查看: 990|回复: 0
[日积月累]:几个表处理函数
已领礼包: 593个
发表于 2004-2-9 14:07:18 | 显示全部楼层 |阅读模式
  1. (defun a-values        (code lst)
  2.   (mapcar 'cdr
  3.           (vl-remove-if-not '(lambda (x) (= (car x) code)) lst)
  4.   )
  5. )
  6. (defun firstN (N L)
  7.   (cond        ((zerop N) nil)
  8.         ((>= n (length l)) l)
  9.         (T
  10.          (cons
  11.            (car L)
  12.            (firstN (1- N) (cdr L))
  13.          )
  14.         )
  15.   )
  16. )
  17. ;;(firstN  3 '(2 4 6 8 10 12))
  18. ;;=>(2 4 6)
  19. (defun nthcdr (N L)
  20.   (cond        ((zerop N) L)
  21.         (T (nthcdr (- N 1) (cdr L)))
  22.   )
  23. )
  24. ;;(nthcdr  3 '(4 5 6 7 8 9 ))
  25. ;;=> (7 8 9)
  26. (defun remove-member (a / ex)
  27.   (setq ex (vl-remove (car a) a))
  28.   (if (car a)
  29.     (cons (car a) (remove-member ex))
  30.   )
  31. )
  32. ;;_$ (remove-member '(1 2 2 3 2 3 4 2 1 2 3 4 2 2 4 1 2))
  33. ;;(1 2 3 4)
  34. ;;_$ (remove-member '("a" "df" "a" "we" "sf" "we" "a" "ee"))
  35. ;;("a" "df" "we" "sf" "ee")
  36. (defun vvl-remove (A L /)
  37.   (apply 'append
  38.          (mapcar '(lambda (x)
  39.                     (if        (not (equal x A))
  40.                       (list x)
  41.                     )
  42.                   )
  43.                  L
  44.          )
  45.   )
  46. )
GMT+8, 2026-11-3 10:19 , Processed in 0.440230 second(s), 32 queries , Gzip On.
