查看: 1553|回复: 5
[ARX程序]:命令的屏蔽
发表于 2002-9-22 14:12:17 | 显示全部楼层 |阅读模式
xd,你好,我做一模块要对用户进行CAD命令权限控制,那么怎样能对命令的禁止呢?
发表于 2002-9-23 13:10:18 | 显示全部楼层
这么黑?
方法很多,但这么作有必要吗?你屏蔽别人,所以这个问题好多人不愿意回答。
发表于 2002-9-23 15:15:26 | 显示全部楼层
用反应器可以吗??
已领礼包: 145个
发表于 2002-9-23 18:52:32 | 显示全部楼层
替换ACAD的内部命令的方法
给你贴篇ADN资料,替换ACAD的内部命令的方法
  1. Replacing Acad's Internal Commands
  2. ID    1957
  3. Applies to:    AutoCAD
  4. AutoCAD 2000I
  5. AutoCAD R14
  6. Date    12/24/2001
  7. This document is part of    AcEd
  8. Question
  9. How do I define my own commands that replace AutoCAD's ?
  10. Answer
  11. The ObjectARX API doesn't provide an ARX method to override an AutoCAD internal
  12. command. This can only be achieved by using the "UNDEFINE" command. In the following
  13. sample, undocumented function acedPostCommand() is used to post a lisp expression
  14. that uses the UNDEFINE command to undefine the "OPEN" and "SAVEAS" command.
  15. Also, ObjectARX does provide two functions to undefine certain type of commands,
  16. they are:
  17. 1)  acedUndef()
  18. Undefines a function (an AutoLISP external function) that was previously defined
  19. by a call to acedDefun().
  20. 2) acedCmdUndefine().
  21. acedCmdUndefine only works with ARX registered commands.
  22. For example, if you want to override OPEN and SAVEAS commands, you need to do
  23. the following:
  24. // declare the following function
  25. int acedPostCommand(const char*);
  26. // place the following lines in acrxEntryPoint()'s case AcRx::kInitAppMsg:
  27.   case AcRx::kInitAppMsg:
  28.   acedPostCommand("(command "_undefine" "_open") ");
  29.   acedPostCommand("(command "_undefine" "_saveas") ");
  30. // ** do this always **
  31.   acedRegCmds->addCommand("MYCOMMAND_GRP", "OPEN", "_OPEN", ACRX_CMD_MODAL, rx_open);
  32.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVE", "_SAVE",  ACRX_CMD_MODAL, rx_saveAs);
  33.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVEAS", "_SAVEAS", ACRX_CMD_MODAL, rx_saveAs);
  34. #include <afxdlgs.h>
  35. void rx_open()
  36. {
  37.   CFileDialog FDialog (TRUE, "dwg", "",OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT, _T("AutoCAD Drawing Files (*.dwg)|*.dwg||"));
  38.
  39.   if (FDialog.DoModal() == IDOK)
  40.   {
  41.    char* pFile = new char[512];
  42.    strcpy(pFile, FDialog.GetPathName());
  43.    if(acedSyncFileOpen(pFile) != Acad::eOk)
  44.     acutPrintf("\nError open drawing file.");
  45.    delete [] pFile;
  46.   }
  47. }
  48. void rx_saveAs()
  49. {
  50.   CFileDialog FDialog (FALSE, "dwg", "",
  51.    OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT,
  52.    _T("Save AutoCAD Drawing File As (*.dwg)|*.dwg||"));
  53.
  54.   if (FDialog.DoModal() == IDOK)
  55.   {
  56.    char* pFile = new char[512];
  57.    strcpy(pFile, FDialog.GetPathName());
  58.    // user can obtain the database object through readDwgFile()
  59.    // for an external database
  60.    AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
  61.    if(pDb->saveAs(pFile) != Acad::eOk)
  62.     acutPrintf("\nError saving drawing file.");
  63.    //clean up
  64.    delete [] pFile;
  65.   }
  66. }
  67. Note:
  68. 1) You can always use the original native ACAD command by prefixing the command
  69. name with a "." even if it is already undefined.
  70. 2) The above code runs only in SDI mode due to the use of acedSyncFileOpen() method.
 楼主| 发表于 2002-9-25 09:33:57 | 显示全部楼层
我做的这个项目用Oracle作为数据后台的,所以设置了用户权限,系统管理员可以根据登录用户也设置他的命令集呀,所以要进行CAD命令权限控制,这并没有和黑有关呀。
 楼主| 发表于 2002-9-25 09:57:00 | 显示全部楼层
undefine命令,这样对于一般的用户是可以这样做的,但是对于CAD很熟练的人来说那很不安全的,再说我要求的是对登录用户的某些CAD命令的禁止,我也到ADN网站看了,那里说了有三种方法,一就是undefine/二就是用钩子函数,三就是在编辑反应器的veto();
我最初是就是用反应器的,但veto()在AcEditorReactor::commandWillStart(const char * cmdStr)内不能被调用。不知为什么?还请指教
GMT+8, 2026-11-3 00:32 , Processed in 0.524935 second(s), 42 queries , Gzip On.
