查看: 1001|回复: 5
[求助] [求助]:谁能给我个序号编号程序(1。2。3。。。)
发表于 2004-2-16 17:04:20 | 显示全部楼层 |阅读模式
发表于 2004-2-16 21:18:03 | 显示全部楼层
ET工具中有文本自动编号的工具。
发表于 2004-2-17 03:17:54 | 显示全部楼层
Re: [求助]:谁能给我个序号编号程序(1。2。3。。。)
最初由 xxming 发布
[B]谁能给我个序号编号程序(1。2。3。。。) [/B]
REFER TO:
(defun c:test ( / pe pe0)
  (setq p0 (getpoint "\nPick star point:"))
  (if inum nil (setq inum 1))
  ;(mlayer "dim" 4 "continous")
  (setq s (getvar "dimscale"))
  (while inum
    (if pe (setq pe0 pe))
    (setq pe (getpoint p0 "\nPick End Point"))
    (princ "\nItem Number or Break: n <")
    (princ inum)
    (setq inum0 (getstring ">:"))
    (if pe0
      (if (< (abs (- (car pe)(car pe0)))(abs (- (cadr pe)(cadr pe0))))
        (setq pe (list (car pe0)(cadr pe)))
        (setq pe (list (car pe)(cadr pe0)))
    (command "leader" p0 (polar pe (angle pe p0)(* s 0.32)) "" "" "n")
    (vl-cmdf "circle"  pe (* s 0.32))
    (if (= (type inum) 'STR)(setq inum (atoi inum)))
    (vl-cmdf "text" "j" "m" pe (* s 1.5 0.18) 0 (itoa inum) "")
    (setq p0 (getpoint "\nPick start Point"))
    (setq inum (1+ inum))
发表于 2004-2-19 09:20:47 | 显示全部楼层
发表于 2004-2-19 09:23:37 | 显示全部楼层
晓东工具箱里也有。
发表于 2004-3-5 22:51:31 | 显示全部楼层
GMT+8, 2026-11-4 06:24 , Processed in 0.757729 second(s), 42 queries , Gzip On.
