查看: 1297|回复: 0
[VBA程序]:如何获得所有插入块实体到一个选择集
发表于 2002-9-27 18:14:36 | 显示全部楼层 |阅读模式
How to create a selection set of all the insertions of a block?
ID    2019
Applies to:    AutoCAD
This document is part of    Block Reference   COM-ActiveX Interfaces   Selection Sets   VBA
Question
How do I create a selection set using the select method with a filter of a given
block in a drawing?
Answer
The following sample code selects all inserts of the block named "A".
  1. [FONT=courier new]
  2. Dim sset As Object
  3.    Set sset = ActiveDocument.SelectionSets.Add("TEST")
  4.
  5.    Dim mode As Integer
  6.    Dim corner1 As Variant, corner2 As Variant
  7.    Dim point1(0 To 2) As Double, point2(0 To 2) As Double
  8.
  9.    Dim gpCode(0 To 1) As Integer
  10.    Dim dataValue(0 To 1) As Variant
  11.    Dim groupCode As Variant, dataCode As Variant
  12.    gpCode(0) = 0
  13.    dataValue(0) = "Insert"
  14.    gpCode(1) = 2
  15.    dataValue(1) = "A"
  16.
  17.    groupCode = gpCode
  18.    dataCode = dataValue
  19.
  20.    point1(0) = 0
  21.    point1(1) = 0
  22.    point1(2) = 0
  23.    point2(0) = 0
  24.    point2(1) = 0
  25.    point2(2) = 0
  26.
  27.    corner1 = point1
  28.    corner2 = point2
  29.    sset.Select acSelectionSetAll, corner1, corner2, groupCode, dataCode
  30. Here point1 and point2 are dummy points because of selection mode
  31. acSelectionSetAll.
  32. [/FONT]
GMT+8, 2026-11-22 09:43 , Processed in 0.308824 second(s), 10 queries , Gzip On, File On.
