查看: 947|回复: 1
[VBA函数]:请教:vba 的多义线的offset方法如何用?
发表于 2002-9-24 16:47:00 | 显示全部楼层 |阅读模式
vba中的多义线偏移时,对于同样的参数有的图形向外偏移,有的图形向内偏移,为什么?如何判断到底是向外偏移,还是向内偏移?
发表于 2002-9-26 09:24:38 | 显示全部楼层
Distance
Double; input-only
The distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve's radius). If "smaller" has no meaning, then it would offset in the direction of smaller X, Y, and Z WCS coordinates.
GMT+8, 2026-11-22 10:15 , Processed in 0.425434 second(s), 12 queries , Gzip On, File On.
