查看: 1846|回复: 6
[文章]:大于1.1M画双开门,小于1.1M画单开门
发表于 2007-3-1 07:56:38 | 显示全部楼层 |阅读模式
; Draw all size door
(defun c:dd(/ ds point1 point2 point3 point4 point5 point6 )
  (setq ds (getint "Please input door size:"))
  (command "-osnap" "INT")
  (setq point1 (getpoint "Pick the nearest point"))
  (setq point2 (list (nth 0 point1) (+ 50 (nth 1 point1))))
  (setq point3 (list (nth 0 point1) (+ (* ds 100) (nth 1 point1))))
  (setq point4 (list (+ 50 (nth 0 point3)) (nth 1 point3)))
  (setq point5 (list (+ (- (* ds 100) 50) (nth 0 point4))
               (- (nth 1 point4) (- (* ds 100) 50))))
  (setq point6 (list (nth 0 point5) (- (nth 1 point5) 50 )))
  (command "pline" point1 "W" "0" "" point2 point3 point4 "arc" point5 "line" point6 "")
  (setq door (ssget "L"))
  (command "rectangle" point2 point4)
  (ssadd (entlast) door)
  (initget 1 "Rotate Mirror Quit")
  (setq input (getkword "Rotate\\Mirror\\Quit:"))
  (while (or (= input "Rotate")(= input "Mirror"))
   (cond
     ((= input "Rotate")
      (command "rotate" door "" point1 pause ))
     ((= input "Mirror")
      (command "mirror" door "" point1 pause "y"))
   (initget "Rotate Mirror Quit")
   (setq input (getkword "Rotate\\Mirror\\Quit:")))
   (setvar "osmode" 33)
; Draw all size double door
(defun c:ddd(/ ds point1 point2 point3 point4 point5 point6 point7 point8 point9 )
  (setq point3 (list (nth 0 point1) (+ (* ds 50) (nth 1 point1))))
  (setq point5 (list (+ (- (* ds 50) 50) (nth 0 point4)) (- (nth 1 point4)
               (- (* ds 50) 50))))
  (setq point6 (list (+ (- (* ds 50) 50) (nth 0 point5)) (+ (- (* ds 50) 50)
               (nth 1 point5))))
  (setq point7 (list (+ 50 (nth 0 point6)) (nth 1 point6)))
  (setq point8 (list (nth 0 point7) (- (nth 1 point7) (- (* ds 50) 50))))
  (setq point9 (list (nth 0 point8) (- (nth 1 point8) 50)))
  (command "pline" point1 "W" "0" "" point2 point3 point4 "arc" point5 "angle" "-90"
           point6 "line" point7 point8 point9 "")
  (setq d-door (ssget "L"))
  (command "rectangle" point2 point4 )
  (ssadd (entlast) d-door)
  (command "rectangle" point6 point8)
   (cond
     ((= input "Rotate")
      (command "rotate" d-door "" point1 pause ))
     ((= input "Mirror")
      (command "mirror" d-door "" point1 pause "y"))
这是从本论坛下载的两个画门的程序,一个画单开门,一个画双开门,我想把两个程序合并为一个程序,合并后的程序这样运行,当输入的门宽大于1.1M画双开门,小于1.1M画单开门
发表于 2007-3-1 11:30:03 | 显示全部楼层
按照楼主的要求,将两个函数合并后,如下:
[PHP]
(defun c:d (/ ds point1 point2 point3 point4 point5 point6 point7 point8 point9)
    ;;判断部分
    (if        (< ds 110)
        ;; Draw all size door
        (progn
            (setq
            (setq point6 (list (nth 0 point5) (- (nth 1 point5) 50)))
                     "line"   point6   ""
        ;; Draw all size double door
        (progn
                               (- (nth 1 point4)
                                  (- (* ds 50) 50)
                               (+ (- (* ds 50) 50)
                                  (nth 1 point5)
            (setq point8
                     "angle"  "-90"    point6        "line"         point7
                     point8   point9   ""
    ;;编辑选项
    (while (or (= input "Rotate") (= input "Mirror"))
        (cond
            ((= input "Rotate")
             (command "rotate" door "" point1 pause)
            ((= input "Mirror")
    (princ)
[/PHP]
另外:
1.尺寸选项最好设置一个默认选项,以方便交互;编辑选项亦是如此。
2.在计算点位坐标时,使用polar函数较好。
3.门窗桌椅之类,利用动态块插入的方法创建,更利于后续编辑修改。
 楼主| 发表于 2007-3-1 13:13:02 | 显示全部楼层
谢谢楼上的朋友,问题已解决
发表于 2007-3-1 13:54:36 | 显示全部楼层
试一试这个怎样?
[PHP]
            point9)
    (setvar "CMDECHO" 0)
    (setq point1  (getpoint "点取第一点:")
          point11 (getpoint point1 "点取第二点:")
          ds          (/ (distance point1 point11) 100.0)
    ;;判断部分
    (if        (<= ds 110)
        (progn
            (setq
                     "line"   point6   ""
        (progn
                               (- (nth 1 point4)
                                  (- (* ds 50) 50)
                               (+ (- (* ds 50) 50)
                                  (nth 1 point5)
            (setq point8
                     point8   point9   ""
    ;;处理选项
    (command "rotate" door "" point1 point11)
    (princ "\n宽度:")
    (princ ds)
    (initget "Yes No")
    (if        (= "Yes" (getkword "\n是否镜像?[是(Y)/否(N)] <N>:"))
        (command "mirror" door "" point1 point11 "y")
    (princ)
[/PHP]
 楼主| 发表于 2007-3-1 14:31:36 | 显示全部楼层
非常好,不愧为高手
有点小问题,当在画门的位置有其它线段时,程序在画门时会出现错误,比如门的开启线弧度出现错误,可能是程序捕获了其它线段的点
发表于 2007-3-1 15:55:14 | 显示全部楼层
通过控制捕捉设置可以解决楼上的此类问题。改进后如下所示:
[PHP]
            point9)
    ;;保存系统变量设置
    (setq old_OS  (getvar "OSMODE")
          old_CMD (getvar "CMDECHO")
    (if        (setq point1 (getpoint "点取第一点:"))
        (if (setq point11 (getpoint point1 "点取第二点:"))
            (progn
                (setq ds (/ (distance point1 point11) 100.0)
                ;;判断部分
                (setvar "OSMODE" 0)
                (if (<= ds 110)
                    (progn
                        (setq
                                           (nth 1 point3)
                                              (nth 0 point4)
                                           (- (nth 1 point4)
                                              (- (* ds 100) 50)
                    (progn
                        (setq
                                           (nth 1 point3)
                                              (nth 0 point4)
                                           (- (nth 1 point4)
                                              (- (* ds 50) 50)
                                              (nth 0 point5)
                                           (+ (- (* ds 50) 50)
                                              (nth 1 point5)
                                           (nth 1 point6)
                        (setq point8
                                 point9          ""
                ;;处理选项
                (princ "\n宽度:")
                (princ ds)
                (initget "Yes No")
                (if (= "Yes"
                (princ "\n成功完成!")
    ;;恢复系统变量设置
    (setvar "CMDECHO" old_CMD)
    (setvar "OSMODE" old_OS)
    (princ)
[/PHP]
发表于 2007-3-3 22:13:39 | 显示全部楼层
刚开始学,还不是看的很明白。。
GMT+8, 2026-11-22 09:54 , Processed in 1.125100 second(s), 22 queries , Gzip On, File On.
