  = 0.0000E+00(kN/m)
  Floor No.   7     Tower No.   3
  Xstif=    46.8000(m)     Ystif=     3.0684(m)     Alf  =     0.0000(Degree)
  Xmass=    46.8570(m)     Ymass=     3.2516(m)     Gmass=    32.6057(t)
  RJX  = 4.7714E+04(kN/m)  RJY  = 4.0701E+04(kN/m)  RJZ  = 0.0000E+00(kN/m)
发表于 2004-2-19 13:57:39 | 显示全部楼层
可不设塔,直接计算
发表于 2004-2-20 01:26:45 | 显示全部楼层
9999不对吧,检查一下模型。多塔定义没错,7/7/3,
GMT+8, 2026-11-4 03:03 , Processed in 0.576380 second(s), 36 queries , Gzip On.
