查看: 1129|回复: 0
[VBA程序]:如何使非停靠的工具条不可见
发表于 2002-9-27 17:46:24 | 显示全部楼层 |阅读模式
Invoking AutoCAD with undocked toolbars in invisible mode
ID    50798
Applies to:    AutoCAD 2000
This document is part of    AcDb (AutoCAD Database)   COM-ActiveX Interfaces   Visual Basic
Question
How can I invoke AutoCAD in invisible mode when there are undocked toolbars?
Answer
This is a known problem. A workaround is to dock or hide the undocked toolbars
as soon as AutoCAD is invoked as shown in the following sample code:
  1. [FONT=courier new]
  2. Dim a_app As AcadApplication
  3. Dim mngrp As AcadMenuGroup
  4. Dim tbar As AcadToolbar
  5. Set a_app = CreateObject("Autocad.Application.15")
  6. For Each mngrp In a_app.MenuGroups
  7.    For Each tbar In mngrp.Toolbars
  8.         If tbar.DockStatus = acToolbarFloating And tbar.Visible = True Then
  9.             tbar.Visible = False 'hide the toolbar
  10.         End If
  11.    Next tbar
  12. Next mngrp
  13. a_app.Visible = False
  14. [/FONT]
GMT+8, 2026-11-22 09:43 , Processed in 0.290068 second(s), 8 queries , Gzip On, File On.
