查看: 2386|回复: 1
[求助] 请高手帮忙以下CAD双向偏移代码怎样添加记忆功能,记忆上次输入数值,并使之可连续偏移
发表于 2013-5-1 14:26:39 | 显示全部楼层 |阅读模式
请高手帮忙,以下CAD双向偏移代码怎样添加记忆功能,记忆上次输入数值,并使之可连续偏移?
[pcode=lisp,true]
(defun c:11 ()
   (setq os (getvar "osmode") cm (getvar "cmdecho"))
    (setvar "cmdecho" 0)
   (while (setq a (entsel "选择要偏离是目标:(回车退出)"))
     (setvar "osmode" 0)
     (setq aa (car a) pp (cadr a))
     (setq en (entget aa) pk (cdr (assoc 0 en)))
     (setq d (getreal "双向的总距离:") dd (/ d 2))
     (if (= pk "LINE")(setq p1 (cdr (assoc 10 en)) p2 (cdr (assoc 11 en)) an (+ (angle p1 p2) (* pi 0.5)) an1 (+ an pi)
                pp1 (polar pp an d) pp2 (polar pp an1 d))
       (if (= pk "ARC")(setq p1 (cdr (assoc 10 en)) r (cdr (assoc 40 en)) an (cdr (assoc 50 en)) an1 (+ an pi)
     (if (= pk "CIRCLE")(setq p1 (cdr (assoc 10 en)) r (cdr (assoc 40 en)) an 0 an1 pi pp1 (polar pp an d) pp2 (polar pp an1 d))
       (if (or (= pk "LWPOLYLINE")(= PK "SPLINE"))
         (setq pp1 (getpoint pp "方向:") an (angle pp pp1) an1 (+ an pi) pp2 (polar pp an1 (distance pp pp1)))
        (command "offset" dd aa pp1 aa pp2 "")
(setvar "osmode" os)
(setvar "cmdecho" cm)
[/pcode]
发表于 2016-5-11 15:13:50 | 显示全部楼层
用图形词典吧
GMT+8, 2026-11-22 07:46 , Processed in 0.620305 second(s), 11 queries , Gzip On, File On.
