查看: 3637|回复: 4
[分享]:"图块改名" 和"图块单独改名"
发表于 2004-2-25 00:12:52 | 显示全部楼层 |阅读模式
  1. ;;;=======================
  2. ;;;图块改名.
  3. ;;;无名块改名后,再改出错.
  4. ;;;By Aeo
  5. ;;;-----------------------
  6. (defun C:TTt ( / blk blkref blocks doc new-blk new-name old-blk old-name)
  7.   (vl-load-com)
  8.   (if(and (setq BLK     (car (entsel "\n选要改名的块: ")))
  9.           (setq BLKREF  (vlax-ename->vla-object BLK))
  10.           (= (vla-get-objectname BLKREF) "AcDbBlockReference")
  11.           (setq old-name(vla-get-name BLKREF))
  12.           (/= ""(setq new-name(getstring (strcat"\n新名称(" old-name "): "))))
  13.           (not(and(= new-name "*")(princ"\n名称可以为*加任意字母")))
  14.           (not(and(tblsearch "block"new-name)(princ"\n图块已存在.")))
  15.       )
  16.       (progn
  17.           (command"undo""group")
  18.           (setq DOC     (vla-get-activedocument (vlax-get-acad-object))
  19.                 BLOCKS  (vla-get-blocks doc)
  20.                 old-blk (vla-item BLOCKS old-name)
  21.           )
  22.           (vla-put-name old-blk new-name)
  23.         (if(wcmatch old-name "`**")
  24.           (progn
  25.            (setq new-BLK (vla-add BLOCKS (vla-get-origin old-blk)new-name))
  26.            (vlax-for ENT old-blk
  27.              (vla-copyobjects  DOC
  28.                 (vlax-safearray-fill
  29.                   (vlax-make-safearray vlax-vbobject '(0 . 0))
  30.                   (list ENT)
  31.                 )
  32.                 new-BLK
  33.             ))
  34.            (vlax-release-object new-BLK)
  35.            )
  36.          )
  37.         (vlax-release-object old-blk)
  38.         (vlax-release-object BLOCKS)
  39.         (vlax-release-object DOC)
  40.         (command"undo""end")
  41.      )
  42.   )
  43.   (prin1)
  44. )
临时想把块中的一个换个名称:
  2. ;;;图块改名拷贝,点到的那个块改成新名称,
  3. ;;;但其他同名块不变.
  4. ;;;By Aeo
  6. (defun C:TT ( / blk blkref blocks doc new-blk new-name old-blk old-name)
  7.   (vl-load-com)
  13.           (not(and(= new-name "*")(princ"\n名称可以为*加任意字母,变为匿名块")))
  15.       )
  16.       (progn
  21.           )
  22.            (setq new-BLK (vla-add BLOCKS (vla-get-origin old-blk)new-name))
  23.            (vlax-for ENT old-blk
  24.              (vla-copyobjects  DOC
  25.                 (vlax-safearray-fill
  26.                   (vlax-make-safearray vlax-vbobject '(0 . 0))
  27.                   (list ENT)
  28.                 )
  29.                 new-BLK
  30.             ))
  31.         (vla-put-name BLKREF new-name)
  32.         (vlax-release-object new-BLK)
  33.         (vlax-release-object old-blk)
  34.         (vlax-release-object BLOCKS)
  35.         (vlax-release-object DOC)
  36.         (command"undo""end")
  37.      )
  38.   )
  39.   (prin1)
  40. )
发表于 2004-2-25 02:16:56 | 显示全部楼层
“无名块改名后,再改出错.”
能说说具体测试的情形么?查到原因否?想到解决的办法否?
测试,好像做匿名块还有点问题,是我弄错了么?
另外,建议可做匿名块的提示放到前面去,命名完了才显示,有点晚了。
Command:  TT
选要改名的块:
新名称(1): *
名称可以为*加任意字母,变为匿名块
Command:
Command:
Command: es LIST 1 found
                  BLOCK REFERENCE  Layer: "0"
                            Space: Model space
                   Handle = 99
                  "1"    (块名没变?)
                at point, X=    30831  Y=    12778  Z=        0
                 X scale factor         1
                 Y scale factor         1
          rotation angle      0
                 Z scale factor         1
Command: tt
选要改名的块:
新名称(1): *U
错误: Automation 错误。 Key not found
Command: tt
选要改名的块:
新名称(1): *1
错误: Automation 错误。 调用方法 SetObjectId 的界面 IAcadBaseObject 失败
Command:
TT
选要改名的块:
新名称(1): *a
发表于 2016-8-23 09:20:59 | 显示全部楼层
这个东西真心不错,可以改块的名称了。。。
发表于 2016-10-28 08:00:19 | 显示全部楼层
正需要,支持 aeo 楼主大人了!
发表于 2026-2-14 15:56:04 | 显示全部楼层
这个东西真心不错,可以改块的名称了。
GMT+8, 2026-11-22 08:54 , Processed in 0.576554 second(s), 18 queries , Gzip On, File On.
